    Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**
    deepsleep
    127 Posts 48 Posters 112.5k Views 57 Watching
      Thosch42 @seb
      @seb
      Hi!
      I found the problem. My Otii Arc was defective. So, everything is fine.
      Thomas
        dbrgn @Thosch42
        @thosch42 said in Root causes of high deep sleep current [LoPy1, WiPy2 and SiPy], all the new modules **do not have deepsleep issues**:
        Oh, how did you find out? With the resistor test?
          Thosch42 @dbrgn
          @dbrgn
          Nope! A little bit harder ;-)
          I stripped down my complete design, module per module, to find out who draws the 6.5mA. The last step was, to pull the cable from the output terminal of my Arc. And, oh wonder, I had still a current of 6.5mA ;-)
          I contacted the support from Qoitech, and a replacement arrived next day!!!
          Thomas
            lj Pybytes Beta
            @Pycom
            Will LoPy1 be redesigned to allow newer production bacthes to have a proper deesleep mode( ~5 and ~15uA) by its own ( at least this is what I undertood) , or will it need the deepsleep shield for ever?
            migrating to Lopy4 is not an option because it is not priced the same.
            Thanks for your reply.
              robert-hh @lj
              @lj I would not expect that. Any new devices use ESP32 Rev 1, and the code as it is assumes PSRAM for a Rev1 device. Obviously, that could be changed, but not easily.
                james_seth
                @Fred
                I have two Lopy v1.0r boards. Due to the evolving ESP32 code set I benched the boards for a while and used an alternative product to accomplish the task due to time constraints and have now come back to redesign the product using the Lopy. As the product runs off a battery the low power capabilities is a must. I only saw this post now and the survey is closed.
                Kind regards,
                James
                • sebS Offline
                  seb @james_seth
                  @james_seth
                  Sent an email to salessupport@pycom.io if you need some deepsleep shields
                    akshayjames @incognico
                    @incognico Hi
                    The high current during deepsleep is due to the LTE module. LTE is started automatically during boot. You need to deinit LTE separately before calling deepsleep as LTE is not stopped automatically during deepsleep.
                    I had the same issue. My FiPy module was drawing 49mA during deepsleep. After I called LTE deinit, the current draw reduced by a lot at that time itself. After that deepsleep worked as expected. :)
                    from network import LTE
                    lte = LTE()
                    LTE.deinit()
                    Hope this helps.
                      dmayorquin
                      Hi @Fred, I need some help with the Pysense deep sleep mode. I have a SiPy + Pysense + 3.7 V LiPo battery (Using JST connector on Pysense). I'm testing Deep sleep mode from last version of Pysense library but I'm measuring high deep sleep current consumption.
                      My program disabled WiFi in boot.py. In main.py It blinks an LED for 5 seconds and then sleeps 20 seconds. These are my results:
                      SiPy firmware: 1.18.0
                      Pysense firmware: 0.0.8
                      Blinking: ~50 mA
                      Deep sleep: ~2.2 mA
                      main.py code:
                      from pysense import Pysense
                      py = Pysense()
                      #Turn-off heartbeat
                      if pycom.heartbeat() == True:
                          pycom.heartbeat(False)
                      #Blink the LED
                      for i in range(5):
                          pycom.rgbled(0x1F)
                          time.sleep(0.05)
                          pycom.rgbled(0x00)
                          time.sleep(1)
                      #Sleep 20 seconds
                      py.setup_sleep(20)
                      py.go_to_sleep()
                      boot.py code:
                      from network import WLAN
                      wlan = WLAN()
                      wlan.deinit()
                      I tried other SiPy firmware versions (1.13.0.b1, 1.15.0.b1, 1.17.3.b1, 1.19.0.b4) but results are the same. @daniel said a few months ago this Pysense issue was resolved, but can you confirm if there is still something wrong with Pysense? Or, am I missing some line of code to make deep sleep mode works as it should? Thanks in advance.
                        Radec @dmayorquin
                        @dmayorquin I think you forget lines codes :
                        Example with timer :
                        machine.deepsleep(3600000 )  # 1 hours
                          dmayorquin @Radec
                          Hi @radec, thanks. According to documentation, machine.deepsleep() works well when you are not using a shield or expansion board, but in my case I'm using SiPy + Pysense, so I must use the deep sleep methods of Pysense library. I've found a solution which I posted here:
                          https://forum.pycom.io/topic/3594/how-to-deep-sleep-with-sipy-pysense-3-7v-lipo
                          By the way, I also tried machine.deepsleep() with my setup, but didn't work (the deep sleep current was ~60 mA).
                            mattliddle
                            @Fred What do you need to do to accomplish that low of power consumption on the GPy with deep sleep? I'm getting about 18 mA when it's going into deep sleep..
                            # and later on in the code once my sensor is done running, I call this
                            machine.deepsleep(30000)
                            What could be going on? does the GPy 1.0 need a power saving board as well? I've looked around on the forum only to find no real solution yet, but other users with the same issue.
                              mattliddle @mattliddle
                              @mattliddle @Fred I discovered an important insight! When powering it through USB (I'm using the expansion board 2.1) there is an LED light that turns on and stays on even in deep sleep. I was measuring current draw and it was always at least 14 mA. I tried powering the device outside of the expansion board by a 3.7V source, and in deep sleep, sure enough it dropped into the microamp range. Even when it is on expansion board 2.1 and powered through battery instead of usb, the LED stays turned off, and therefore power consumption will drop into the micro amp range.
                              • 5
                              • 6
                              • 7
                              • 7 / 7
