    30uA and LoRaWAN
    low power
    13 Posts 6 Posters 1.4k Views 7 Watching
      robert-hh @marcozennaro
      @marcozennaro That is hard to tell. As a blind shot, I would set the GPIO pins used for Lora/Sigfox to input. For P5 to P7 this is easy. For the other Pins at GPIO17, 18, and 23 this is not supported. These are internal Pins and not accessible through machine.Pin. And for GPIO17 it might be not recommended anyhow. AFAIK, this is also used for SPIRAM Clock.
        jcaron @marcozennaro
        @marcozennaro Unrelated, but note that you'll probably save a bit by using pycom.wifi_on_boot(false) rather than "manually" disabling WiFi and Bluetooth.
          jcaron
          Another thing you may try: set the socket to blocking to be sure it's finished sending before going to sleep, and/or add a (long enough) time.sleep.
            robert-hh @jcaron
            @jcaron Not likely, because the sx1276 takes 20-120 mA when sending, and about 10 mA when receiving.
              malachib
              Just curious, does your application call for receiving any LoRa packets? Or just sending [1, 2, 3] on start?
                marcozennaro Pycom Ambassadors @malachib
                @malachib it is just sending. As I use ABP I don't have to wait for an acknowledge from the gateway.
                  beyonlo @marcozennaro
                    beyonlo
                    @marcozennaro said in 30uA and LoRaWAN:
                    Using ABP do not means that node will not waiting for a possible ACK from the Gateway. Both, ABP and OTAA always waiting a time (are two DOWNLINK slot times) after sending data, for a possible ACK from the gateway, that is standard. The difference is that OTAA needs an authentication (that will use a DOWNLINK too) before to sent any data, ABP doens't.
                    M bmarkusB 2 Replies Last reply Reply Quote 0
                      marcozennaro Pycom Ambassadors @beyonlo
                      @beyonlo you are perfectly right!
                      • bmarkusB Offline
                        bmarkus @beyonlo
                        @beyonlo said in 30uA and LoRaWAN:
                        You are missing different things.
                        First, Gateway never send ACK, it is done by the LoRaWAN Network Server when requested by the device.
                        ABP and OTAA are activation modes and handling encryption keys. ABP itself doesn't generate any air traffic, keys exchanged out of LoRaWAN. OTAA is a way to generate keys but it has nothing to do with authentication.
                        Whether node will wait for downlink and when is independent of activation mode, it depends on Devics Class 'A' or 'C', 'B' is not supported by PyCom and most of other devices.
