    joining OTAA and then sending location data
    lopy4
    24 Posts 3 Posters 3.5k Views 3 Watching
      robert-hh @abhishek2101
      @abhishek2101 Does it work, if you call:
      import mylora
      from the REPL prompt?
      if yes, and this statement is inside main.py, do not reset from pymakr, instead push the reset button on the Lopy4.
      Pymakr may do a safe boot, which prevents boot.py and main.py from running.
      Using my firmware package, you can check the content of main.py and boot.py from the REPL command line by:
      from upysh import *
      cat("main.py")
      cat("boot.py")
        @abhishek2101 You can also look into files using Chrome or the linux file manager, by connecting to:
        ftp://<lopy_ip_address>
        e.g.
        ftp://192.168.4.1
          abhishek2101 @robert-hh
          @robert-hh it does not work from REPL prompt also. I have also tried reseting from the button.
          screenshot attached.
            @abhishek2101 What I see:
            main.py starts and calls mylora.py, and that runs into an error at line 5. So check your script.
              @robert-hh here is the code, dont see any problem with line 5
              the same code when i run (using pymakr plugin in atom) without uploading is able to run and join the TTN.
              from network import LoRa
              import ubinascii
              # Initialise LoRa in LORAWAN mode.
              # Please pick the region that matches where you are using the device:
              # Asia = LoRa.AS923
              # Australia = LoRa.AU915
              # Europe = LoRa.EU868
              # United States = LoRa.US915
              lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.IN865)
              # create an OTAA authentication parameters
              app_eui = ubinascii.unhexlify('xxxxxxx')
              app_key = ubinascii.unhexlify('xxxxxxx')
              # join a network using OTAA (Over the Air Activation)
              while not lora.has_joined():
                  time.sleep(2.5)
                  print('Not yet joined...')
              # create a LoRa socket
              # set the LoRaWAN data rate
              # make the socket blocking
              s.setblocking(True)
              # send some data
              s.setblocking(False)
              data = s.recv(64)
              print(data)```
                @abhishek2101 There is a difference. When you run the code from pymakr, it is freshly uploaded. If you call it from main.py fro in the terminal window of pymakr, you run the local copy on the device.
                What happens, if in the REPL prompt, you enter the command:
                import mylora
                  @robert-hh nothing happens
                  attached screenshot
                    @abhishek2101 Since you have importedthat already in main.py, the second one is not executed. You have to remove that "import mylora" first from main.py
                      @robert-hh got it working !!
                      since i was cutting and pasting the code, there were some truncation problems which were causing the errors.
                        @abhishek2101 That's good. besides that, make yourself familiar with ftp (file transfer protocol), who's only purpose is to transfer files. That avoids any copying errros.
                        • 2 / 2
