    Updating code is not working!!!
    gpyexpansion board
    5 Posts 3 Posters 935 Views 3 Watching
      averri
      I'm trying to upload code to the board using the Pycharm with Micropython plugin. The Expansion does not respond.
      Connecting to COM7
      Uploading files: 0% (0/1)
      C:\dev\source\personal\embedded\pycom\blink\boot.py -> boot.py
      b'Traceback (most recent call last):\r\n  File "boot.py", line 12, in <module>\r\nKeyboardInterrupt: \r\nPybytes library: v0.9.0\r\nStarting UART...\r\n'
        File "C:\Users\abc\.PyCharmCE2018.2\config\plugins\intellij-micropython/scripts/microupload.py", line 138, in <module>
          main(sys.argv[1:])
        File "C:\Users\abc\.PyCharmCE2018.2\config\plugins\intellij-micropython/scripts/microupload.py", line 79, in main
          files.put(remote_path, fd.read())
        File "C:\Users\abc\AppData\Local\Programs\Python\Python37-32\lib\site-packages\ampy\files.py", line 157, in put
          self._pyboard.enter_raw_repl()
        File "C:\Users\abc\AppData\Local\Programs\Python\Python37-32\lib\site-packages\ampy\pyboard.py", line 192, in enter_raw_repl
          raise PyboardError('could not enter raw repl')
      ampy.pyboard.PyboardError: could not enter raw repl
      I have a demo to do with this stuff, please help.
      danD robert-hhR 3 Replies Last reply Reply Quote 0
      • danD Offline
        dan @averri
        @averri Hi, any reason you're not using Pymakr with Atom or VSCode?
          averri @dan
          @dan I have done a factory reset (connecting G28 pin to the +3.3v). After that, I was able to upload the code again.
          I had tried Pymakr with VisualStudio, it was not working fine. The Pymakr with Atom is working, but I prefer to use the Pycharm, the IDE is much better in many aspects.
            robert-hh @averri
            @averri Why don't you use ftp?
              robert-hh @averri
              @averri Besides that, I tried adafruit-ampy, which seems to be used by pycharm, and it works fine. Please be aware, that the files on the device mist be stored under /flash directory (or /sd, it mounted there). So a boot.py must have the target name /flash/boot.py
