High current consumption in deep sleep: 80 mA
  • Hi, I'm testing GPy on deep sleep mode, and the current consumption is around 80 mA. I was expecting something in the uA range, do you know what's wrong?
    I'm invoking the deep sleep with:
    machine.deepsleep(10000)
    I have a boot.py file with WiFi configuration. I'm using GPy v1.0.
  • @averri said in High current consumption in deep sleep: 80 mA:
    We just mitigated this through [1] by invoking lte.deinit() with the "reset" operation like
    lte.deinit(detach=False, reset=True)
    [1] https://github.com/hiveeyes/hiveeyes-micropython-firmware/commit/ec7c80e1219fb119c2881a0019cecdfad220f29f
  • I'm having the same problem. When I arrive at home a will insert a SIM card and check if the current consumption decrease.
    Update:
    I have insert a SIM card. And make lte.deinit() and de current consumption in deepsleep drop to 0.022 mA.
  • @jcaron No, I don't have a SIM card. Is it possible to disable the LTE without the SIM card?
  • @averri Do you have a SIM card in the module? IIRC LTE.deinit() won't work without one.
  • @robert-hh The LTE deinit is not working, please see the message above.
  • It does not work. I'm using the following code:
    import json
    from mqtt import MQTTClient
    from network import WLAN, LTE
    def sleep(millis):
        print('Going to sleep...')
        lte = LTE()
        lte.deinit()
        machine.deepsleep(millis)
    def handler(topic, data):
        print(topic, data)
        payload = json.loads(data.decode('utf-8'))
        msg = payload['msg'] if 'msg' in payload else None
        if msg == 'deepSleep':  # Here we enter deep sleep.
            sleep(10000)
    def connect_mqtt():
        """Connects to the MQTT queue."""
        print('Connecting to the MQTT server...')
        c = MQTTClient('alex-device', 'xxx', port=1883, user='xxx', password='xxx')
        c.set_callback(handler)
        c.connect()
        c.publish('inTest', 'Device connected!')
        c.subscribe('outTest')
        return c
    def wait_for_wlan():
            if WLAN().mode() == WLAN.STA:
                break
                time.sleep(0.5)
    def main():
        wait_for_wlan()
        c = connect_mqtt()
            time.sleep(0.5)
            # Check MQTT message.
            c.check_msg()
    if __name__ == '__main__':
        main()
    The result:
    Going to sleep...
      File "main.py", line 112, in <module>
      File "main.py", line 95, in main
      File "mqtt.py", line 206, in check_msg
      File "mqtt.py", line 193, in wait_msg
      File "main.py", line 34, in handler
      File "main.py", line 15, in sleep
    Pycom MicroPython 1.18.0.r1 [v1.8.6-849-9569a73] on 2018-07-20; GPy with ESP32
  • @averri You have to de-init the LTE modem.
