    SI7021 I2C pin setup (SOLVED)
    micropythonsi7021i2c
    59 Posts 4 Posters 14.0k Views 4 Watching
      tttadam @robert-hh
      @robert-hh My bad, so sorry. The error is in this line:
      sensor = SI7021(i2c=bus)
        robert-hh @tttadam
        @tttadam Try:
        sensor = SI7021.SI7021(i2c=bus)
        = class SI7021 in module SI7021. Quite confusing at the beginning. You could also have imported the class as:
        from SI7021 import SI7021, then the initial code would work.
        T 1 Reply Last reply Reply Quote 2
          tttadam @robert-hh
          @robert-hh Now I am getting a totaly different error, so I think We are getting somewhere.
          I checked the wiring multiple times. That should be okay.
          VIN-->VIN
          GND-->GND
          G8-->SCL
          G7-->SDA)
            File "main.py", line 14, in <module>
            File "/flash/lib/SI7021.py", line 31, in readTemp
            File "/flash/lib/SI7021.py", line 28, in write_command
          OSError: I2C bus error
          Line 14 is this: print(sensor.readTemp())
          from machine import I2C, Pin
          from dth import DTH
          bus = I2C(0, I2C.MASTER, baudrate=100000, pins=(Pin.exp_board.G8,Pin.exp_board.G7))
          # bus = I2C(0, I2C.MASTER, baudrate=100000, pins=("P8","P7"))
          print(sensor.readRH())
          E robert-hhR 2 Replies Last reply Reply Quote 0
          • E Offline
            Eric73 @tttadam
            @tttadam Have you add a 1K or 4K7 or 10K pull-up resistor on G8 and G7 ?
            What is the board you use ?
              tttadam @Eric73
              @eric73
              Oh, I did not. I just tried out the built in resistances, but doesn't make a difference, still getting the same error.
              I am using right now a lopy4 with ExpansionBoard V3r (But in the final product I will use a pytrack board)
              from dth import DTH
              bus = I2C(0, I2C.MASTER, baudrate=100000, pins=(Pin(Pin.exp_board.G8,mode= Pin.OPEN_DRAIN, pull= Pin.PULL_UP),Pin(Pin.exp_board.G7,mode= Pin.OPEN_DRAIN, pull= Pin.PULL_UP)))
                robert-hh @tttadam
                @tttadam On the expansion board G7 and G8 are also connected to CTS and RTS of the USB/UART bridge. If you want to use them for other means, you have to remove the respective jumpers.
                  tttadam @robert-hh
                  @robert-hh Okay, I changed the pins to 5 and 4. I am still getting the same error, but now it takes some time, like a second or so. Before that a I got the error immediately.
                    File "main.py", line 16, in <module>
                  pin5 = Pin(Pin.exp_board.G5,mode= Pin.OPEN_DRAIN, pull= Pin.PULL_UP)
                  pin4 = Pin(Pin.exp_board.G4,mode= Pin.OPEN_DRAIN, pull= Pin.PULL_UP)
                  bus = I2C(0, I2C.MASTER, baudrate=100000, pins=(pin5,pin4))
                  line16 is this: print(sensor.readTemp())
                    robert-hh @tttadam
                    @tttadam G5 and G4 aka P13 and P14 are input only ports. I wonder that it does not give an error immedetaly when declaring. Why don't you use the default pins G16 and G17 aka "P9" for SDA and "P10" for SCL, at least for a first test?
                    Edit: You do not have to initialize the pins yourself. In the i2c constructor, you can write ... pins=("P9", "P10") or pins=("G16", "G17").
                      tttadam @robert-hh
                      @robert-hh Yes You are right, I should thought about this earlier.
                      So I modified my code like this. Something is still wrong, because I still get the same error.
                      My pins are correct, now but I took a picture just in case.
                      sensor = SI7021(i2c=I2C())
                      layout
                        tttadam @tttadam
                        @tttadam said in SI7021 I2C pin setup:
                        Looks like my picture didn't make it.
                        Here is the url: [https://imgur.com/a/j8fPQxZ](link url)
                          robert-hh @tttadam
                          @tttadam According to the picture, your wiring seems wrong. You connected SDA to P10 and SCL to P9.
                            tttadam @robert-hh
                            @robert-hh I switched them back and for forth. Maybe a I took the picture on the wrong state but I tried both way (just to make sure).
                              robert-hh @tttadam
                              @tttadam In order to test the communication, do some basics like:
                              i2c = I2C(0, I2C.MASTER)
                              i2c.scan()
                              That already should return the adress of the connected device. If that works, then you know at least that the I2C connection is fine and which address your device is using.
                                tttadam @robert-hh
                                @robert-hh said in SI7021 I2C pin setup:
                                i2c.scan()
                                This is what it returns:
                                [64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120]
                                • E Offline
                                  Eric73 @tttadam
                                  @tttadam Strange things, i have a look to your wire connexion, i hope my eyes are wrong but it seem you power your sensor with VIN (approx 5V), but your device SI7021 have +3.6V maximum power supply voltage so +5V can destroy your device.
                                  If i take time to watch your wire it because typically on a scan i2c your device seem to ACK all address starting by 0x40 (64) and this can be happen in case of bad gnd connexion, please check your power supply +3.3V and GND for your SI7021.
                                  If you have an oscilloscope for probin SDA and SCL this will be very helpfull.
                                    robert-hh @tttadam
                                    @tttadam Definitely Vcc should be 3.3 V. And I cannot tell whether pull-up resistors are present on the board. Adding some with a value of about 4.7 - 10 kOhm should not hurt.
                                      tttadam @Eric73
                                      @eric73 Well, you are right. I gave the sensor 5v instead of 3.3. I think I killed it.. well least a learned something. I also tried with 10k resistor but still getting I2C bus error...
                                      Thanks for the help anyway.
                                        robert-hh @tttadam
                                        @tttadam did you try swapping sda and scl again when running with 3.3v?
                                          tttadam @robert-hh
                                          @robert-hh Yes.
                                          for i2c.scan() i get back this: [64], but I2C bus error for print(sensor.readTemp())
                                            robert-hh @tttadam
                                            @tttadam So it means that at least the i2c protocol is now working. 64 or 0x40 ist the proper i2c address of the device. Try to reduce the baud rate.
                                            • 1 / 3
