    SI7021 I2C pin setup (SOLVED)
    micropythonsi7021i2c
    59 Posts 4 Posters 14.0k Views 4 Watching
      robert-hh @tttadam
      @tttadam 1K is too low. The usual recommendation is 4.7 k. But that should not change the figure. The question is, whether i2c.scan() returns [64] also in the context of your main code.
      If yes, then the port & wires & I2C protocol are OK, and we have to look at the SI7021 module.
        tttadam @robert-hh
        @robert-hh Okay, I will get bigger resistors, and replace the sensor.
        Thank you for the help.
          robert-hh @tttadam
          @tttadam I searched a little bit for a module that looks like yours. I found one, and in the backside pictures I see some resistors, which most likely are 10k pull-up resistors, and a three terminal device, which is according to the print-out a LM6206N3 3.3V voltage regulator. The pull-up resistors seem to be connected to 5V. Being 10k, that should not hurt the pycom device, and you do not need external pull-up resistors. And the 5V were OK for your device.
          Edit: I see also a dual level shifter, which is intended to connect a 5V side at the micro to the 3.3 V side of the sensor. It is a single FET transistor level shifter.
            tttadam @robert-hh
            @robert-hh Well I just ran the code again(from 5V without resistors), but I got OS error for every baud rate from 1 to 10000. So I think something most be wrong with this sensor.
            • E Offline
              Eric73 @tttadam
              @tttadam Single transistor level shifter ? A single transistor is an inverter gate, your SDA and SCL signal will be inverted. Please note that i2c is an opendrain bus with pull up. Your SI7021 can be powered by +5V (if its identical to the one showed by robert-hh) but have you checked is your board have 5V-3.3V regulator and have you checked what is SDA and SCL voltage level when you just power SI7021? In SI7021 datasheet absolute maximum rating for SDA and SCL is 3.3V, i have doubts that a SI7021 board have +5V pull-up on SDA and SCL....without power any of the two board, please check your wire continuity with multimeter if you can.
                robert-hh @Eric73
                @eric73 said in SI7021 I2C pin setup:
                Yes. there is a standard circuit doing this with single MosFET transistor, used by all cheap level shifter. Principle below. LV is low voltage, HV is high voltage, Lx and Hx are the low & high voltage logic. And you see the pull-up resistors on both sides:
                P.S.: You could make a picture of the back side of the sensor, just to clarify @Eric73 's question.
                T 1 Reply Last reply Reply Quote 2
                • nespressifN Offline
                  nespressif
                  Hello everyone, I have tested with an HTU21d sensor that is very similar to the SI7021 and with the SI7021 class I also get the "I2C bus error". However with the code in the main.py, it works perfectly, and without external resistances, I do not understand why I get the error with the class, if everything seems to be fine.
                  I use this one:
                  from machine import I2C
                  i2c = I2C(0, I2C.MASTER)
                  print(i2c.scan()) #I get [64] is 0x40
                  i2c.writeto(0x40, 0xf3) #read temp no hold
                  time.sleep_ms(25)
                  temp = i2c.readfrom(0x40, 3)
                  temp2 = temp[0] << 8
                  temp2 = temp2 | temp[1]
                  print((175.72 * temp2 / 65536) - 46.85)
                  I hope it helps you, Regards
                  robert-hhR 1 Reply Last reply Reply Quote 2
                    robert-hh @nespressif
                    @nespressif The difference is in writing the command. In your example, you are writing a single int value,
                    wheras in the class it is two bytes, where the first byte contains the command, and the second a zero.
                      def write_command(self, command_byte):
                        self.cbuffer[0] = command_byte
                        self.i2c.writeto(self.addr, self.cbuffer)
                    Since you have a suitable device at hand, could you try to change the class accordingly. e.g. like below:
                      def readTemp(self):
                        self.i2c.writeto(self.addr, CMD_MEASURE_TEMPERATURE)
                        sleep_ms(25)
                        temp = self.i2c.readfrom(self.addr,3)
                        return (175.72 * temp2 / 65536) - 46.85
                    nespressifN 1 Reply Last reply Reply Quote 1
                      nespressif @robert-hh
                      @robert-hh I'm sorry, but I don't understand what you want me to do. I've already tried creating a SI7021(i2c) class object and I get that error. Maybe that's how it works, I'll try it:
                          #self.cbuffer[0] = command_byte
                          self.i2c.writeto(self.addr, command_byte)
                      robert-hhR 2 Replies Last reply Reply Quote 1
                          @nespressif @tttadam I just verified that change to write_command(), and it works.
                          Setting: Vin of the SI7021 module at 3.3V, not external pull-up resistors.
                            tttadam @robert-hh
                            @robert-hh 1sorry for the delay.
                            I took pictures of the sensors.
                            https://photos.app.goo.gl/d1p1NSwZaXU41QbK8
                              tttadam @robert-hh
                              @robert-hh Sorry But it is not clear for me. What sould I change in SI7021.py file?
                              Thnak you
                                robert-hh @tttadam
                                @tttadam The board looks fine. Not additional resistors required. In the SI7021 class there is a function call write_command. Change that function into:
                                  tttadam @robert-hh
                                  @robert-hh well I ran my little baudrate finder again with modflyed write_command method.
                                  But I got tha same result, exept it frozed at 2964 baud.
                                  I am not sure what am I missing.
                                    robert-hh @tttadam
                                    @tttadam Don't care about the baud rate. Here is works well at the default baud rate (I purchased I device for testing). This is the class code which works:
                                    from time import sleep_ms
                                    from machine import Pin, I2C
                                    # Default Address
                                    SI7021_I2C_DEFAULT_ADDR = 0x40
                                    # Commands
                                    CMD_MEASURE_RELATIVE_HUMIDITY_HOLD_MASTER_MODE = 0xE5
                                    CMD_MEASURE_RELATIVE_HUMIDITY = 0xF5
                                    CMD_MEASURE_TEMPERATURE_HOLD_MASTER_MODE = 0xE3
                                    CMD_MEASURE_TEMPERATURE = 0xF3
                                    CMD_READ_TEMPERATURE_VALUE_FROM_PREVIOUS_RH_MEASUREMENT = 0xE0
                                    CMD_RESET = 0xFE
                                    CMD_WRITE_RH_T_USER_REGISTER_1 = 0xE6
                                    CMD_READ_RH_T_USER_REGISTER_1 = 0xE7
                                    CMD_WRITE_HEATER_CONTROL_REGISTER = 0x51
                                    CMD_READ_HEATER_CONTROL_REGISTER = 0x11
                                    class SI7021(object):
                                      def __init__(self, i2c=None):
                                        self.i2c = i2c
                                        self.addr = SI7021_I2C_DEFAULT_ADDR
                                        self.cbuffer = bytearray(2)
                                        self.cbuffer[1] = 0x00
                                      def readTemp(self):
                                        self.write_command(CMD_MEASURE_TEMPERATURE)
                                        sleep_ms(25)
                                      def readRH(self):
                                        self.write_command(CMD_MEASURE_RELATIVE_HUMIDITY)
                                        sleep_ms(25)
                                        rh = self.i2c.readfrom(self.addr, 3)
                                        rh2 = rh[0] << 8
                                        rh2 = rh2 | rh[1]
                                        return (125 * rh2 / 65536) - 6
                                    It is called with:
                                    i2c=I2C(0, I2C.MASTER)
                                    from SI7021 import SI7021
                                    m = SI7021(i2c)
                                    print(m.readRH(), m.readTemp())
                                    Device connected at P9 = SDA and P10 = SCL, Vin at 3.3V
                                      tttadam @robert-hh
                                        File "main.py", line 6, in <module>
                                        File "/flash/lib/SI7021.py", line 32, in readTemp
                                      OSError: I2C bus error
                                      still the same. If it's working on your side, than my sensor must be dead.
                                        robert-hh @tttadam
                                        @tttadam Please check that there is only one copy of SI7021.py installed on your device. When working with pymakr, that may happen. Please use simple tools like ftp for the check. And yes, the version I posted works. No, I do not think that your device is defect. And it is well protected. Ans since it responds well to scan(), the wiring is also fine. So the code or code set-up is most probably the problem.
                                          tttadam @robert-hh
                                          @robert-hh Can I do a factory reset somehow? Delete everything from the device.
                                            robert-hh @tttadam
                                            @tttadam When you update the firmware, then you have in the advanced section the option to erase the file system. Other method from the REPL prompt:
                                            import uos
                                            uos.mkfs("/flash")
                                            And then reboot.
                                            • 3 / 3
