    Firmware release 1.0.0.b2
    38 Posts 10 Posters 15.6k Views 10 Watching
      arneme @daniel
      @daniel I am connected but I guess your server is not responding properly. On the Linux PC I get some sort of SSL error....
      As to firewall issues, that depends on what you are trying to do. Our firewall is open for everything going out but restricts access coming in. If you are trying to open a separate connection (and not piggybacking on the ongoing session) it will most certainly fail.
        Could you try running the unix tool with sudo?
          arneme @daniel
          @daniel I did (and it did not work).
            daniel @arneme
            @arneme when the unix tool fails it normally prints a log with the errors it found. Could you copy and paste the log here? That should help find the problem... Thanks.
            J A 3 Replies Last reply Reply Quote 0
              jasonriedy @daniel
              @daniel I'm trying to update from a system that has Python 3.5.2:
              File "./bin/updater.py", line 3, in <module>
              from esptool import ESP32ROM
              File "/root/pyupgrade/bin/esptool.py", line 183
              print '%s' % inst.CHIP_NAME
              SyntaxError: Missing parentheses in call to 'print'
                arneme @daniel
                @daniel I left my Linux PC at work but I can post the error message tomorrow. I tried the update tool on my Mac from my home network and that worked fine. Unless you changed something it seems to be the firewall at work that stops the necessary network traffic. I am therefore wondering how you are trying to serve the firmware?
                  arneme @daniel
                  @daniel It looks like something went really wrong with the LoPy that I tried to upgrade earlier today without success. I am now not able to get in contact with it at all. The procedure for safe boot is not working (P12 to V3V and reset; does not result in orange blinking LED. The WiFi that is usually served by the LoPy is not present). Any ideas on how to fix this or is this LoPy gone forever?
                  I have however successfully upgraded other LoPy devices (from home) to 1.0.0.b2.
                  L D 2 Replies Last reply Reply Quote 0
                    jasonriedy @jasonriedy
                    @daniel Ah, modifying update.py to run python2 explicitly works on a Pi3 running manjaro. Plugging into my laptop may have been easier, but I was curious.
                    BLE scan can run repeatedly, and machine.reset() works for me. Thank you!
                      livius @arneme
                      @arneme
                      try once again your upgrade - deselect "fast connection" or something simmillar in updater tool - it help me on one device maybe you got success also
                        daniel @arneme
                        @arneme no matter how wrong things went, it's not broken for sure. The updater tool is able to program devices with a blank flash memory. You don't need to do a safe boot, simply use the updater tool to flash the latest firmware on it. On the failed update before some sections of the flash memory of your LoPy were erased and not programmed again, that's why it doesn't boot anymore, but the updater tool can fix it without any doubt.
                          mohpor
                          Thanks for the update.
                          I can confirm that WiFi scan now works after Bluetooth instantiation.
                          M.
                            arneme @daniel
                            @daniel Here is the error message:
                             File "lopyupdate.py", line 73, in __do_work
                               self.__done_signal.emit(callback, func(param), param)
                             File "lopyupdate.py", line 97, in get_file_worker
                               timeout=20
                             File "/usr/lib/python2.7/dist-packages/requests/api.py", line 55, in get
                               return request('get', url, **kwargs)
                             File "/usr/lib/python2.7/dist-packages/requests/api.py", line 44, in request
                               return session.request(method=method, url=url, **kwargs)
                             File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 455, in request
                               resp = self.send(prep, **send_kwargs)
                             File "/usr/lib/python2.7/dist-packages/requests/sessions.py", line 558, in send
                               r = adapter.send(request, **kwargs)
                             File "/usr/lib/python2.7/dist-packages/requests/adapters.py", line 385, in send
                               raise SSLError(e)
                            requests.exceptions.SSLError: [Errno 1] _ssl.c:510: error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error
                              rskoniec @livius
                              @livius said in Firmware release 1.0.0.b2:
                              @arneme
                              @daniel By default this "fast connection" option is checked and first time when I was updating my LoPy I get an error. Second time with this option unchecked update was successful. Can you say a little bit more about this option? Thanx. ;o)
                                rskoniec
                                Yesterday I've noticed that this code is working:
                                from network import WLAN
                                wlan = WLAN(mode=WLAN.STA)
                                and this isn't:
                                import network
                                wlan = network.WLAN(mode=WLAN.STA)
                                Please check and let me know if I'm alone with this issue. ;o)
                                • X Offline
                                  Xykon administrators
                                  Unless I'm mistaken github.com/pycom/pycom-micropython hasn't yet been updated with this version. The last commit 765f2bc is from 18 days ago. Can you please update the repository?
                                  Christian Ehlers
                                    daniel @Xykon
                                    @Xykon we will update this this Thursday, we are cleaning up several things after updating to the latest IDF. Sorry for the delay.
                                      crc16
                                      The "firmware" directory is missing in file pycom_update_1.0.0.b2.tar.gz
                                      • X Offline
                                        Xykon administrators @crc16
                                        @crc16 said in Firmware release 1.0.0.b2:
                                        The firmware file is downloaded automatically. This way you'll always get the latest version of the firmware without having to go to the website and download a new package.
                                        Christian Ehlers
                                        L C 2 Replies Last reply Reply Quote 0
                                          livius @Xykon
                                          @Xykon where it is downloaded?
                                            crc16 @Xykon
                                            @Xykon
                                            it worked ! Thank you.
