    GY-87 micropython library
    micropythongy-80lopy4
    32 Posts 4 Posters 5.2k Views 4 Watching
      tttadam @robert-hh
      This is what I see. So same for me.
      >>> from machine import I2C
      >>> i2c = I2C(1)
      >>> i2c.scan()
      [64, 104, 119]
      >>> i2c.writeto_mem(104, 107, 128) # reset MPU6050
      >>> i2c.writeto_mem(104, 107, 0) # disable sleep
      >>> i2c.writeto_mem(104, 55, 2)   # enable I2C passthru
      >>> i2c.scan()
      [13, 64, 104, 119]
        robert-hh @tttadam
        @tttadam So let's see if that is a bug or an intended address trabslation (but why?)
          robert-hh @tttadam
          @tttadam A short google search gave an answer:
          The chip in the board is not a HMC5883, but a QMC5883. See https://github.com/nodemcu/nodemcu-firmware/issues/2187
          The QMC5883 server for the same purpose, but has different programming interface.
            robert-hh @tttadam
            @tttadam I found a RasPi driver for the QMC5883 and adapted it to pycom MP:
            # ported from http://nobytes.blogspot.com/2018/03/qmc5883-magnetic-field-sensor.html
            import struct
            from machine import idle
            class QMC5883:
                #Default I2C address
                ADDR = 0x0D
                #QMC5883 = Register = numbers
                X_LSB = 0
                X_MSB = 1
                Y_LSB = 2
                Y_MSB = 3
                Z_LSB = 4
                Z_MSB = 5
                STATUS = 6
                T_LSB = 7
                T_MSB = 8
                CONFIG = 9
                CONFIG2 = 10
                RESET = 11
                CHIP_ID = 13
                #Bit values for the STATUS register
                STATUS_DRDY = 1
                STATUS_OVL = 2
                STATUS_DOR = 4
                #Oversampling values for the CONFIG register
                MC5883L_CONFIG_OS512 = 0b00000000
                CONFIG_OS256 = 0b01000000
                CONFIG_OS128 = 0b10000000
                CONFIG_OS64  = 0b11000000
                #Range values for the CONFIG register
                CONFIG_2GAUSS = 0b00000000
                CONFIG_8GAUSS = 0b00010000
                #Rate values for the CONFIG register
                CONFIG_10HZ = 0b00000000
                CONFIG_50HZ = 0b00000100
                CONFIG_100HZ = 0b00001000
                CONFIG_200HZ = 0b00001100
                #Mode values for the CONFIG register
                CONFIG_STANDBY = 0b00000000
                CONFIG_CONT = 0b00000001
                def __init__(self, i2c):
                    self.i2c = i2c
                    self.oversampling = QMC5883.CONFIG_OS64
                    self.range = QMC5883.CONFIG_2GAUSS
                    self.rate = QMC5883.CONFIG_100HZ
                    self.mode = QMC5883.CONFIG_CONT
                    self.reset()
                def reconfig(self):
                    print("{0:b}".format(self.oversampling | self.range | self.rate | self.mode))
                    self.i2c.writeto_mem(QMC5883.ADDR, QMC5883.CONFIG, self.oversampling | self.range | self.rate | self.mode);
                def reset(self):
                    self.i2c.writeto_mem(QMC5883.ADDR, QMC5883.RESET, 0x01)
                    time.sleep(0.1)
                    self.reconfig()
                    time.sleep(0.01)
                def setOversampling(self, x):
                    self.oversampling = x
                    self.reconfig()
                def setRange(x):
                    self.range = x
                    self.reconfig()
                def setSamplingRate(self, x):
                    self.rate = x
                    self.reconfig()
                def ready(self):
                    status = self.i2c.readfrom_mem(QMC5883.ADDR, QMC5883.STATUS, 1)[0]
                    # prevent hanging up here.
                    # Happens when reading less bytes then then all 3 axis and will end up in a loop.
                    # So, return any data but avoid the loop.
                    if (status == QMC5883.STATUS_DOR):
                        print("fail")
                        return QMC5883.STATUS_DRDY
                    return status & QMC5883.STATUS_DRDY
                def readRaw(self):
                    while not self.ready():
                        idle()
                        pass
                    # Python performs a wrong casting at read_i2c_block_data.
                    # The filled buffer has to be onverted afterwards by mpdule Struct
                    register = self.i2c.readfrom_mem(QMC5883.ADDR, QMC5883.X_LSB, 9);
                    # Convert the axis values to signed Short before returning
                    x, y, z, status, t = struct.unpack('<hhhBh', register)
                    return (x, y, z, t)
            and a short test code:
            from qmc5883 import QMC5883
            i2c=I2C()
            print(i2c.scan())
            time.sleep(1)
            qmc = QMC5883(i2c)
                print(qmc.readRaw())
                time.sleep(1)
              tttadam @robert-hh
              @robert-hh thank you, it's looks useful, but after some time it's produce an OSError. Line 17 in my code is this : print(qmc.readRaw())
              and the line 99 is this. register = self.i2c.readfrom_mem(QMC5883.ADDR, QMC5883.X_LSB, 9)
              I think there were an ; which is not needed.
              But something else is still not alright. I didn't find it yet.
              (6967, -4882, -7620, -1943)
              (4742, -7337, -7950, -1923)
                File "main2.py", line 17, in <module>
                File "/flash/lib/qmc5883.py", line 99, in readRaw
              OSError: I2C bus error
                tttadam @robert-hh
                This is the error what i get now. Maybe tomorrow with fresh eye I will see something :)
                [13, 64, 104, 119]
                11001001
                  File "/flash/lib/qmc5883.py", line 95, in readRaw
                  File "/flash/lib/qmc5883.py", line 81, in ready
                • K Offline
                  kuqizz
                    robert-hh @tttadam
                    @tttadam No, the ; is not needed (probably a left-over from an initial C-Code file), but it also does not hurt. There is another one in reconfig(). The OSError is probably caused by a I2C communication problem to the device. I did not let it run for longer than about 20 minutes or 1000 measurement. If you enclose that into a try/except clause, does the device recover?
                    The temperature reading has an offset. That is also told in the data sheet. If I add 4900 to the value, it is almost OK. The value seems to be scaled as °C*100.
                      tttadam @robert-hh
                      @robert-hh Okay, So I try-catch block for OSError for
                      and
                      lines. Looks like it's not recovering.
                      Something went wrongI2C bus error
                        File "/flash/lib/qmc5883.py", line 110, in readRaw
                        File "/flash/lib/qmc5883.py", line 97, in ready
                      NameError: local variable referenced before assignment.
                      Did you used this library for porting?
                      Because it's mention something about readraw blocking.
                      Where did you find the desription about these four values? What are does mean?
                      The whole code looks like this, but it is the same, only thing I added, that I moved a i2c magic into the init method from main:
                      import struct
                      class QMC5883:
                          ADDR = 0x0D
                          X_LSB = 0
                          X_MSB = 1
                          Y_LSB = 2
                          Y_MSB = 3
                          Z_LSB = 4
                          Z_MSB = 5
                          STATUS = 6
                          T_LSB = 7
                          T_MSB = 8
                          CONFIG = 9
                          CONFIG2 = 10
                          RESET = 11
                          CHIP_ID = 13
                          STATUS_DRDY = 1
                          STATUS_OVL = 2
                          STATUS_DOR = 4
                              self.i2c = i2c
                              self.i2c.writeto_mem(104, 107, 128) # reset MPU6050
                              self.i2c.writeto_mem(104, 107, 0) # disable sleep
                              self.i2c.writeto_mem(104, 55, 2)   # enable I2C passthru
                              self.reset()
                          def reconfig(self):
                          def reset(self):
                              time.sleep(0.1)
                              self.reconfig()
                              time.sleep(0.01)
                              self.reconfig()
                          def setRange(x):
                              self.range = x
                              self.reconfig()
                              self.rate = x
                              self.reconfig()
                          def ready(self):
                              try:
                              except OSError as e:
                                  print("Something went wrong"+str(e))
                                  #TODO: Tune it a little
                                  print("fail")
                                  try:
                          def readRaw(self):
                                  idle()
                                  pass
                              return (x, y, z, t)
                        robert-hh @tttadam
                        @tttadam
                        Thanks for the error log. But that only happens if you catch the error, print a message and then continue. The the symbol status is not defined, raising a new exception. So you would either add:
                        status = 0
                        or
                        return 0
                        after the print statements.
                        No. I found Python code, which in turn might have been ported from that web side. See http://nobytes.blogspot.com/2018/03/qmc5883-magnetic-field-sensor.html with a link to another interesting port, of which I might carry over the calibration part.
                        I did intentionally not include that I2C magic, because that is only relevant for this GY87 board.
                          tttadam @robert-hh
                          @robert-hh I found the issue.
                          GY-87 is on breadboard and and from the breadboard connected to the pytrack via dupont cables.
                          It was a contact issue. Sorry for the false alarm.
                          Can you help me out what are those 4 numbers mean, or where do I find a some info about that? My guess is that the last one is related to the temperature somehow but I am not sure.
                          (-925, -2192, -8705, -2071)
                            robert-hh @tttadam
                            @tttadam The first three are the x,y,z values for the magnetic field, the last one is the temperature. All numbers a raw values. I have prepared a version which returns proper scaled gauss values for the magnetic field and °C for temperature. I did not test it yet, so I will send it later.
                            The temperature value has an offset. According to the data sheet, it is scaled properly, so differences are fine. But the offset for the absolute value has to be determined. For my device it is about 5000. So if you local temperature is about 30°C, then it's about the same. The scaling is 100LSB/°C. So if you divide the value by 100, you get °C (with offset).
                              robert-hh @tttadam
                              @tttadam Updated code. The name of the methods are changed to reflect PEP8. SO
                              readRaw() -> read_raw
                              and a new
                              read_scaled(), which returns the values as Gauss and °C.
                              The constructor has an optional second argument for the temperature offset in °C .
                              # initial code by Sebastian Folz, M.Sc. at
                              # http://nobytes.blogspot.com/2018/03/qmc5883-magnetic-field-sensor.html
                              # which, I assume, was itself ported from C-Code
                              # See also https://github.com/RigacciOrg/py-qmc5883l
                              # Changes and Additions:
                              # - port to micropython's I2C methods
                              # - add method read() for scaled values
                              # - reading register values into a static buffer
                              # - parsed register values in one single struct call
                              # - changed method names according to PEP8
                              # - apply PyLint and fixed bugs & warnings reported by it
                              import struct
                              class QMC5883:
                                  ADDR = 0x0D
                                  #QMC5883 Register numbers
                                  X_LSB = 0
                                  X_MSB = 1
                                  Y_LSB = 2
                                  Y_MSB = 3
                                  Z_LSB = 4
                                  Z_MSB = 5
                                  STATUS = 6
                                  T_LSB = 7
                                  T_MSB = 8
                                  CONFIG = 9
                                  CONFIG2 = 10
                                  RESET = 11
                                  STATUS2 = 12
                                  CHIP_ID = 13
                                  STATUS_DRDY = 1
                                  STATUS_OVL = 2
                                  STATUS_DOR = 4
                                  # Mode values for the CONFIG2 register
                                  CONFIG2_INT_DISABLE = 0b00000001
                                  CONFIG2_ROL_PTR = 0b01000000
                                  CONFIG2_SOFT_RST = 0b10000000
                                  def __init__(self, i2c, offset=50.0):
                                      self.i2c = i2c
                                      self.temp_offset = offset
                                      self.register = bytearray(9)
                                      self.reset()
                                  def reset(self):
                                      time.sleep(0.1)
                                      self.reconfig()
                                  def reconfig(self):
                                      # print("{0:b}".format(self.oversampling | self.range | self.rate | self.mode))
                                      time.sleep(0.01)
                                      self.i2c.writeto_mem(QMC5883.ADDR, QMC5883.CONFIG2, QMC5883.CONFIG2_INT_DISABLE)
                                      time.sleep(0.01)
                                  def set_oversampling(self, x):
                                      self.reconfig()
                                  def set_range(self, x):
                                      self.range = x
                                      self.reconfig()
                                  def set_sampling_rate(self, x):
                                      self.rate = x
                                      self.reconfig()
                                  def ready(self):
                                      if status == QMC5883.STATUS_DOR:
                                          print("Incomplete read")
                                  def read_raw(self):
                                      try:
                                              idle()
                                          self.i2c.readfrom_mem_into(QMC5883.ADDR, QMC5883.X_LSB, self.register)
                                          print ("OSError", e)
                                          pass # just silently re-use the old values
                                      x, y, z, _, t = struct.unpack('<hhhBh', self.register)
                                      return (x, y, z, t)
                                  def read_scaled(self):
                                      x, y, z, t = self.read_raw()
                                      scale = 12000 if self.range == QMC5883.CONFIG_2GAUSS else 3000
                                      return (x / scale, y / scale , z / scale, (t / 100 + self.temp_offset))
                              • 2 / 2
