New firmware release 1.10.1.b1
@colateral On MacOS X (which we use internally) the script works fine with either the standard expansion board or the Pytrack / Pysense. This is an issue specifically with running the script on Windows. As I want to include this functionality with the firmware update tool, we'll obviously have to make the script compatible with Windows OS.
@xykon said in New firmware release 1.10.1.b1:
Any chance you can try without assigning a fixed IP?
calling ifconfig() before connect() also solves the problem. I looked into the code, and there seems to be a condition mix-up between the local state of the wlan_obj.disconnected variable and the connection status in the wifi_event_group variable. ifconfig(), when called, disconnects first, which causes a SYSTEM_EVENT_STA_DISCONNECTED event, which attempts to reconnect, while the dhcp client is shut down and the new ip values are set, and the timing relations are not obvious. This might lead to trouble.
Espressif just pushed a new release 2.1.1 (https://github.com/espressif/esp-idf/releases) which is advertised to include bug fixes for two security vulnerabilites: KRACK and BlueBorne
Are the mentioned fixes already included in this current firmware release?
EDIT:
Found the answer regarding Krack myself:
http://espressif.com/en/media_overview/news/espressif-releases-patches-wifi-vulnerabilities-cert-vu228519
Fix is in master since this commit:
https://github.com/espressif/esp-idf/commit/904d6c8f2b01de52597b9e16dad19c78ade9e586This commit is in pycom's esp-idf as well (https://github.com/pycom/pycom-esp-idf/commit/904d6c8f2b01de52597b9e16dad19c78ade9e586).
@tudro Did you find a solution to this issue? Im experiencing the same issue
@bradnz Nope. I guess we have to wait for a new firmware.
@tudro There is a new firmware version out at 1.10.2.b1, but it does not mention deepsleep in the revision notes.
@tudro Interestingly enough, after a lot of testing, I only ever get this error when I have connected to the device, with an expansion board and powering this ONLY through a Lipo battery. With the device connected via USB I dont get this error! I have upgraded to the latest firmware which hasnt fixed the issue so Im not sure where to go to from here.
@bradnz Thank you for the info. I was pretty busy lately and didn't have much time for the lopy. Maybe this week i get a chance to test some more. I tested 2 lopys on usb and they both had the same problem. Even if it's just on batter for you, it still means there is a problem. Maybe they will have time to investigate this sooner or later, otherwise i will just stick to the 1.9 version for now.
@tudro This is hapenning to me now with the last firmware. How did you solve this?
@devinv What is happening?
