    Prevent anyone can download my code over serial
    code protection
    13 Posts 7 Posters 1.2k Views 7 Watching
      dserrano
      I am starting product line that use wiPy 3.0.
      I just see that any one can connect he board and download and copy all my code and credentials.
      There is any way to prevent code download from board?
      C robert-hhR 2 Replies Last reply Reply Quote 2
        combaindeft @dserrano
        @dserrano
        One crazy-out-there-idea ... is for you to compile your own firmware ...
        That is
        A) write your code into the firmware source code ... like in your own custom library ...
        B) compile it and flash your WiPy with your own custom firmware
        C) then all you have to do is Improt your custom lib ... and run your custom function ...
        Import My_Custom_LIB
        My_Custiom_funcion(ANY-DEFINED-PARAMETERS)
          robert-hh @dserrano
          @dserrano You dio in in several levels/step, which both require the ability for you to create your own images:
          1. Level 1: Embed your code as frozen bytecode. Then it is not visible at the command prompt level, but still a falsh dump woudl get access to the bytecode, which then has to be disassembled. The only visible part of the code would be boot.py and optionally main.py. But these can be short and almost empty, just calling your embedded code.
          2. Level 2: Additionally, encrypt the flash. This is supported by the build environment.
            dserrano @robert-hh
            @robert-hh Hello Robert thanks for your replay.
            How can I Embed your code as frozen bytecode?
              dserrano
              @combaindeft said in Prevent anyone can download my code over serial:
              Hi there!
              How can I compile and flash your WiPy code?
                johand @dserrano
                @dserrano The instructions for compiling your own firmware (including your own frozen code) and encrypt it can be found here: https://github.com/pycom/pycom-micropython-sigfox
                  Paul Thornton @johand
                  @johand said in Prevent anyone can download my code over serial:
                  ^this is likely the best way to help avoid the code being dumped.
                    crumble @Paul Thornton
                    @paul-thornton said in Prevent anyone can download my code over serial:
                    I tried to follow the instructions to build the firmware for a LOPY but esptools.py failed on
                    import serial
                    Adding pyserial with pip3 was not the solution. Running this on a hyper-v debian. Big plan was to compile on VM and use windows host for upload. Does the python module works only when a serial is present?
                      johand @crumble
                      @crumble I managed to build and encrypt the WiPy firmware (should be the same) using Windows Subsystem for Linux (https://docs.microsoft.com/en-us/windows/wsl/install-win10) running Ubuntu. I installed pyserial with "pip install pyserial". What is the error you get?
                        crumble @johand
                        @johand
                        I used pip3 to install pyserial-3.4 But serial cannot be found
                        ImportError: No module named serial
                          johand @crumble
                          @crumble I am far from an Python expert, so just guessing... Could it be that you use pip3 instead of pip that I use (I think I got som problems trying to use Python 3)? What if you run "pip list", does pyserial show up as installed?
                            crumble @johand
                            @johand
                            aaahhh, you are right. Micropython is python 3 but the build tool uses python 2. Totally forgot that this still exists on PCs
                            Thanks ;)
                              svonbentzel @dserrano
                              @dserrano I am also interested in this howto ;-)
