    External SD Card
    sd card
    22 Posts 6 Posters 9.0k Views 6 Watching
      Manju2391 @robert-hh
      @robert-hh @livius
      I did change the values according to pycom sources but still its not liking it. I'm getting this error
      File "/flash/sd.py", line 9
      File "/flash/lib/sdcard.py", line 54, in_init_
      File "/flash/lib/sdcard.py", line 79, in init_card
      File "/flash/lib/sdcard.py", line 147, in cmd
      Typeerror: extra positional arguments given
        robert-hh @Manju2391
        @manju2391 It seems that this library is a little bit outdated. I know that I used this on an esp8266, and it worked. And the version on the micropython.org site seems to be a little bit more recent. (https://github.com/micropython/micropython/tree/master/drivers/sdcard). I can check, but not before the evening, which is in about 8 hours.
          Is there any possibility to interface the SD card over shared SPI bus without using any
          libraries? I have been getting my head around the SPI module from last week and I haven't got it yet. Not a problem @robert-hh you can let me know how it goes after testing
            @manju2391 I tried that driver, and I got it to the point where it showed some activity. The code is below. The sdcard SPI is connected to:
            P9 (SS), P10(Clk), P11(MOSI) and P12 (MISO). It is started with:
            import sdcard, machine, os
            sd = sdcard.SDCard(machine.SPI(0), machine.Pin("P9"))
            os.mount(sd, "/card")
            But it is very unstable, runs at low speed only, and data read from the card contains the byte sequence "\x7f\x04" here and there. And sometimes lopy simply crashed. So it's nothing really usable at the moment.
            I tried that with two different SD card adapters. One with embedded bus drivers, which is like the one you have, and one which is simply wiring. The latter runs well when connected to the genuine SD card pins of the xxPy, using the built-in SD card module.
            MicroPython driver for SD cards using SPI bus.
            Requires an SPI bus and a CS pin.  Provides readblocks and writeblocks
            methods so the device can be mounted as a filesystem.
            Example usage on xxPy:
                import machine, sdcard, os
                os.mount(sd, '/sd2')
                os.listdir('/sd2')
            from micropython import const
            _CMD_TIMEOUT = const(100)
            _R1_IDLE_STATE = const(1 << 0)
            #R1_ERASE_RESET = const(1 << 1)
            _R1_ILLEGAL_COMMAND = const(1 << 2)
            #R1_COM_CRC_ERROR = const(1 << 3)
            #R1_ERASE_SEQUENCE_ERROR = const(1 << 4)
            #R1_ADDRESS_ERROR = const(1 << 5)
            #R1_PARAMETER_ERROR = const(1 << 6)
            _TOKEN_CMD25 = const(0xfc)
            _TOKEN_STOP_TRAN = const(0xfd)
            _TOKEN_DATA = const(0xfe)
            class SDCard:
                def __init__(self, spi, cs):
                    self.spi = spi
                    self.cs = cs
                    self.cmdbuf = bytearray(6)
                    self.dummybuf = bytearray(512)
                    for i in range(512):
                        self.dummybuf[i] = 0xff
                    self.dummybuf_memoryview = memoryview(self.dummybuf)
                    # initialise the card
                    self.init_card()
                def init_spi(self, baudrate):
                    master = self.spi.MASTER
                    self.spi.init(master, baudrate=baudrate, phase=0, polarity=0)
                def init_card(self):
                    # init CS pin
                    self.cs.init(self.cs.OUT, value=1)
                    # init SPI bus; use low data rate for initialisation
                    self.init_spi(100000)
                    # clock card at least 100 cycles with cs high
                    for i in range(16):
                        self.spi.write(b'\xff')
                    # CMD0: init card; should return _R1_IDLE_STATE (allow 5 attempts)
                    for _ in range(5):
                        if self.cmd(0, 0, 0x95) == _R1_IDLE_STATE:
                            break
                        raise OSError("no SD card")
                    # CMD8: determine card version
                    r = self.cmd(8, 0x01aa, 0x87, 4)
                    if r == _R1_IDLE_STATE:
                        self.init_card_v2()
                    elif r == (_R1_IDLE_STATE | _R1_ILLEGAL_COMMAND):
                        self.init_card_v1()
                        raise OSError("couldn't determine SD card version")
                    # get the number of sectors
                    # CMD9: response R2 (R1 byte + 16-byte block read)
                    if self.cmd(9, 0, 0, 0, False) != 0:
                        raise OSError("no response from SD card")
                    csd = bytearray(16)
                    self.readinto(csd)
                    if csd[0] & 0xc0 != 0x40:
                        raise OSError("SD card CSD format not supported")
                    self.sectors = ((csd[8] << 8 | csd[9]) + 1) * 2014
                    #print('sectors', self.sectors)
                    # CMD16: set block length to 512 bytes
                    if self.cmd(16, 512, 0) != 0:
                        raise OSError("can't set 512 block size")
                    # set to high data rate now that it's initialised
                    #self.init_spi(100000)
                    #self.init_spi(40000000)
                def init_card_v1(self):
                    for i in range(_CMD_TIMEOUT):
                        self.cmd(55, 0, 0)
                        if self.cmd(41, 0, 0) == 0:
                            self.cdv = 512
                            #print("[SDCard] v1 card")
                            return
                    raise OSError("timeout waiting for v1 card")
                def init_card_v2(self):
                        time.sleep_ms(50)
                        self.cmd(58, 0, 0, 4)
                        self.cmd(55, 0, 0)
                        if self.cmd(41, 0x40000000, 0) == 0:
                            self.cdv = 1
                            #print("[SDCard] v2 card")
                            return
                    raise OSError("timeout waiting for v2 card")
                def cmd(self, cmd, arg, crc, final=0, release=True):
                    self.cs(0)
                    # create and send the command
                    buf = self.cmdbuf
                    buf[0] = 0x40 | cmd
                    buf[1] = arg >> 24
                    buf[2] = arg >> 16
                    buf[3] = arg >> 8
                    buf[4] = arg
                    buf[5] = crc
                    self.spi.write(buf)
                    # wait for the response (response[7] == 0)
                        response = self.spi.read(1, write=0xff)[0]
                        if not (response & 0x80):
                            # this could be a big-endian integer that we are getting here
                            for j in range(final):
                            if release:
                                self.cs(1)
                            return response
                    # timeout
                    self.cs(1)
                    return -1
                def cmd_nodata(self, cmd):
                    self.spi.write(cmd)
                    self.spi.read(1, write=0xff) # ignore stuff byte
                    for _ in range(_CMD_TIMEOUT):
                        if self.spi.read(1, write=0xff)[0] == 0xff:
                            self.cs(1)
                            return 0    # OK
                    self.cs(1)
                    return 1 # timeout
                def readinto(self, buf):
                    self.cs(0)
                    # read until start byte (0xff)
                    while self.spi.read(1, write=0xff)[0] != 0xfe:
                        pass
                    # read data
                    mv = self.dummybuf_memoryview[:len(buf)]
                    self.spi.write_readinto(mv, buf)
                    # read checksum
                    self.cs(1)
                def write(self, token, buf):
                    self.cs(0)
                    # send: start of block, data, checksum
                    self.spi.read(1, token)
                    self.spi.write(buf)
                    # check the response
                    if (self.spi.read(1, 0xff)[0] & 0x1f) != 0x05:
                        self.cs(1)
                        return
                    # wait for write to finish
                    while self.spi.read(1, 0xff)[0] == 0:
                        pass
                    self.cs(1)
                def write_token(self, token):
                    self.cs(0)
                    while self.spi.read(1, 0xff)[0] == 0x00:
                        pass
                    self.cs(1)
                def count(self):
                    return self.sectors
                def readblocks(self, block_num, buf):
                    nblocks, err = divmod(len(buf), 512)
                    assert nblocks and not err, 'Buffer length is invalid'
                    if nblocks == 1:
                        # CMD17: set read address for single block
                        if self.cmd(17, block_num * self.cdv, 0) != 0:
                            return 1
                        # receive the data
                        self.readinto(buf)
                        # CMD18: set read address for multiple blocks
                        if self.cmd(18, block_num * self.cdv, 0) != 0:
                            return 1
                        offset = 0
                        mv = memoryview(buf)
                        while nblocks:
                            self.readinto(mv[offset : offset + 512])
                            offset += 512
                            nblocks -= 1
                        return self.cmd_nodata(b'\x0c') # cmd 12
                    return 0
                def writeblocks(self, block_num, buf):
                    if nblocks == 1:
                        # CMD24: set write address for single block
                        if self.cmd(24, block_num * self.cdv, 0) != 0:
                            return 1
                        # send the data
                        self.write(_TOKEN_DATA, buf)
                        # CMD25: set write address for first block
                        if self.cmd(25, block_num * self.cdv, 0) != 0:
                            return 1
                        # send the data
                        offset = 0
                        while nblocks:
                            self.write(_TOKEN_CMD25, mv[offset : offset + 512])
                            offset += 512
                            nblocks -= 1
                        self.write_token(_TOKEN_STOP_TRAN)
                    return 0
            M N 2 Replies Last reply Reply Quote 1
              Thanks for your reply robert and I'll try working on it today and will post if anything crashes up and I have one more doubt regarding the WLAN access point. I have created an access point and I want to connect to my AP whenever the boot.py loads up. I can connect as a station but not as an access point i tried using this syntax but whenever it boots up it's looking for wlan AP but couldn't find it and goes to deep sleep mode. My network is up and it runs when I run it externally but not during boot up.
              from network import WLAN
              wlan.init(mode=WLAN.STA_AP,ssid='AP')
              wlan.init(ssid='AP',auth=(WLAN.WPA2,'xxxx'))
              print(wlan.ifconfig())
              Is the above syntax right?
                @manju2391 About WLAN: It could look like:
                wlan = WLAN(mode=WLAN.STA_AP)
                wlan.connect(ssid='AP',auth=(WLAN.WPA2, 'xxxx'))
                # from here on it's optional. It just takes a few moments to connect
                for _ in range (200):
                    if wlan.isconnected():
                        break
                        time.sleep_ms(50)
                    print("Could not connect")
                  I tried using SPI bus it is very slow. I had designed the pcb with spi pins but looks like it is not best so I’m just using the SDIO pins and changed the pcb. About the WLAN when I define wlan initially it is asking me for ap ssid at first I get an error saying ap ssid not given. I get the IP address when run locally and it connects to FileZilla but when it boots for the STA_AP it doesn’t print the IP address nor it connects to WLAN. It will be in idle state. I don’t know why it’s not connecting. I’m wondering should we create a station first and then an AP?
                  • N Offline
                    nathanh @robert-hh
                    @robert-hh said in External SD Card:
                        os.listdir('/sd2')
                    class SDCard:
                            self.spi = spi
                            self.cs = cs
                            self.init_card()
                            # init CS pin
                            for i in range(16):
                            for _ in range(5):
                                    break
                                self.init_card_v2()
                                self.init_card_v1()
                            csd = bytearray(16)
                            self.readinto(csd)
                                self.cmd(55, 0, 0)
                                    self.cdv = 512
                                    return
                                time.sleep_ms(50)
                                self.cmd(55, 0, 0)
                                    self.cdv = 1
                                    return
                            self.cs(0)
                            buf = self.cmdbuf
                            buf[0] = 0x40 | cmd
                            buf[1] = arg >> 24
                            buf[2] = arg >> 16
                            buf[3] = arg >> 8
                            buf[4] = arg
                            buf[5] = crc
                            self.spi.write(buf)
                                    if release:
                                        self.cs(1)
                                    return response
                            # timeout
                            self.cs(1)
                            return -1
                            self.spi.write(cmd)
                                    self.cs(1)
                                    return 0    # OK
                            self.cs(1)
                            return 1 # timeout
                            self.cs(0)
                                pass
                            # read data
                            # read checksum
                            self.cs(1)
                            self.cs(0)
                            self.spi.write(buf)
                                self.cs(1)
                                return
                                pass
                            self.cs(1)
                            self.cs(0)
                                pass
                            self.cs(1)
                        def count(self):
                            return self.sectors
                            if nblocks == 1:
                                    return 1
                                # receive the data
                                self.readinto(buf)
                                    return 1
                                offset = 0
                                while nblocks:
                                    offset += 512
                                    nblocks -= 1
                            return 0
                            if nblocks == 1:
                                    return 1
                                # send the data
                                    return 1
                                # send the data
                                offset = 0
                                while nblocks:
                                    offset += 512
                                    nblocks -= 1
                            return 0
                    I know this is a bit old but I just got an SD card module (https://www.sparkfun.com/products/13743) and was trying to get it working with my FiPy. I was running into a lot of issues but was able to make some headway using the library you pasted @robert-hh and thought I would share my results in case other people wanted to get it working.
                    However, I did have some errors with the library and had to make the following changes:
                    • The pins you used are not the default pins for the SPI init call. So I created my own SPI instance with the pin allocation you had in the post (since I already had them like that) and passed that instance into the SDCard constructor rather than machine.SPI(0). I also removed the additional spi init calls.
                    • I had to set the SPI baudrate to 1000000 instead of 100000
                    • I had to declare the CS pin as an instance outside of the library and pass it in similar to the SPI above.
                    • The command to check idle state at the start of the library self.cmd(0, 0, 0x95) would never return a value of 1. I don't know where the reference of these commands were but testing the other commands manually all returned values as expected. So I commented out the entire block that checks for the SD card or raises the 'no SD card' error. I found that I still need to run this command regardless, I get the same set of (4?) different values that repeat each time it is called. They never equal 1 but I let the code continue and command out the error block. Not calling the 0x95 command will not allow the next set of command to work correctly.
                    Doing the above I have gotten my external SD card board working fine with the FiPy. For reference below are my library and how I call it.
                        os.listdir('/sd2')
                    class SDCard:
                            self.spi = spi
                            self.cs = cs
                            self.init_card()
                            # init CS pin
                            #self.cs.init(self.cs.OUT, value=0)
                            for i in range(16):
                            for _ in range(5):
                                    break
                                self.init_card_v2()
                                self.init_card_v1()
                            csd = bytearray(16)
                            self.readinto(csd)
                                self.cmd(55, 0, 0)
                                    self.cdv = 512
                                    return
                                time.sleep_ms(50)
                                self.cmd(55, 0, 0)
                                    self.cdv = 1
                                    return
                            self.cs(0)
                            buf = self.cmdbuf
                            buf[0] = 0x40 | cmd
                            buf[1] = arg >> 24
                            buf[2] = arg >> 16
                            buf[3] = arg >> 8
                            buf[4] = arg
                            buf[5] = crc
                            self.spi.write(buf)
                                    if release:
                                        self.cs(1)
                                    return response
                            # timeout
                            self.cs(1)
                            return -1
                            self.spi.write(cmd)
                                    self.cs(1)
                                    return 0    # OK
                            self.cs(1)
                            return 1 # timeout
                            self.cs(0)
                                pass
                            # read data
                            # read checksum
                            self.cs(1)
                            self.cs(0)
                            self.spi.write(buf)
                                self.cs(1)
                                return
                                pass
                            self.cs(1)
                            self.cs(0)
                                pass
                            self.cs(1)
                        def count(self):
                            return self.sectors
                            if nblocks == 1:
                                    return 1
                                # receive the data
                                self.readinto(buf)
                                    return 1
                                offset = 0
                                while nblocks:
                                    offset += 512
                                    nblocks -= 1
                            return 0
                            if nblocks == 1:
                                    return 1
                                # send the data
                                    return 1
                                # send the data
                                offset = 0
                                while nblocks:
                                    offset += 512
                                    nblocks -= 1
                            return 0
                    from machine import SPI
                    from machine import Pin
                    spi = SPI(0, mode=SPI.MASTER, baudrate=1000000, polarity=0, phase=0, pins=('P10','P11','P12'))
                    cs = Pin('P9', Pin.OUT)
                    sd = sdcard.SDCard(spi, cs)
                    I could probably tidy up the library to initialise the SPI and CS properly internally but this got me going at least.
                    • E Offline
                      Edward Dimmack @jmarcelino
                      @jmarcelino Would this wiring work?
                        robert-hh @Edward Dimmack
                        @edward-dimmack That should work. I'm using this wiring on my homebrew interface boards.
                        • 2 / 2
