    no safe boot possible
    safe bootstuck
    21 Posts 5 Posters 1.7k Views 5 Watching
      devinv @robert-hh
      @robert-hh As I don't see the options you are talking about I'm not sure I'm using the right tool
      Following your link I used pycom_firmware_update_1.15.1.exe.zip
      There is no advanced section
      There is "Include developement releases", which I don't know if I need to tick or not (tryed both, same result)
      In the Communiction section I choose the PORT (COM6), the Speed (115200)
      I have the option 'erase flash file system' (which I ticked)
      Force update Lora region (I have a sipy, so I don't tick that right??)
      A 'flash from local file' option
      A type (pybytes, stable or development), which one do I have to choose?
      It asks for a pybytes activation token (no idea where I'm supposed to get that?). I can skip that part
      Then it instal 1.18.1.r7 [pybytes] and it mentions it is Sipy
      and it write after a few minutes : Your Sipy was successfully updated
      But then, nothing change I have the same
      flash read err, 1000 loop in Atom
        robert-hh @devinv
        @devinv You should install the stable version. But besides that all is fine. I use verison 1.15.2 of the updater. Links are here: https://forum.pycom.io/topic/3425/new-beta-firmware-updater-1-15-2-b0
        But firmware-wise the results are the same.
        As next step, try erasing with esptool.py & reflash. That is the crowbar style of reset and brings the device definitely back to the manufacturing state after assembly.
          devinv @robert-hh
          @robert-hh ok, I tryed this
          python esptool.py -p COM6 -b 460800 -c esp32 erase_flash
          esptool.py v2.0.1
          Got this
          esptool.py:2124: DeprecationWarning: inspect.getargspec() is deprecated since Python 3.0, use inspect.signature() or inspect.getfullargspec()
          operation_args,,,_ = inspect.getargspec(operation_func)
          then this for 30 seconds
          Connecting.....................................................
          (that takes 30 seconds...)
          and then
          A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
          Is there something else which has to be done before?
            robert-hh @devinv
            @devinv Oh yes. You have to connect P2 to GND and press reset, to go in boot mode.
            esptool.py does not support the PIC boot mode setting, it uses the espressif mode switch, which is sadly not supported by Pycom hardware.
            And there is a more recent version of esptool.py here: https://github.com/espressif/esptool/tree/4dab24e1b28632d270adf7305fe0d008d1acee99
              devinv @robert-hh
              @robert-hh Thank you so much. I'm back on track.
                devinv @robert-hh
                @robert-hh Is it possible that all what I did could create problem with my sipy sending messages to Sigfox?
                It doesn't work anymore.
                This was working before
                sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
                s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
                s.setblocking(True)
                s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
                But not anymore.
                No messages arrives to my sigfox account!?
                  robert-hh @devinv
                  @devinv Erasing flash erase all data, including any credentials that existed. But these will normally be restored when you do a firmware install through the Pycom updater. And that needs to work, because sometimes devices are in a state where only a full erase help.
                  But you may also ask Pycom service. Maybe Sigfox requires another configuration step.
                    devinv @robert-hh
                    @robert-hh Sorted. I just had desengage the sequence number on my sigfox account.
                      goldfishalpha
                      Just for the record, I had a similar issue with a LoPy on a Pysense board.
                      I foolishly got it stuck in a while loop. Pulling p12 high as per the official documentation could not get me back into REPL to reflash the file system, i.e
                      os.mkfs('/flash')
                      Reinstalling the firmware with the 'Erase flash file system' option checked worked the end.
                      Additional: This is not the first time that the official documentation has been wrong or incomplete.
                      Maybe an update of docs is in order?
                      robert-hhR M 2 Replies Last reply Reply Quote 0
                        robert-hh @goldfishalpha
                        @goldfishalpha Pulling P12 high and then pushing the reset button should activate safe boot, which does not execute boot.py and main.py on boot. That's almost the same as typing Ctrl-F at the REPL prompt.
                        G 1 Reply Last reply Reply Quote 1
                          Martinnn @goldfishalpha
                          @goldfishalpha Are you sure you have P12? As you have noted, documentation is pretty buggy and pinout description a mess. You might well have the wrong pin.
                            goldfishalpha @robert-hh
                            To qoute the docs directly, " After reset, if P12 pin is held high (i.e. connect it to the 3V3 output pin), the heartbeat LED will begin flashing orange slowly. If after 3 seconds the pin is still held high..." suggesting that the pin should be pulled high AFTER reset.
                            In fact I did get a flashing orange led, using this method.
                            My problem was that it appeared to reset once I released P12. I released P12 because I did not want to go to the prvious OTA firware and only wanted to disable boot.py and main.py.
                            @Martinn
                            I am sure that I have P12 (and not GPIO12 or '12') as I get the flashing led..
                            I haven't solved it yet. Just documenting for posterity.
                            F robert-hhR 2 Replies Last reply Reply Quote 0
                            • F Offline
                              ferfersan6 @goldfishalpha
                              @goldfishalpha
                              Did you solve it? Having the same problem on a Lopy 4.0. Thanks!!
                                @goldfishalpha If there is a time window where micropython is running, you could try to push Ctrl-F in a terminal window. That forces a safe boot. Ctrl-C may work too. This time slot is hard to catch, because typically you cannot connect a terminal when the device is in deepsleep. An indication for start would be an increase in power consumption. So if you have a USB dongle which shows that, if gives the trigger.
                                  goldfishalpha @ferfersan6
                                  @ferfersan6 Good intentions pave the way to hell and I had every intention to reply to this. I know this is WAY too late to reply this but may useful for any experiencing the same issues.
                                  If I remember correctly, I just held the pin high for as long as possible and went through the drudgery of reinstalling the proper firmware. Nothing sophisticated going on here! :)
