Documentation: pycom module 'machine'
Just trying to understand the reset conditions for the machine and noticed that the docs are incomplete in relation to reset causes.
When I runprint(machine.reset_cause())
I am returned an interger value. The list at Reset Causes does not have reset listed against their correspoding integer values AND there is no explanation of the the 'methods'; e.g. ismachine.HARD_RESET
correspond to bothmachine.reset()
and abutton push
?Thank you for your time
@goldfishalpha You're right! Sorry for the confusion and good catch (I'll edit my previous post so as not to confuse future readers)
@Colateral Thank you for your response. I am just thinking along the lines of logging reset reasons for my device.
e.g. If I get a WDT reset at a certain time, check and save the reason on restart of system. Would be handy for analysing software/system stability.
However, I have just noticed that a reset button press returns0
on amachine.reset_cause()
Will keep testing as I go along.
@alexpul Thank you. It appears as if counting starts from
0
though.
To confirm, I spotted that one can runhelp(machine)
to get a list..
PWRON_RESET -- 0
HARD_RESET -- 1
WDT_RESET -- 2
DEEPSLEEP_RESET -- 3
SOFT_RESET -- 4
BROWN_OUT_RESET -- 5
PWRON_WAKE -- 0
PIN_WAKE -- 1
RTC_WAKE -- 2
ULP_WAKE -- 3
machine.HARD_RESET never happens: nor at push button(POWER RESET) and never on machine.reset() (that actually is tided to WDT_RESET)
When this cause is happening?
If you do
then the numbers correspond to the reset causes list
0 - machine.PWRON_RESET
1 - machine.HARD_RESET
2 - machine.WDT_RESET
3 - machine.DEEPSLEEP_RESET
4 - machine.SOFT_RESET
5 - machine.BROWN_OUT_RESETIf you do
machine.wake_reason()
then the numbers correspond to the wake reasons list
0 - machine.PWRON_WAKE
1 - machine.PIN_WAKE
2 - machine.RTC_WAKE
3 - machine.ULP_WAKE
