Simple HTTP server
I repurposed some generic micropython HTTP server code to run on the gpy
import machine; from machine import Pin pins = [machine.Pin(i, machine.Pin.IN) for i in ('P23', 'P22', 'P21')] print (pins) html = """<!DOCTYPE html> <html> <head> <title>ESP8266 Pins</title> </head> <body> <h1>ESP8266 Pins</h1> <table border="1"> <tr><th>Pin</th><th>Value</th></tr> %s </table> </body> </html> """ import socket addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1] s = socket.socket() s.bind(addr) s.listen(1) print('listening on', addr) while True: cl, addr = s.accept() print('client connected from', addr) cl_file = cl.makefile('rwb', 0) while True: line = cl_file.readline() if not line or line == b'\r\n': break rows = ['<tr><td>%s</td><td>%d</td></tr>' % (str(p), p.value()) for p in pins] response = html % '\n'.join(rows) cl.send(response) cl.close()
It's supposed to show the status of the pins in a table but when I run it & try to login I get
[Pin('P23', mode=Pin.IN, pull=None, alt=-1), Pin('P22', mode=Pin.IN, pull=None, alt=-1), Pin('P21', mode=Pin.IN, pull=None, alt=-1)] listening on ('0.0.0.0', 80) client connected from ('192.168.4.2', 58649) Traceback (most recent call last): File "<stdin>", line 26, in <module> ValueError: invalid argument(s) value
I can't find any docs on makefile so I was wondering if anyone can tell me what the problem is with
Spot on with the cl.makefile('wb') Eric, although I can't tell how you figured that out from that doc page. No matter it works now! If I change 'import socket' to 'import usocket as socket' it runs the same so the pycom library must have both?
According to documentation (https://docs.pycom.io/firmwareapi/micropython/usocket.html) makefile seem have only one argument and not two. Logically i don't know any system where when you have write acces you haven't read access, so i propose you to try
cl_file = cl.makefile('wb')
Please note that's "import usocket" and not "import socket" as in your code with pycom library, if you use a different lib have a look at your provider's library documentation
