UDP sockets doesnt' work
There is some code example that implements WIFI-Direct using UDP?
Recevier
wlan =WLAN() Pin('P12', mode=Pin.OUT)(True) wlan.init(mode=WLAN.AP, ssid= Name, auth=(WLAN.WPA2,Pass), channel=1, antenna=WLAN.EXT_ANT) s = socket.socket(socket.AF_INET,socket.SOCK_DGRAM) #create socket server s.bind(('192.168.4.1',2000)) #bind s.settimeout(3) s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1) while True: try: data, address = sock.recvfrom(1024) print ("Received data from", address) print(data) ack = bytes("ACK",'utf-8') s.sendto(ack,('192.168.4.2', 58308)) #invia l'ack except OSError: return ("Timeout")Sender
Pin('P12', mode=Pin.OUT)(True) wlan = WLAN() wlan.init(mode = WLAN.STA, antenna = WLAN.EXT_ANT) #station wlan.ifconfig(config=('192.168.0.107', '255.255.255.0', '192.168.0.1', '192.168.0.1')) nets = wlan.scan() for net in nets: if net.ssid == ssid: print("Found network: " + net.ssid) wlan.connect(net.ssid, auth=(net.sec, password), timeout=5000) while not wlan.isconnected(): idle() # save energy if wlan.isconnected() == True: print('WLAN connection succeeded!') data = "Hello" s = socket.socket(socket.AF_INET,socket.SOCK_DGRAM) #crea socket server s.bind('192.168.0.107',58308) s.settimeout(3) s.sendto(data,('192.168.4.1',2000)) #send bytes print("Waiting for the data") while True: try: result, address = s.recvfrom(1024) print(address) if address == ('192.168.4.1',2000): print(result) return result else: return -1 except OSError: print ("Timeout") return "Timeout"But the sockets doesn't exchange data, what is wrong?
(obviously all the necessary modules have been imported) -
@p-m-97
For the sender, this should be enough for sending data (bind and timeout is not needed for UDP as far as I understood):UDP_IP = '192.168.4.1' UDP_PORT = 2000 MESSAGE = "Hello, World!".encode() s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) addr=(UDP_IP,UDP_PORT) s.sendto(MESSAGE,addr) -
I've added the timeout to make the recvfrom non-blocking.Moreover, all the operation does not depend by the s.bind() (for safety I tried to remove it anyway, and in fact it still doesn't work)
Other advice?Thank you
