    CAN SPI Device and I2C Device Co-Operate on one LoPy?
    16 Posts 5 Posters 5.3k Views 5 Watching
      rdixey @livius
      @livius Hi Livius. I am using a DVM (Digital Volt Meter) to measure the voltage as a simple test. (I don't have an oscilloscope) The power supply to LoPy is USB 3.0 (5V - 5Amp.) LoPy is mounted in the PyCom Expansion board. I'm using GND pin on the Exp Board jumpered to breadboard and Vin pin of exp board jumpered to breadboard for power to both I2C & SPI devices.
      I don't think there is an electrical/power problem. The I2C device works correctly by itself. The SPI device works correctly by itself. The problem is using them at the same time.
      My point for writing about the voltage level of the P10/G17 CLK/SCL signal is that the amplitude of the clock signal is dramatically different (millivolts vs volts) when SPI is initialized compared to when I2C is initialized. Observing that once initialized for SPI (mV range) I cannot reinitialize it back to I2C (V range) without hard reboot.
      Also when the SPI is initialized then I2C address becomes unavailable and I have only been able to recover the I2C address through hard reboot. This does not seem to be an intended functionality.
      My Question is: Is this is a setting issue, a command issue or a bug?
      Also according to the LoPy pinout diagrams, the P10/G17 CLK/SCL is the ONLY configured signal available for clock of I2C & SPI. I am trying to use both and not succeeding.
      My Question is: Does the LoPy only support either I2C OR SPI but NOT BOTH together?
        jmarcelino @rdixey
        @rdixey said in CAN SPI Device and I2C Device Co-Operate on one LoPy?:
        Vin is at 5V (connected directly to USB) so your I2C and SPI devices are being powered by 5V and probably signalling at 5V as well - for example if I2C bus is also connected to those 5V via the pull-up resistors.
        This would explain the high voltages you're seeing - and if so you're probably damaging the LoPy.
        L R 2 Replies Last reply Reply Quote 1
          livius @jmarcelino
          @jmarcelino
          ach - if he use the same power from VIN
          not from 3V3 pin that he has a problem
            rdixey @jmarcelino
            @jmarcelino Hi I appreciate your advice. The devices I'm using are breakouts made by Adafruit.
            Light Sensor: https://www.adafruit.com/products/1980 # I2C Only.
            OLED: https://www.adafruit.com/products/938 #Using as SPI by Default but can be configured for I2C.
            Both can accept 5V or 3.3V as VIN. They both have onboard regulators providing 3.3v to the signal pins, and have onboard level shifting. According to their datasheets the I2C bus have onboard pullups installed for SDA/SLC. So I thought that powering as I was doing was valid.
            None the less, your comment about damaging the LoPy made me quickly change to using the LoPy regulated 3.3V pin to power VIN of both devices. Now redoing my same voltage check as before with P10/G17 CLK/SCL signal jumpered to both devices there is 3.284V with clock at Idle making it compatible with LoPy.
            Unfortunately this did not resolve the original problem of my post. The SPI OLED Display works correctly individually. The I2C Light Sensor works correctly individually. But when the SPI is initialized then I2C address becomes unavailable and I have only been able to recover the I2C address through hard reboot.
            • Can you not map the CLK line of either SPI or I2C to a different - separate - pin? I haven't tried it but seems to be one of the initialization options.
            No i did not try to map another pin as SCL yet since I have no docs to refer to as guide. As a test I did try using P5/G12 for the SPI OLED CLK (used by LoRa) and keeping P10/G17 I2C SCL for Light Sensor. I got the same result as stated in my problem. I did not keep it this way since I want to avoid sharing bus / contention with LoRa since this is the key use of a LoPy.
            I am coming to the conclusion that LoPy can support either SPI devices or I2C devices but NOT both. Hoping someone from PyCom will provide comment to the users about the intended designed functionality in this regard.
            J B 2 Replies Last reply Reply Quote 0
              rdixey @livius
              @livius Hi Livius.....per your advice I switched to using the LoPy regulated 3V3 to VIN of my SPI and I2C devices. Doing this reduced the P10/G17 CLK/SCL to 3.284V with clock at idle make it compatible with LoPy. Thanks for starting the discussion on this.
              Unfortunately this did NOT resolve the original problem of my post. The SPI OLED Display works correctly individually. The I2C Light Sensor works correctly individually. But when the SPI is initialized then I2C address becomes unavailable and I have only been able to recover the I2C address through hard reboot.
              Otherwise I may give up on this adventure and reconfigure the SPI OlED as an I2C device to avoid the problem.
                livius @rdixey
                @rdixey
                Good - now you have ok voltage :)
                Will be good to see your connections, unfortunately i have not SPI device.
                All my devices are I2C, digital or analog - and i can not test this myself.
                But as @jmarcelino i do not suppose that this is good idea to share same clock between I2C and SPI. I suppose you should use alternate function.
                But if you show us the wire then maybe we will see something obvious.
                As you say all your devices have builtin pullup then:
                What is voltage when you plug sensor and display?
                • When you only power it up on data lines.
                • And when you start communication?
                  I know that without oscilloscope this is hard.
                Will be good if someone with both SPI and I2C devices can join to discussion
                or especially pycom @administrators to show us if you can share that clock.
                  jmarcelino @rdixey
                  @rdixey
                  Excellent, you have the voltages under control now!
                  I read on the documentation that you set the pins like this:
                  i2c.init(mode, *, baudrate=100000, pins=(SDA, SCL))
                  pins is an optional tuple with the pins to assign to the I2C bus. The default I2C pins are P9 (SDA) and P10 (SCL)
                  and actually just tried it myself by moving the I2C CLK pin to P8
                  i2c = I2C(0, I2C.MASTER, baudrate=100000,pins=("P9", "P8"))
                  and happy to report this worked perfectly. Testing with a DS3231 RTC clock over I2C the CLK was now P8.
                  So please try to move the I2C CLK somewhere else (maybe P8 as in my example above) and see if works for you.
                  L R 2 Replies Last reply Reply Quote 3
                    livius @jmarcelino
                    @jmarcelino said in CAN SPI Device and I2C Device Co-Operate on one LoPy?:
                    Thank you for tests because i am also interested for future develop.
                    An you confirm our thoughts about need to alternate function.
                      rdixey @jmarcelino
                      @jmarcelino Defining the separate I2C SCL at P8 resolved the problem. With using separate clocks the I2C device address is still available after initializing the SPI Bus.
                      So the solution to my post is that I2C and SPI devices CAN both operate on a LoPy however they cannot share the clock signal generated from the default CLK/SCL P10 / Exp G17 signal. There must be a separate clock established for both the SPI bus and the I2C bus.
                      I'm moving forward thanks to your and Livius help.
                      For comparison to my original post.
                      >>> i2c = I2C(0, I2C.MASTER, baudrate=100000,pins=("P9", "P8"))      #I2C initialized
                      >>> i2c.scan()
                      [40]
                      >>> import tsl2591
                      >>> tsl = tsl2591.Tsl2591(28)
                      >>> full, ir = tsl.get_full_luminosity()
                      >>> print(full, ir)
                      141 63
                      >>> i2c.scan()
                      [40]
                      >>> spi = SPI(0, mode=SPI.MASTER, baudrate=100000, polarity=0, phase=0)      #SPI initialized
                      >>> i2c.scan()                 #I2C address still available and bytes read from it.
                      [40]
                      >>> print(full, ir)
                      18 10
                        This is not the case, but I see that:
                        I'm glad that you were able to find the solution :-)
                        I jumper the P10/G17 pin to share the clock with the SPI and I2C. Is that a valid use case?
                        No, this is not a good idea and it's never going to work. You need to use separate pins for both serial buses.
                        That's correct.
                          barsznica @rdixey
                          @rdixey
                          If you didn't need the speed of SPI, then you could have used I2C (IIC) for both devices (as long as they different addresses), as IIC supports 127 (from memory) device addresses.
                          "OLED: https://www.adafruit.com/products/938 #Using as SPI by Default but can be configured for I2C.", rdixey
