    Open source Licence
    27 Posts 9 Posters 17.2k Views 9 Watching
      livius
      this should be in documentation. Reading script file is bad way for starters ;-)
      but now it is clear
      curl with these specific options is used as a command line ftp client
      ah i see, he only copy image file throught ftp
      i did not read whole line carefully - but it was so simple
      when i saw curl i have stoped reading ;-)
        livius
        thank you for help
        i now have make WIPI bin file
        and i am ready to make some pull requests :)
          brotherdust @LoneTech
          @LoneTech Thanks for the instructions. I was able to successfully build on my Windows 10 box using Bash on Ubuntu on Windows. =) heh.
            brotherdust @brotherdust
            @brotherdust said in Open source Licence:
            So, yeah. It might have built successfully, but I can't get the LoPy to take it. Argh. Here's the CLI output:
            $ curl --disable-epsv --ftp-pasv -T "build/LOPY/release/appimg.bin" ftp://micro:python@10.192.5.64//flash/sys/appimg.bin
              % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                             Dload  Upload   Total   Spent    Left  Speed
             31  819k    0     0   31  256k      0   530k  0:00:01 --:--:--  0:00:01  534k
            curl: (55) Send failure: Broken pipe
            I think it's because the firmware file is too big. The one I compiled is ~820KB, but the official releases are weighing in around ~631KB. Is it possible this is the cause?
              LoneTech @brotherdust
              @brotherdust Unlikely; the firmware partitions are 1M large, and your transfer stopped at 256k. OTA updating isn't quite 100% for me; not sure if that readonly flash bug is reoccurring or what, but doing a serial download tends to clear it. Also, on the firmware versions with the watchdog bug OTA almost always triggers that.
              • N Offline
                nickparrin @LoneTech
                Keep getting an error like this:
                developer@developer:~/esp32/pycom-micropython/esp32$ make BOARD=LOPY LORA_BAND=USE_BAND_868
                LINK build/LOPY/release/bootloader/bootloader.elf
                xtensa-esp32-elf-gcc -nostdlib -Wl,-Map=build/LOPY/release/bootloader/bootloader.map -Wl,--no-check-sections -u call_user_start_cpu0 -Wl,-static -Wl,--undefined=uxTopUsedPriority -Wl,--gc-sections -T esp32.bootloader.ld -T esp32.rom.ld -T esp32.peripherals.ld -Wl,--start-group -Llib -L/home/developer/esp32/pycom-esp-idf/components/esp32/ld -Lbuild/LOPY/release/bootloader -L/home/developer/esp32/pycom-esp-idf/components/esp32/lib -Lbootloader -llog -lcore -lspi_flash build/LOPY/release/bootloader/bootloader.a -Wl,--end-group -Wl,-EL -o build/LOPY/release/bootloader/bootloader.elf
                /home/developer/esp32/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/4.8.5/../../../../xtensa-esp32-elf/bin/ld: cannot find -lcore
                collect2: error: ld returned 1 exit status
                application.mk:274: recipe for target 'build/LOPY/release/bootloader/bootloader.elf' failed
                make: *** [build/LOPY/release/bootloader/bootloader.elf] Error 1
                I set the IDF_PATH and added gcc to PATH. Tried with the ln command, and without by editing the Makefile directly
                EDiT: fixed it thanks to daniel. I missed to import (inside pycom idf) the needed compontents:
                • git submodule update --init
                  livius
                  Will be good to see port of this
                  https://github.com/micropython/micropython/pull/2091/files
                  and also enable time_us() which is currently commented out in the code
                  but i suppose it is limited by some esp32 IDF? and because of this is commented out?
                  https://github.com/pycom/pycom-micropython/blob/master/esp32/mods/modutime.c
                    @livius yes, machine.time_pulse_us() is very useful and we will implement it for the ESP32. A number of function in the time module are incomplete due to previous limitations of the IDF. The plan is to get back to that and implement them in early January.
                      livius @daniel
                      @daniel
                      thank you for the info - especially about time frame
                        livius
                        @daniel
                        Can i ask what is IRAM_ATTR in functions declaration?
                          @livius that's needed in order to place functions inside the instruction RAM of the ESP32. Otherwise they will reside in flash, which means that they need to be fetched from the SPI flash everytime there's a cache miss. Time critical functions must be placed inside IRAM, as well as interrupt handlers.
                            livius @daniel
                            @daniel
                            Thank you very much :)
                            I still analyze repo (and learn C which is not my language) and need to understand internals until i change something on my side.
                              livius
                              We have correlation between
                              and
                              https://github.com/pycom/pycom-esp-idf
                              will be good when you send update to new version
                              e.g. 1.3.0.b1 do the same in pycom-esp-idf
                              because i do not know now how to revert firmware to older version.
                              I can simply download pycom-micropython at certain firmware version(commit)
                              but do not know how do this in correlation with esp-idf (do not know which commit)
                                @livius I was almost sure that we also pushed to Github the latest pycom-esp-idf, but it seems we didn't. That is corrected now and everything us up to date. Thanks for pointing it out.
                                  livius @daniel
                                  @daniel
                                  but i do not talk about this
                                  only when you commit to pycom-esp-idf
                                  add comment or some file as "version" and write there same string as is for pycom-micropython e.g. `1.3.0.b1'
                                  we then can back in commits and download esp-idf and pycom in the same version (older)
                                  but thank you for the update
                                    @livius good point, we'll start tagging it like this from now on. Thanks!
                                      beyonlo @Fred
                                      I am pleased to confirm that the firmware of Pycom modules is now Open source and can be found here https://github.com/pycom/pycom-micropython
                                      I remember to read in the past a topic in the "Announcements & News" about that PyCom and Micropython (Damien George) will work together on ESP32 port. Well, I would like to know some things:
                                      1. Where are there this topic? Anyone can past me the URL?
                                      2. Is this https://github.com/micropython/micropython-esp32 the official address to MicroPython to ESP32 where PyCom and Damien are working together?
                                      3. I remember (via that announcement) that PyCom will be to commit the source code ESP32 project directally to official port (address above), is that happen? Because I checked today that last commit was done more than a month ago and less than a month PyCom released a new firmware with modifications on the MicroPython.
                                      Thank you.
