    PWM signal to one pin instead of all
    2 Posts 2 Posters 200 Views 2 Watching
      Dezert754
      So Im trying to understand if all the pins are directly connected to a single PWM? In my case I'm using a WiPy, when I run my code all my pins seem to get that signal as I have multiple servos moving, however im specifying a single pin to get the PWM signal.
      Im only calling one function at a time.
      def shelfServoOpenA():
          pwm = machine.PWM(0, frequency=50)
          pwm_ca = pwm.channel(0, pin='P23', duty_cycle=0.02)
          time.sleep(2)
          print("A Going to 60")
          pwm_ca.duty_cycle(0.2450)
      def shelfServoCloseA():
          time.sleep(2)
          print("A Going to 0")
          pwm_ca.duty_cycle(0.0450)
      def shelfServoOpenB():
          pwm_cb = pwm.channel(0, pin='P22', duty_cycle=0.02)
          time.sleep(2)
          print("B Going to 60")
          pwm_cb.duty_cycle(0.2450)
      def shelfServoCloseB():
          time.sleep(2)
          print("B Going to 0")
          pwm_cb.duty_cycle(0.0450)
        jcaron @Dezert754
        @Dezert754 you probably want to use different timers (the first argument to machine.PWM) and/or different channels (the first argument to pwm.channel). Probably the latter rather the former.
        You can also probably avoid instantiating / configuring each time you need to do something.
