    WEB Server
    29 Posts 11 Posters 12.6k Views 11 Watching
    • pierrot10P Offline
      pierrot10 @jczic
      @jczic :o), what do you meen by
      You want to make a captive portal ?
      I would like to display basic information about my node. Because my Lopy4 is LoRa Node. So when the owner is close to the node, he connect to the SSID and he got basic information. But for that I have to write the index.html page with those basic information. In order to make it simple for the user, when he is connected to the SSID, his smartphone browser open and display the info without an additionnal action from the user, excepted to be connected to the SSID.
      Thank for the link microDNSSrv.py.
      I will look at this, for sure
        jczic @pierrot10
        @pierrot10 Okay yes, I see.
        But at the moment, this is not possible with MicroDNSSrv. I must to add special domaine name like "apple" etc... to automatically open a popup window on smartphones and computers who connects to Wi-Fi AP.
        But now, you must to start MicroDNSSrv to resolve names ...
        You can open a browser and type a domain name (or catch * wildcards domains).
        JC`zic
          jczic @pierrot10
          @pierrot10 Sorry pierrot but that works (I have just tested) :)
          You must to configure MicroDNSServer to respond to all domains with your IP :
          from microDNSSrv import MicroDNSSrv
          srv = MicroDNSSrv.Create( {
          	"*"   : "192.168.4.1" } )
          and you must to configure MicroWebSrv with a redirection on a "not found" page :
          srv.SetNotFoundPageUrl('my-captive-portal.mydevice.com')
          If you want to change the default IP and configuration, try this complet code in main.py :
          from microWebSrv import MicroWebSrv
          def _httpHandlerTestGet(httpClient, httpResponse) :
          	content = """\
          	<!DOCTYPE html>
          	<html lang=fr>
                  <head>
                  	<meta charset="UTF-8" />
                      <title>TEST GET</title>
                  </head>
                  <body>
                      <h1>TEST GET</h1>
                      Client IP address = %s
                      <br />
          			<form action="/test" method="post" accept-charset="ISO-8859-1">
          				First name: <input type="text" name="firstname"><br />
          				Last name: <input type="text" name="lastname"><br />
          				<input type="submit" value="Submit">
          			</form>
                  </body>
              </html>
          	""" % httpClient.GetIPAddr()
          	httpResponse.WriteResponseOk( headers		 = None,
          								  contentType	 = "text/html",
          								  contentCharset = "UTF-8",
          								  content 		 = content )
          def _httpHandlerTestPost(httpClient, httpResponse) :
          	formData  = httpClient.ReadRequestPostedFormData()
          	firstname = formData["firstname"]
          	lastname  = formData["lastname"]
          	content   = """\
          	<!DOCTYPE html>
          	<html lang=fr>
          		<head>
                      <title>TEST POST</title>
                  </head>
                  <body>
                      <h1>TEST POST</h1>
                      Firstname = %s<br />
                      Lastname = %s<br />
                  </body>
              </html>
          	""" % ( MicroWebSrv.HTMLEscape(firstname),
          		    MicroWebSrv.HTMLEscape(lastname) )
          								  content 		 = content )
          def _acceptWebSocketCallback(webSocket, httpClient) :
          	print("WS ACCEPT")
          	webSocket.RecvTextCallback   = _recvTextCallback
          	webSocket.RecvBinaryCallback = _recvBinaryCallback
          	webSocket.ClosedCallback 	 = _closedCallback
          def _recvTextCallback(webSocket, msg) :
          	print("WS RECV TEXT : %s" % msg)
          	webSocket.SendText("Reply for %s" % msg)
          def _recvBinaryCallback(webSocket, data) :
          	print("WS RECV DATA : %s" % data)
          def _closedCallback(webSocket) :
          	print("WS CLOSED")
          routeHandlers = [
          	( "/test",	"GET",	_httpHandlerTestGet ),
          	( "/test",	"POST",	_httpHandlerTestPost )
          from network import WLAN
          wlan = WLAN();
          wlan.init(mode=WLAN.AP, ssid='MYDEVICE WIFI', auth=(WLAN.WPA2, 'azerty123'))
          wlan.ifconfig( id     = 1,
                         config = ('10.0.0.254', '255.255.255.0', '10.0.0.254', '10.0.0.254' ) )
          srv = MicroWebSrv(routeHandlers=routeHandlers)
          srv.MaxWebSocketRecvLen     = 256
          srv.WebSocketThreaded		= False
          srv.AcceptWebSocketCallback = _acceptWebSocketCallback
          srv.Start()
          	"*"   : "10.0.0.254" } )
          Just connect your computer or smartphone to wifi MYDEVICE WIFI with pass azerty123 and a captive popup will be opened on your main page :)
          JC`zic
          pierrot10P 2 Replies Last reply Reply Quote 2
            pierrot10 @jczic
            @jczic That great!!!! Thank, I will try it later!!!!! Thank
              pierrot10 @jczic
              @jczic Hello!! Thank a lot for this example. That help but I can not make it working at 100%
              When I connect to my WIFI (with my smartphone) it does not open a browser with the page. But it's not critical. If I can do it , it's great, if not, the user can be connect to the SSID and then open a broser but it would be necessary that all request into the browser (any URL) foward to the 192.168.4.1 web page.
              However, when I enter the url www.nothin.fr (or something else), the content of 192.168.4.1 is display.
              I observed when I enter www.google.ch, it does display the content of 192.168.4.1. It display an error page not found.
              I observed that all https reuqest display a not page found, and it look like id only the http request display the 192.168.4.1 content.
              Can it be possible?
              I also could configure an new iP for my AP.
              that work when I enter 10.0.0.254 in my browser.
              However, the srv.SetNotFoundPageUrl
              never display a page. But I do not understand the URL you gave.
              Does mydevise.com is the name of my poly4 devise?
              If yes how can I set the name of my devise
              Or should I change it with (or with an URL of my web site to see a result)?
              srv.SetNotFoundPageUrl('map.google.com')
              Should it be an external web site or a page of my LoPy devise like /test.
              Last question :o).
              Is
              _httpHandlerTestPost and _httpHandlerTestGet necessary in that exercice?
              or should I use to create some additional page like
              routeHandlers = [
              	( "/sensors",	"GET",	_httpHandlerTestGet ),
              	( "/configure",	"POST",	_httpHandlerTestPost )
              Last last question.
              I saw in your github, the boot.py as this code
              from    os      import dupterm
              from    machine import UART
              uart = UART(0, 115200)
              dupterm(uart)
              I have o copied it and my boo.py is empty.
              Is an error from me?
              What does the boot.py code exactely?
              Thank fro your support and your great help, it help and help me to learn as well!!!!!
              Pierrot
                jczic @pierrot10
                @pierrot10 Okay, you must to configure the IP interface else LoPy wifi set the DNS server tout 0.0.0.0.
                Set the configuration IP with the same IP addr for the DNS.
                After, you must to use MicroDNSSrv tout catch all names to the same IP { "*" : "10.0.0.254" }.
                All web requests will be directed tout this IP.
                Thé MicroWebSrv have not page for "www.a-test.com" for exemple.
                You must set your default page URL if a page IS not round.
                boot.py is just the first "launched" file and it can configure the terminal to the serial UART input/output.
                JC`zic
                pierrot10P 1 Reply Last reply Reply Quote 0
                  pierrot10 @jczic
                  @jczic Hello, Thank for your reply. I was concentrated on creating a nice web page with jquery mobile, but .... (laugh), lopy did not have enough space to store the library :o) :o).
                  I created a very smaller nice welcome web page.
                  However, if I wrote this is to say, after I modified the default index.html, the popup windows appear after the WiFi connection. So that finally work,
                  What you lastly wrote, we are agree is to have any url request redirect to the index.html?
                  I tried
                  fconfig( id     = 1,
                                 config = ('0.0.0.0', '255.255.255.0', '10.0.0.254', '0.0.0.0' ) ) # (ip, subnet_mask, gateway, DNS_server)
                  It's look not working. It ask me to enter again the WiFi password but it does not accept it. Any way, it's not so important. Ir would nice that if I enter only 'localhost' the my smartphone browser, or any caracter, it forward to index.html. but it take too much of your time I can leave
                                 config = ('10.0.0.254', '255.255.255.0', '10.0.0.254', '10.0.0.254' ) ) # (ip, subnet_mask, gateway, DNS_server)
                  :o)
                  I also changed to
                  srv.SetNotFoundPageUrl('index.html')
                  in that way, all "notFoundPage is redirected to the index.
                  • E Offline
                    Eric Waai
                    i somehow just son't get this to work on a fipy.
                    i tried using the code given here with the microwebserver but i don't get a browser to display anything.
                    i think the fipy should put data on the uart and i don't get anything there either.
                    any ideas?
                    this is the code i have in main.py
                    	content = """\
                    	<!DOCTYPE html>
                    	<html lang=en>
                            <head>
                            </head>
                            <body>
                                <h1>TEST GET</h1>
                                <br />
                    			</form>
                            </body>
                        </html>
                    								  content 		 = content )
                    	content   = """\
                    	<!DOCTYPE html>
                    	<html lang=en>
                    		<head>
                            </head>
                            <body>
                                <h1>TEST POST</h1>
                                Lastname = %s<br />
                            </body>
                        </html>
                    								  content 		 = content )
                    	print("WS ACCEPT")
                    	print("WS CLOSED")
                    routeHandlers = [
                    wlan = WLAN();
                    wlan.init(mode=WLAN.AP, ssid='fipy test', auth=(WLAN.WPA2, 'qwerty123'))
                                   config = ('10.0.0.10', '255.255.255.0', '10.0.0.254', '10.0.0.254' ) )
                    srv.WebSocketThreaded		= True
                    srv.Start(threaded=True)
                    print("Done")
                      tealbrains @Eric Waai
                      @eric-waai Apparently the pycom boards do not have enough memory to run it. I contacted @jczic and that was his reply.
                      @pierrot10 , if you are still around, what board did you use?
                      I am looking for a solution where the pycom board (Lopy4 in my case) would be set as an AP, display a form via a webapp to let the user update some parameters.
                      I have seen solutions that work on other ESP32 boards.
                      Any help would be good. Setting the device as AP is a nice thing to have, but some examples on how to use this functionality would be handy.
                        troy salt @tealbrains
                        @tealbrains Any progress here? I also want to implement the same idea of a form via a webapp for parameter updates.
                        • W Offline
                          westernira
                          What's that? I am here to find the answer about the web server.I found some data related to login into web servers tools 192.168.0.50, but i still need to read a lot of information from it.You can refer that for help.
                            robert-hh @westernira
                            @westernira There are a few tiny web servers around, like this one: https://github.com/pfalcon/picoweb, which is made for a micropython environment. It should not be so difficult to use it on a Pycom device.
                              jczic
                              I released a fully new version (v2.0) of my web server here : https://github.com/jczic/MicroWebSrv2.
                              Open source MIT, fully asynchronous, more robust, more fast and more efficient on Pycom modules.
                              It is delivered with a good documentation.
                              Thank you for your support and feedback. ☺️
                              JC`zic
                              • 2 / 2
