how to check if a non-existing key in nvs ?
How can I check if a key value pair dict is saved in NVS?
def car_count(): if pycom.nvs_get('count'): pycom.nvs_set('count', (pycom.nvs_get('count')+1)) print('{} cars have passed so far this period'.format(pycom.nvs_get('count'))) else:#needed following initial start up pycom.nvs_set('count', 1) print('first car passed this way')according to the docs if a non-existing key is given the returned value will be None. However I get an error
ValueError: No matching object for the provided key -
You have to check if it is None or not, change to:
if pycom.nvs_get("count") != None:
it returns the same error
@philwilkinson Any reference to a line? I just tried your code and it works fine for me.
I was just using the REPL and it returned the error when I called nvs_get('count').
@philwilkinson No problem when I try, are you using an old firmware?
It is a bug. I have raised issue #306 on Github
On the latest firmware
Pycom MicroPython 1.18.2.r7 [v1.8.6-849-df9f237] on 2019-05-14; LoPy4 with ESP32>>> import pycom >>> pycom.nvs_get('anything')==None ValueError: No matching object for the provided keyso I used a previous version of the firmware
Pycom MicroPython 1.18.2.r2 [v1.8.6-849-5cf02dc] on 2019-03-07; LoPy4 with ESP32>>>import pycom >>>pycom.nvs_get('anything')==None True >>> -
This post is deleted! -
@johand said in how to check if a non-existing key in nvs ?:
Are you sure that will work? An exception is an exception and "pycom.nvs_get("count")" would not return anything to compare with. The exception would be generated before the compare can be executed.
@PeterB said in how to check if a non-existing key in nvs ?:
Depends on the version. This must have changed over time.
You can simply use a variable and wrap the call, so that it shall run on all versions:try: _wake = pycom.nvs_get('wake'); except Exception as e: _wake = None if _wake==None: _wake = 103 -
@crumble I just ran into this today. Yes, I agree you can wrap the call and catch the exception - however, the current documentation states "If a non-existing key is given the returned value will be None." (See: https://docs.pycom.io/firmwareapi/pycom/pycom/). The general catching of unknown exceptions isn't good practice. While I think your workaround is sound, I'd upvote this as a bug that needs to be fixed.
in our code we use a such function to read memory:
def memory_get(name='MIR', default_value=1): ''' Retourne une valeur par défaut si la mémoire NVS ne contient pas l'élément recherché ''' try: _value = pycom.nvs_get(name) except Exception: _value = None if _value is None: _value = default_value return _valueI'm not sure if that is the python way, but maybe that can help you!
import pycom the_value = pycom.nvs_get('the_key',None) if the_value: print(the_value)
