    OTAA Node to Nano Gateway AU915
    3 Posts 2 Posters 388 Views 2 Watching
    • Y Offline
      Yendor
      I just recently got a couple of Lopy 4's to act as nodes, but while I wait for my gateway, I was trying to set the pair up in a LoraWan nano gateway and OTAA node test.
      I’m using the GitHub code for a base https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway and trying to modify it for use in Australia AU915.
      I think I got the gateway working but it never shows connected in the TNN console.
      config.py
      #!/usr/bin/env python
      # Copyright (c) 2019, Pycom Limited.
      # This software is licensed under the GNU GPL version 3 or any
      # later version, with permitted additional terms. For more information
      # see the Pycom Licence v1.0 document supplied with this file, or
      # available at https://www.pycom.io/opensource/licensing
      """ LoPy LoRaWAN Nano Gateway configuration options """
      import ubinascii
      WIFI_MAC = ubinascii.hexlify(machine.unique_id()).upper()
      # Set  the Gateway ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address
      GATEWAY_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12]
      SERVER = 'router.thethings.meshed.com.au'
      PORT = 1700
      NTP = "pool.ntp.org"
      NTP_PERIOD_S = 3600
      WIFI_SSID = 'ssid'
      WIFI_PASS = 'password'
      WIFI_ADDRESS = '192.168.1.50'
      WIFI_MASK = '255.255.255.0'
      WIFI_GATEWAY = '192.168.1.1'
      # for EU868
      # LORA_FREQUENCY = 868100000
      # LORA_GW_DR = "SF7BW125" # DR_5
      # LORA_NODE_DR = 5
      # for US915
      # LORA_FREQUENCY = 903900000
      # LORA_GW_DR = "SF7BW125" # DR_3
      # LORA_NODE_DR = 3
      # for AU915
      LORA_FREQUENCY = 916800000
      LORA_NODE_DR = 4
      nanogateway.py
      """ LoPy LoRaWAN Nano Gateway. Can be used for both EU868 and US915. """
      import errno
      import ubinascii
      import ujson
      import uos
      import usocket
      import utime
      import _thread
      from micropython import const
      from network import LoRa
      from network import WLAN
      from machine import Timer
      PROTOCOL_VERSION = const(2)
      PUSH_DATA = const(0)
      PUSH_ACK = const(1)
      PULL_DATA = const(2)
      PULL_ACK = const(4)
      PULL_RESP = const(3)
      TX_ERR_NONE = 'NONE'
      TX_ERR_TOO_LATE = 'TOO_LATE'
      TX_ERR_TOO_EARLY = 'TOO_EARLY'
      TX_ERR_COLLISION_PACKET = 'COLLISION_PACKET'
      TX_ERR_COLLISION_BEACON = 'COLLISION_BEACON'
      TX_ERR_TX_FREQ = 'TX_FREQ'
      TX_ERR_TX_POWER = 'TX_POWER'
      TX_ERR_GPS_UNLOCKED = 'GPS_UNLOCKED'
      UDP_THREAD_CYCLE_MS = const(20)
      STAT_PK = {
          'stat': {
              'time': '',
              'lati': 0,
              'long': 0,
              'alti': 0,
              'rxnb': 0,
              'rxok': 0,
              'rxfw': 0,
              'ackr': 100.0,
              'dwnb': 0,
              'txnb': 0
      RX_PK = {
          'rxpk': [{
              'time': '',
              'tmst': 0,
              'chan': 0,
              'rfch': 0,
              'freq': 0,
              'stat': 1,
              'modu': 'LORA',
              'datr': '',
              'codr': '4/5',
              'rssi': 0,
              'lsnr': 0,
              'size': 0,
              'data': ''
      TX_ACK_PK = {
          'txpk_ack': {
              'error': ''
      class NanoGateway:
          Nano gateway class, set up by default for use with TTN, but can be configured
          for any other network supporting the Semtech Packet Forwarder.
          Only required configuration is wifi_ssid and wifi_password which are used for
          connecting to the Internet.
          def __init__(self, id, frequency, datarate, ssid, password, address, mask, gateway, server, port, ntp_server='pool.ntp.org', ntp_period=3600):
              self.id = id
              self.server = server
              self.port = port
              self.frequency = frequency
              self.datarate = datarate
              self.ssid = ssid
              self.password = password
              self.address = address
              self.mask = mask
              self.gateway = gateway
              self.ntp_server = ntp_server
              self.ntp_period = ntp_period
              self.server_ip = None
              self.rxnb = 0
              self.rxok = 0
              self.rxfw = 0
              self.dwnb = 0
              self.txnb = 0
              self.sf = self._dr_to_sf(self.datarate)
              self.bw = self._dr_to_bw(self.datarate)
              self.stat_alarm = None
              self.pull_alarm = None
              self.uplink_alarm = None
              self.wlan = None
              self.sock = None
              self.udp_stop = False
              self.udp_lock = _thread.allocate_lock()
              self.lora = None
              self.lora_sock = None
              self.rtc = machine.RTC()
          def start(self):
              Starts the LoRaWAN nano gateway.
              self._log('Starting LoRaWAN nano gateway with id: {}', self.id)
              # setup WiFi as a station and connect
              self.wlan = WLAN(mode=WLAN.STA)
              self.wlan.ifconfig(config=(self.address, self.mask, self.gateway, self.gateway))
              self._connect_to_wifi()
              # get a time sync
              self._log('Syncing time with {} ...', self.ntp_server)
              self.rtc.ntp_sync(self.ntp_server, update_period=self.ntp_period)
              while not self.rtc.synced():
                  utime.sleep_ms(50)
              self._log("RTC NTP sync complete")
              # get the server IP and create an UDP socket
              self.server_ip = usocket.getaddrinfo(self.server, self.port)[0][-1]
              self._log('Opening UDP socket to {} ({}) port {}...', self.server, self.server_ip[0], self.server_ip[1])
              self.sock = usocket.socket(usocket.AF_INET, usocket.SOCK_DGRAM, usocket.IPPROTO_UDP)
              self.sock.setsockopt(usocket.SOL_SOCKET, usocket.SO_REUSEADDR, 1)
              self.sock.setblocking(False)
              # push the first time immediatelly
              self._push_data(self._make_stat_packet())
              # create the alarms
              self.stat_alarm = Timer.Alarm(handler=lambda t: self._push_data(self._make_stat_packet()), s=60, periodic=True)
              self.pull_alarm = Timer.Alarm(handler=lambda u: self._pull_data(), s=25, periodic=True)
              # start the UDP receive thread
              _thread.start_new_thread(self._udp_thread, ())
              # initialize the LoRa radio in LORA mode
              self._log('Setting up the LoRa radio at {} Mhz using {}', self._freq_to_float(self.frequency), self.datarate)
              self.lora = LoRa(
                  mode=LoRa.LORAWAN,
                  frequency=self.frequency,
                  bandwidth=self.bw,
                  sf=self.sf,
                  preamble=8,
                  coding_rate=LoRa.CODING_4_5,
                  tx_iq=True
              # create a raw LoRa socket
              self.lora_sock = usocket.socket(usocket.AF_LORA, usocket.SOCK_RAW)
              self.lora_sock.setblocking(False)
              self.lora_tx_done = False
              self.lora.callback(trigger=(LoRa.RX_PACKET_EVENT | LoRa.TX_PACKET_EVENT), handler=self._lora_cb)
              self._log('LoRaWAN nano gateway online')
          def stop(self):
              Stops the LoRaWAN nano gateway.
              self._log('Stopping...')
              # send the LoRa radio to sleep
              self.lora.callback(trigger=None, handler=None)
              self.lora.power_mode(LoRa.SLEEP)
              # stop the NTP sync
              self.rtc.ntp_sync(None)
              # cancel all the alarms
              self.stat_alarm.cancel()
              self.pull_alarm.cancel()
              # signal the UDP thread to stop
              self.udp_stop = True
              while self.udp_stop:
                  utime.sleep_ms(50)
              # disable WLAN
              self.wlan.disconnect()
              self.wlan.deinit()
          def _connect_to_wifi(self):
              self.wlan.connect(self.ssid, auth=(None, self.password))
              while not self.wlan.isconnected():
                  utime.sleep_ms(50)
              self._log('WiFi connected to: {}', self.ssid)
          def _dr_to_sf(self, dr):
              sf = dr[2:4]
              if sf[1] not in '0123456789':
                  sf = sf[:1]
              return int(sf)
          def _dr_to_bw(self, dr):
              bw = dr[-5:]
              if bw == 'BW125':
                  return LoRa.BW_125KHZ
              elif bw == 'BW250':
                  return LoRa.BW_250KHZ
                  return LoRa.BW_500KHZ
          def _sf_bw_to_dr(self, sf, bw):
              dr = 'SF' + str(sf)
              if bw == LoRa.BW_125KHZ:
                  return dr + 'BW125'
              elif bw == LoRa.BW_250KHZ:
                  return dr + 'BW250'
                  return dr + 'BW500'
          def _lora_cb(self, lora):
              LoRa radio events callback handler.
              events = lora.events()
              if events & LoRa.RX_PACKET_EVENT:
                  self.rxnb += 1
                  self.rxok += 1
                  rx_data = self.lora_sock.recv(256)
                  stats = lora.stats()
                  packet = self._make_node_packet(rx_data, self.rtc.now(), stats.rx_timestamp, stats.sfrx, self.bw, stats.rssi, stats.snr)
                  packet = self.frequency_rounding_fix(packet, self.frequency)
                  self._push_data(packet)
                  self._log('Received packet: {}', packet)
                  self.rxfw += 1
              if events & LoRa.TX_PACKET_EVENT:
                  self.txnb += 1
                  lora.init(
                      mode=LoRa.LORA,
                      bandwidth=self.bw,
                      sf=self.sf,
                      preamble=8,
                      tx_iq=True
          def _freq_to_float(self, frequency):
              MicroPython has some inprecision when doing large float division.
              To counter this, this method first does integer division until we
              reach the decimal breaking point. This doesn't completely elimate
              the issue in all cases, but it does help for a number of commonly
              used frequencies.
              divider = 6
              while divider > 0 and frequency % 10 == 0:
                  frequency = frequency // 10
                  divider -= 1
              if divider > 0:
                  frequency = frequency / (10 ** divider)
              return frequency
          def frequency_rounding_fix(self, packet, frequency):
              freq = str(frequency)[0:3] + '.' + str(frequency)[3]
              start = packet.find("freq\":")
              end = packet.find(",", start)
              packet = packet[:start + 7] + freq + packet[end:]
              return packet
          def _make_stat_packet(self):
              now = self.rtc.now()
              STAT_PK["stat"]["time"] = "%d-%02d-%02d %02d:%02d:%02d GMT" % (now[0], now[1], now[2], now[3], now[4], now[5])
              STAT_PK["stat"]["rxnb"] = self.rxnb
              STAT_PK["stat"]["rxok"] = self.rxok
              STAT_PK["stat"]["rxfw"] = self.rxfw
              STAT_PK["stat"]["dwnb"] = self.dwnb
              STAT_PK["stat"]["txnb"] = self.txnb
              return ujson.dumps(STAT_PK)
          def _make_node_packet(self, rx_data, rx_time, tmst, sf, bw, rssi, snr):
              RX_PK["rxpk"][0]["time"] = "%d-%02d-%02dT%02d:%02d:%02d.%dZ" % (rx_time[0], rx_time[1], rx_time[2], rx_time[3], rx_time[4], rx_time[5], rx_time[6])
              RX_PK["rxpk"][0]["tmst"] = tmst
              RX_PK["rxpk"][0]["freq"] = self._freq_to_float(self.frequency)
              RX_PK["rxpk"][0]["datr"] = self._sf_bw_to_dr(sf, bw)
              RX_PK["rxpk"][0]["rssi"] = rssi
              RX_PK["rxpk"][0]["lsnr"] = snr
              RX_PK["rxpk"][0]["data"] = ubinascii.b2a_base64(rx_data)[:-1]
              RX_PK["rxpk"][0]["size"] = len(rx_data)
              return ujson.dumps(RX_PK)
          def _push_data(self, data):
              token = uos.urandom(2)
              packet = bytes([PROTOCOL_VERSION]) + token + bytes([PUSH_DATA]) + ubinascii.unhexlify(self.id) + data
              with self.udp_lock:
                  try:
                      self.sock.sendto(packet, self.server_ip)
                  except Exception as ex:
                      self._log('Failed to push uplink packet to server: {}', ex)
          def _pull_data(self):
              packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_DATA]) + ubinascii.unhexlify(self.id)
              with self.udp_lock:
                  try:
                      self._log('Failed to pull downlink packets from server: {}', ex)
          def _ack_pull_rsp(self, token, error):
              TX_ACK_PK["txpk_ack"]["error"] = error
              resp = ujson.dumps(TX_ACK_PK)
              packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_ACK]) + ubinascii.unhexlify(self.id) + resp
              with self.udp_lock:
                  try:
                      self._log('PULL RSP ACK exception: {}', ex)
          def _send_down_link(self, data, tmst, datarate, frequency):
              Transmits a downlink message over LoRa.
              self.lora.init(
                  mode=LoRa.LORA,
                  frequency=frequency,
                  bandwidth=self._dr_to_bw(datarate),
                  sf=self._dr_to_sf(datarate),
                  preamble=8,
                  tx_iq=True
              #while utime.ticks_cpu() < tmst:
              #    pass
              self.lora_sock.send(data)
              self._log(
                  'Sent downlink packet scheduled on {:.3f}, at {:.3f} Mhz using {}: {}',
                  tmst / 1000000,
                  self._freq_to_float(frequency),
                  datarate,
                  data
          def _send_down_link_class_c(self, data, datarate, frequency):
              self.lora.init(
                  mode=LoRa.LORA,
                  preamble=8,
                  tx_iq=True,
                  device_class=LoRa.CLASS_C
              self._log(
                  utime.time(),
                  datarate,
                  data
          def _udp_thread(self):
              UDP thread, reads data from the server and handles it.
              while not self.udp_stop:
                  try:
                      data, src = self.sock.recvfrom(1024)
                      _token = data[1:3]
                      _type = data[3]
                      if _type == PUSH_ACK:
                          self._log("Push ack")
                      elif _type == PULL_ACK:
                          self._log("Pull ack")
                      elif _type == PULL_RESP:
                          self.dwnb += 1
                          ack_error = TX_ERR_NONE
                          tx_pk = ujson.loads(data[4:])
                          if "tmst" in data:
                              tmst = tx_pk["txpk"]["tmst"]
                              t_us = tmst - utime.ticks_cpu() - 15000
                              if t_us < 0:
                                  t_us += 0xFFFFFFFF
                              if t_us < 20000000:
                                  self.uplink_alarm = Timer.Alarm(
                                      handler=lambda x: self._send_down_link(
                                          ubinascii.a2b_base64(tx_pk["txpk"]["data"]),
                                          tx_pk["txpk"]["tmst"] - 50, tx_pk["txpk"]["datr"],
                                          int(tx_pk["txpk"]["freq"] * 1000) * 1000
                                      us=t_us
                                  ack_error = TX_ERR_TOO_LATE
                                  self._log('Downlink timestamp error!, t_us: {}', t_us)
                                  handler=lambda x: self._send_down_link_class_c(
                                  us=50
                          self._ack_pull_rsp(_token, ack_error)
                          self._log("Pull rsp")
                  except usocket.timeout:
                      pass
                  except OSError as ex:
                      if ex.errno != errno.EAGAIN:
                          self._log('UDP recv OSError Exception: {}', ex)
                      self._log('UDP recv Exception: {}', ex)
                  # wait before trying to receive again
                  utime.sleep_ms(UDP_THREAD_CYCLE_MS)
              # we are to close the socket
              self.sock.close()
              self._log('UDP thread stopped')
          def _log(self, message, *args):
              Outputs a log message to stdout.
              print('[{:>10.3f}] {}'.format(
                  utime.ticks_ms() / 1000,
                  str(message).format(*args)
      main.py
      """ LoPy LoRaWAN Nano Gateway example usage """
      import config
      from nanogateway import NanoGateway
      if __name__ == '__main__':
          nanogw = NanoGateway(
              id=config.GATEWAY_ID,
              frequency=config.LORA_FREQUENCY,
              datarate=config.LORA_GW_DR,
              ssid=config.WIFI_SSID,
              password=config.WIFI_PASS,
              address=config.WIFI_ADDRESS,
              mask=config.WIFI_MASK,
              gateway=config.WIFI_GATEWAY,
              server=config.SERVER,
              port=config.PORT,
              ntp_server=config.NTP,
              ntp_period=config.NTP_PERIOD_S
          nanogw.start()
          nanogw._log('You may now press ENTER to enter the REPL')
          input()
      Start up log
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8028,len:8
      load:0x3fff8030,len:1688
      load:0x4009fa00,len:0
      load:0x4009fa00,len:14592
      entry 0x400a059c
      WMAC: 3C71BF8750F0
      Firmware: 1.18.2.r6
      Pybytes: 0.9.12
      Pybytes configuration read from /flash/pybytes_config.json
      Initialized watchdog for WiFi and LTE connection with timeout 660000 ms
      WiFi connection established
      WARNING: consider enabling certificate validation
      Using MQTT over TLS
      Connected to MQTT mqtt.pybytes.pycom.io
      Pybytes connected successfully (using the built-in pybytes library)
      Now starting user code in main.py
      [    31.212] Starting LoRaWAN nano gateway with id: b'3C71BFFFFE8750F0'
      [    31.238] WiFi connected to: ssid
      [    31.245] Syncing time with pool.ntp.org ...
      [    35.502] RTC NTP sync complete
      [    42.098] Opening UDP socket to router.thethings.meshed.com.au (224.94.149.63) port 1700...
      [    42.116] Setting up the LoRa radio at 916.7999 Mhz using SF7BW125
      [    42.160] LoRaWAN nano gateway online
      [    42.167] You may now press ENTER to enter the REPL
      As for the OTAA client I can not get it to connect
      config.py
      """ LoPy Node configuration options """
      import ubinascii
      # Set  the Node ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address
      NODE_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12]
      # for EU868
      # LORA_NODE_DR = 5
      # for US915
      # LORA_NODE_DR = 3
      # for AU915
      LORA_NODE_DR = 4
      main.py
      """ OTAA Node example compatible with the LoPy Nano Gateway """
      import binascii
      import struct
      import config
      # initialize LoRa in LORAWAN mode.
      # Please pick the region that matches where you are using the device:
      # Asia = LoRa.AS923
      # Australia = LoRa.AU915
      # Europe = LoRa.EU868
      # United States = LoRa.US915
      lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915)
      # create an OTA authentication params
      dev_eui = config.NODE_ID
      app_eui = binascii.unhexlify('3C71BFFFFE8750F0')
      app_key = binascii.unhexlify('36AB7625FE770B6881683B495300FFD6')
      for channel in range(0, 16):
          lora.remove_channel(channel)
      # set the 3 default channels to the same frequency (must be before sending the OTAA join request)
      lora.add_channel(0, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR)
      lora.add_channel(1, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR)
      lora.add_channel(2, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR)
      # join a network using OTAA
      lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0) #, dr=config.LORA_NODE_DR)
      while not lora.has_joined():
          time.sleep(2.5)
          print('Not joined yet...')
      # remove all the non-default channels
      for i in range(3, 16):
          lora.remove_channel(i)
      # create a LoRa socket
      # set the LoRaWAN data rate
      s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR)
      s.setblocking(False)
      time.sleep(5.0)
      for i in range (200):
          pkt = b'PKT #' + bytes([i])
          print('Sending:', pkt)
          s.send(pkt)
          time.sleep(4)
          rx, port = s.recvfrom(256)
          if rx:
              print('Received: {}, on port: {}'.format(rx, port))
          time.sleep(6)
      Startup Log
      entry 0x400a059c
      WMAC: 807D3A934E9C
      Firmware: 1.18.2.r6
      Pybytes: 0.9.12
      Using MQTT over TLS
      Not joined yet...
      Not joined yet...
      Not joined yet...
      Not joined yet...
      Not joined yet...
      Not joined yet...
      Not joined yet...
      Not joined yet...
      Most likely I’ve don’t something wrong been new to Lora and the Lopy’s
      Any help would be appreciated, thanks.
        jcaron @Yendor
        @Yendor I think you have the Pybytes firmware loaded, you probably want the version without Pybytes in this case.
        • Y Offline
          Yendor
          Thanks @jcaron ,
          Got it working using ABP and a few change to the TNN config, but would still like to get it working with OTAA this was all done with the Pybytes firmware, I have now removed it on your suggestion and I'll see how it goes.
          Current configuration
          Gateway config.py
          import ubinascii
          SERVER = 'router.au.thethings.network'
          PORT = 1700
          NTP = "au.pool.ntp.org"
          NTP_PERIOD_S = 3600
          WIFI_SSID = 'ssid'
          # for EU868
          # LORA_NODE_DR = 5
          # for US915
          # LORA_NODE_DR = 3
          # for AU915
          LORA_NODE_DR = 5
          nanogateway.py
          import errno
          import ubinascii
          import ujson
          import uos
          import usocket
          import utime
          import _thread
          PUSH_ACK = const(1)
          PULL_ACK = const(4)
          STAT_PK = {
              'stat': {
                  'time': '',
                  'lati': 0,
                  'long': 0,
                  'alti': 0,
                  'rxnb': 0,
                  'rxok': 0,
                  'rxfw': 0,
                  'ackr': 100.0,
                  'dwnb': 0,
                  'txnb': 0
          RX_PK = {
              'rxpk': [{
                  'time': '',
                  'tmst': 0,
                  'chan': 0,
                  'rfch': 0,
                  'freq': 0,
                  'stat': 1,
                  'modu': 'LORA',
                  'datr': '',
                  'codr': '4/5',
                  'rssi': 0,
                  'lsnr': 0,
                  'size': 0,
                  'data': ''
          TX_ACK_PK = {
              'txpk_ack': {
                  'error': ''
          class NanoGateway:
              def __init__(self, id, frequency, datarate, ssid, password, address, mask, gateway, server, port, ntp_server='au.pool.ntp.org', ntp_period=3600):
                  self.id = id
                  self.port = port
                  self.ssid = ssid
                  self.mask = mask
                  self.rxnb = 0
                  self.rxok = 0
                  self.rxfw = 0
                  self.dwnb = 0
                  self.txnb = 0
                  self.wlan = None
                  self.sock = None
                  self.lora = None
              def start(self):
                  # get a time sync
                      utime.sleep_ms(50)
                  # create the alarms
                  self.lora = LoRa(
                      mode=LoRa.LORA,
                      bandwidth=self.bw,
                      sf=self.sf,
                      preamble=8,
                      tx_iq=True
              def stop(self):
                  # stop the NTP sync
                      utime.sleep_ms(50)
                  # disable WLAN
                  self.wlan.deinit()
                      utime.sleep_ms(50)
                  sf = dr[2:4]
                      sf = sf[:1]
                  return int(sf)
                  bw = dr[-5:]
                  if bw == 'BW125':
                  elif bw == 'BW250':
                  dr = 'SF' + str(sf)
                      return dr + 'BW125'
                      return dr + 'BW250'
                      return dr + 'BW500'
                      self.rxnb += 1
                      self.rxok += 1
                      self.rxfw += 1
                      self.txnb += 1
                      lora.init(
                          mode=LoRa.LORA,
                          bandwidth=self.bw,
                          sf=self.sf,
                          preamble=8,
                          tx_iq=True
                  used frequencies.
                  divider = 6
                      divider -= 1
                  if divider > 0:
                  return frequency
                  return packet
                  with self.udp_lock:
                      try:
                  with self.udp_lock:
                      try:
                  with self.udp_lock:
                      try:
                  self.lora.init(
                      mode=LoRa.LORA,
                      preamble=8,
                      tx_iq=True
                  #    pass
                  self._log(
                      tmst / 1000000,
                      datarate,
                      data
                  self.lora.init(
                      mode=LoRa.LORA,
                      preamble=8,
                      tx_iq=True,
                  self._log(
                      utime.time(),
                      datarate,
                      data
                      try:
                          _token = data[1:3]
                          _type = data[3]
                              self.dwnb += 1
                              if "tmst" in data:
                                  if t_us < 0:
                                      t_us += 0xFFFFFFFF
                                  if t_us < 20000000:
                                          us=t_us
                                      us=50
                          pass
                  self.sock.close()
          main.py
          import config
                  port=config.PORT,
              nanogw.start()
              input()
          Connecting to COM11...
          [     2.595] Starting LoRaWAN nano gateway with id: b'3C71BFFFFE8750F0'
          [     6.118] WiFi connected to: ssid
          [     6.123] Syncing time with au.pool.ntp.org ...
          [     6.179] RTC NTP sync complete
          [     6.189] Opening UDP socket to router.au.thethings.network (52.62.83.250) port 1700...
          [     6.204] Setting up the LoRa radio at 916.7999 Mhz using SF7BW125
          [     6.213] LoRaWAN nano gateway online
          [     6.218] You may now press ENTER to enter the REPL
          Pycom MicroPython 1.18.2.r7 [v1.8.6-849-df9f237] on 2019-05-14; LoPy4 with ESP32
          >>> [     6.249] Push ack
          [    21.068] Received packet: {"rxpk": [{"data": "QLIXAiYAAAACQ9+WpQPqPkmVOg==", "time": "2019-05-31T19:49:52.173381Z", "chan": 0, "tmst": 21050429, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": 0, "rfch": 0, "codr": "4/5", "freq": 916.8, "datr": "SF7BW125", "size": 19}]}
          [    21.129] Push ack
          [    31.066] Received packet: {"rxpk": [{"data": "QLIXAiYAAQAC1T4VWxMKlrC8Aw==", "time": "2019-05-31T19:50:02.172292Z", "chan": 0, "tmst": 31049439, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": -1, "rfch": 0, "codr": "4/5", "freq": 916.8, "datr": "SF7BW125", "size": 19}]}
          [    31.208] Push ack
          [    31.252] Pull ack
          ABP Node config.py
          import binascii
          import struct
          WIFI_MAC = binascii.hexlify(machine.unique_id()).upper()
          DEV_EUI = binascii.unhexlify('0x')
          APP_EUI = binascii.unhexlify('0x')
          APP_KEY = binascii.unhexlify('0x')
          DEV_ADDR = struct.unpack(">l", binascii.unhexlify('0x'))[0]
          NWK_SWKEY = binascii.unhexlify('0x')
          APP_SWKEY = binascii.unhexlify('0x')
          # for EU868
          # LORA_NODE_DR = 5
          # for US915
          # LORA_NODE_DR = 3
          # for AU915
          LORA_GATEWAY_DR = "SF7BW125"
          LORA_NODE_DR = 5
          main.py
          """ ABP Node example compatible with the LoPy Nano Gateway """
          import binascii
          import struct
          import config
          # Asia = LoRa.AS923
          # remove all the channels
          for channel in range(0, 72):
          # # set all channels to the same frequency (must be before sending the OTAA join request)
          # for channel in range(0, 72):
          #     lora.add_channel(channel, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR)
          # join a network using ABP
          lora.join(activation=LoRa.ABP, auth=(config.DEV_ADDR, config.NWK_SWKEY, config.APP_SWKEY))
              s.send(pkt)
              time.sleep(4)
              if rx:
              time.sleep(6)
          Sending: b'PKT #\x00'
          Sending: b'PKT #\x01'
          Sending: b'PKT #\x02'
