Launching pybytes (pybytes autostart set to off)
I was wondering if there was a command to launch Pybytes manually from within a script, after having the device start up with pybytes disabled.
there is, we have functionpybytes.start()
You will need to instantiate
pybytes
object manually. Basically do the steps that this code is doing, whenpybytes_autostart
isTrue
. https://github.com/pycom/pycom-micropython-sigfox/blob/pybytes-master/esp32/frozen/Base/_main.py#L21-L45>>> from _pybytes_config import PybytesConfig >>> pybytes_config = PybytesConfig().read_config() >>> from _pybytes import Pybytes >>> pybytes = Pybytes(pybytes_config)
this is how the full output if
pybytes_autostart
was false and how I manually connected to Pybytes later.
(you can see the message: Not starting Pybytes as auto-start is disabled)rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:1688 load:0x4009fa00,len:0 load:0x4009fa00,len:14592 entry 0x400a059c Pybytes configuration read from /flash/pybytes_config.json Not starting Pybytes as auto-start is disabled Pycom MicroPython 1.18.2.r6 [v1.8.6-849-a210e85] on 2019-05-13; WiPy with ESP32 Type "help()" for more information. >>> from _pybytes_config import PybytesConfig >>> pybytes_config = PybytesConfig().read_config() >>> from _pybytes import Pybytes >>> pybytes = Pybytes(pybytes_config) WMAC: 240AC40B3A1C Firmware: 1.18.2.r6 Pybytes: 0.9.12 >>> pybytes.connect() Initialized watchdog for WiFi and LTE connection with timeout 660000 ms WiFi connection established WARNING: consider enabling TLS by using pybytes.enable_ssl() Connected to MQTT 10.0.0.66 Pybytes connected successfully (using the built-in pybytes library) >>>
