    loramesh example crashing on LoPy4
    3 Posts 2 Posters 284 Views 2 Watching
      cuca94
      hi everyone!
      @catalin
      i got a couple of LoPy4 devices (with ext. board 3.1), upgraded the firmware to v1.20.0.rc11 and tested the raw lora successfully between two devices.
      after that i moved on to loramesh since this is very interresting for my application.
      i flashed the example code from the documentation (https://docs.pycom.io/tutorials/lora/lora-mesh.html) including the library source file (https://github.com/pycom/pycom-libraries/blob/master/lib/lora_mesh/loramesh.py) onto two lopy's, but after powering them they both did not connect to the loramesh.
      both devices act the same:
      the rgbled stays red and after around 50 seconds of hanging in the first while loop getting "state: detached" it breaks the while, says "neighbors found: 0" and crashes with an error in this line: https://github.com/pycom/pycom-libraries/blob/adb22c2d005b8ce83d8a9a6b31bbe5265135018a/lib/lora_mesh/main.py#L68
      i will post the exact error tomorrow.
      am i understanding the whole mesh thing wrong or is it right that the first device powered up will "start" the mesh and the others will "log in" to it?!
      how are the roles of the mesh members selected?
      thanks for your help
      best regards
      • catalinC Offline
        catalin
        hi @cuca94, glad you tried pymesh example.
        The error is due to the method rc_cb() which should have 2 parameters, as it's in docs: https://development.pycom.io/firmware-and-api-reference/pycom/network/lora/pymesh#mesh-rx_cb-handler-argument
        If you fix it, maybe you could raise a pull-request.
        In principle it's correct.
        The firmware is identical for all devices, so every device could take any role, dinamically. First one powered, is most-likely the Leader. The following ones are Child, but they become Routers (after a random time up to 2 mins). Overall the max number of Routers is 16, so the 17th will stay Child.
        Catalin,
          cuca94
          thanks for your reply, i fixed the problem and raised a pull-request!
