I can not upload a sketch to my WiPy 3.0 using Arduino IDE.
@robert-hh said in I can not upload a sketch to my WiPy 3.0 using Arduino IDE.:
Pycom update too
Thank you I have updated the firmware. GPIO0 is at high now but I get the following error when trying to upload a sketch : ```
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header -
@armant That is still a message from the boot loader. if you just connect a terminal emulator at 115200 baud and push reset, which messages do you see?
terminal emulator
I can not make the connection anymore. I tried Atom and PuTTy but got no message and failed to connect. I used to get some messages when I pushed the reset.
@armant With Putty you have to set flow control to None.
@robert-hh Still could not make the connection
My baud is 115200, data bits 8 , stop bits 1, parity none and flow control none. -
@armant That is strange. At least the boot loader should come up with messages like:
ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:2156 ho 0 tail 12 room 4 load:0x4009fa00,len:19208 entry 0x400a05f4 -
This post is deleted! -
@robert-hh I managed to update the firmware again and get the serial working but again GPIO0 is not high this time and I can not program.
@armant Can you pull GPIO0 high externally, push reset & look at the messages? And, b.t.w., how and at which Pin do you power the device?
@robert-hh I pulled it High externally and now it works. Thank you very much! Really appreciate your help.
