    What does the PWR_EN pin on Pysense do?
    fipypysensecontrol pin
    6 Posts 3 Posters 1.1k Views 3 Watching
      akshayjames
      I could not understand what the function of PWR_EN pin on the Pysense is.
      Can anybody help?
        jmarcelino @akshayjames
        @akshayjames
        It turns on the power supply to the Pycom module.
          akshayjames @jmarcelino
          @jmarcelino Does that pin do anything when the Pysense is powered via USB?
          When I measured the voltage on PWR_EN pin on external IO, it is about 2.53 volts (HIGH). I pulled the PWR_EN pin low, but the module continues to work. (0 volt on PWR_EN pin).
          Can I use it to disable the module externally?
            akshayjames @akshayjames
            @akshayjames said in What does the PWR_EN pin on Pysense do?:
            Unplugged USB. > The PWR_EN pin is connected to GND. > Plugged back in the USB cable.
            Still the FiPy module works?
              svonbentzel
              Hello, any news to this topic. Can I force a Reset over PWR_EN and GND?
                svonbentzel
                Can everyone explain me how is pwr_en works?
                Can I wakeup the board over pwr_en and gnd from deepsleep?
                Can I force a reset over this pin?
                Pycom doc confuse me 😊
                With your input, this post could be even better πŸ’—
