    Struggling with message format for Sigfox transmission
    1 Posts 1 Posters 163 Views 1 Watching
      jez
      Re: Data format for Sigfox transmission
      So i'm continuing to have issues with what must be a simple task. Below is my code... simply trying to send the variable data1 via Sigfox.
      A message is received but the data is always represented as "21030490058604" from the Sigfox back end which I assume is an error code of some form as its always the same irrelevant of the content of my variable.
      The content is encoded from 2315051001 to b'\xf9\xdf\xfc\x89'. But I'm unclear if this is how the data should be prepared for sigfox? As ever any help appreciated.
      from network import Sigfox
      from time import sleep
      import _thread
      import array
      import ustruct
      # init Sigfox for RCZ1 (Europe)
      sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
      # create a Sigfox socket
      s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
      # make the socket blocking
      s.setblocking(True)
      # configure it as uplink only
      s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
      # send some bytes
      data1 = 2315051001
      print (data1)
      data1 = ustruct.pack('i', data1)
              try:
                      s.send(data1)
                      print (data1)
              except:
                      print ("fail")
                      pass
              sleep(900)```
