    WLAN connectivity problem
    Scheduled Pinned Locked Moved Software Tools
    pymakr
    20 Posts 8 Posters 5.1k Views 9 Watching
      SenaPR @robert-hh
      @robert-hh are there any libraries which we need to dump on our pycom board after upgrading its firware ??
      Thank you.
        robert-hh @SenaPR
        @SenaPR No, for the language itself and the standard modules as documented you do not need any special libraries. Especially the Bluetooth and WiFi modules are embedded in the firmware. For you special application, you might need some libraries and scripts, but that's another story.
          guyadams99 @robert-hh
          @SenaPR - also, most of these IP addresses are invalid - an IPv4 address can't have an octet above 255 and you have 478 and even 1090. I would expect the libraries to reject these, but in any case you will never get a working network without valid IP addresses.
            SenaPR @robert-hh
            @robert-hh i have attached a file of the WLAN program, using the code i am trying to connect pycom board wifi with the office router. Everything has been developed under your guidance but still i am unable to connect it with the office wifi. Please go through the program and suggest me if i went somewhere wrong. Thank you.0_1505381525191_test3.png
              robert-hh @SenaPR
              @SenaPR Hello SenaPR, What I'm missing is in the auth= parameter of the connect statement the WiFi password of your router. I guess you just dropped that for showing th example..
              And you cannot give your own device the IP address of the router, which is 192.168.1.1. So you must use something different, which is not in use at the moment, like 192.168.1.100. You have to ask the network administrator which addresses you may use.
              Again, I see a problem with indentation. The last idle() statement is not indented properly and should raise an sytax error.
              Are you sure that this boot.py is really loaded to your device? It has to, because is is executed before pymakr steps in. Otherwise, for testing you can give is a different name, like connect.py, and just put a statement like:
              import connect
              into boot.py.
              I do not trust the atom plugin.
              Still: if your PC is connected to the office router, open the program cmd.exe, which gives you the good ol' MSDOS command prompt. At the prompt, enter the command:
              ipconfig
              That will tell you the netmask, the IP address of the router, and the IP-adress of the DNS-Service.
              • N Offline
                Nona
                facing exactly the same issue.Even changed the router and firewall but didn't work.do i have to install any kind of library?
                please revert asap as i have to finish my project by the end of this week.
                • V Offline
                  Vellin_Boute
                    jswmai123
                      jcaron
                      DO NOT click on the link in the post by Vellin_Boute, it is most certainly an attempt to hack your router...
                        Cherry Mann Banned
                        1 Reply Last reply Reply Quote -1
