    urequest.post gives me an OSError: Network card not available
    5 Posts 3 Posters 347 Views 3 Watching
      Thosch42
      Hi all!
      I simply like to post some measurement values to an influxdb.
      resp_data = "current,location={0} value={1}".format(location, irms)
      resp = urequests.post(db, data=resp_data)
      print("response: {}".format(resp.status_code))
      I'm using the lates urequests.py from micropython-lib.
      The error points me to line 56 of the urequests.py lib
      s = usocket.socket(ai[0], ai[1], ai[2])
      Someone else getting such an error?
      Thomas
        Thosch42
        Ok...
        Digging a bit deeper into the problem.
        The request method in urequests.py uses the usocket.getaddrinfo method from the usocket lib to resolve the host ip.
        The given ip string is
        db = "http://xxx.xxx.xxx.xxx:8086/write?db=energy_db"
        and it is splittet correctly.
        The result of the usocket.getaddrinfo call
        ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)
        gives the following list back:
        [(2, 1, 0, '', ('xxx.xxx.xxx.xxx', 8086))]
        The first list entry is the 'family'. Locking into the docs, FamilyType[2] is socket.AF_SIGFOX.
        The L01 doesn't have a SIGFOX modem. So, to try to open a socket with
        leads to the OSError: Network card not available.
        I'm using Pycom 1.20.0.rc13 [v1.9.4-94bb382] firmware. Is it probably a bug?
        Thomas
        • K Offline
          KenM
          urequests.request("POST","http://IPADDRESS/api/v1/TOKEN/telemetry","{\"temperature\": 25.01,\"pressure\": 1.02}", None, {"Content-Type": "application/json"},None).text
          This worked for me to post to thingsboard
          after changing
          to
          ai = usocket.getaddrinfo(host, port)
          But when I got an error I had to power off to make it work again.
          urequests.py
          release='1.18.2.r7'
          S 2 Replies Last reply Reply Quote 0
            samith wijerathna @KenM
            @KenM Could you please share the python code I am trying to send data to thingsboard via Gpy LTE Nb network.
              @KenM said in urequest.post gives me an OSError: Network card not available:
              api/v1/
              thanks lot .it is working...
