    New release New firmware release 1.2.2.b1
    36 Posts 10 Posters 13.9k Views 10 Watching
      minkley
      I think the latest firmware for Linux is borked :) It's my first hands-on with the wipy2 and the upater failed. Digging around I noticed there are no firmware files in the tgz.
      There is no firmware directory as per the previous v 0.9.7.. version. I used this link https://software.pycom.io/findupgrade?product=pycom-firmware-updater&type=all&platform=unix&redirect=true
      Here are the extracts so you can see what I am talking about.
      tar -tvzf pycom_update_1.0.0.b2.tar.gz
      -rw-r--r-- abiliojr/staff 247 2016-12-17 04:17 pyupgrade/README
      drwxr-xr-x abiliojr/staff 0 2016-12-19 12:38 pyupgrade/bin/
      -rw-r--r-- abiliojr/staff 0 2016-12-17 04:17 pyupgrade/bin/init.py
      -rw-r--r-- abiliojr/staff 92013 2016-12-17 04:17 pyupgrade/bin/esptool.py
      -rwxr-xr-x abiliojr/staff 4046 2016-12-17 04:17 pyupgrade/bin/updater.py
      -rw-r--r-- abiliojr/staff 22135 2016-12-17 04:17 pyupgrade/lopyupdate.py
      -rw-r--r-- abiliojr/staff 44124 2016-12-17 04:17 pyupgrade/spinner.gif
      -rwxr-xr-x abiliojr/staff 7316 2016-12-19 19:14 pyupgrade/update
      tar -tvzf pycom_update_0.9.7.b1.tar.gz
      drwxr-xr-x abiliojr/staff 0 2016-11-26 08:44 pyupgrade/bin/
      -rw-r--r-- abiliojr/staff 0 2016-10-27 20:13 pyupgrade/bin/init.py
      -rw-r--r-- abiliojr/staff 92032 2016-11-26 08:19 pyupgrade/bin/esptool.py
      -rwxr-xr-x abiliojr/staff 2408 2016-11-26 08:44 pyupgrade/bin/updater.py
      -rwxr-xr-x abiliojr/staff 210 2016-12-03 05:12 pyupgrade/._firmware
      drwxr-xr-x abiliojr/staff 0 2016-12-03 05:12 pyupgrade/firmware/
      -rw-r--r-- abiliojr/staff 210 2016-12-03 04:31 pyupgrade/firmware/._bootloader.bin
      -rw-r--r-- abiliojr/staff 5520 2016-12-03 04:31 pyupgrade/firmware/bootloader.bin
      -rw-r--r-- abiliojr/staff 210 2016-12-03 04:44 pyupgrade/firmware/._lopy_0.9.7.b1_868.bin
      -rw-r--r-- abiliojr/staff 828448 2016-12-03 04:44 pyupgrade/firmware/lopy_0.9.7.b1_868.bin
      -rw-r--r-- abiliojr/staff 210 2016-12-03 04:43 pyupgrade/firmware/._lopy_0.9.7.b1_915.bin
      -rw-r--r-- abiliojr/staff 828272 2016-12-03 04:43 pyupgrade/firmware/lopy_0.9.7.b1_915.bin
      -rw-r--r-- abiliojr/staff 210 2016-12-03 04:32 pyupgrade/firmware/._partitions.bin
      -rw-r--r-- abiliojr/staff 3072 2016-12-03 04:32 pyupgrade/firmware/partitions.bin
      -rw-r--r-- abiliojr/staff 210 2016-12-03 04:46 pyupgrade/firmware/._wipy_0.9.7.b1.bin
      -rw-r--r-- abiliojr/staff 820400 2016-12-03 04:46 pyupgrade/firmware/wipy_0.9.7.b1.bin
      -rw-r--r-- abiliojr/staff 14383 2016-11-26 08:43 pyupgrade/lopyupdate.py
      -rwxr-xr-x abiliojr/staff 5765 2016-11-06 03:32 pyupgrade/update
      Or am I mistaken :)
      Thanks guys
        daniel @minkley
        @minkley the updater now connects to the internet every time to get the latest files. Normally the updater prints an error message with the reason of the failure. Could you try again and copy paste the message here? Thanks.
          minkley
          File "./bin/updater.py", line 3, in <module>
          from esptool import ESP32ROM
          File "/home/mink/pyupgrade/bin/esptool.py", line 25, in <module>
          import serial
          ImportError: No module named serial
            Ok, it looks like only the Windows and OS X updater tools come with pyserial bundled. Please install pyserial manually and run the updater again:
            http://pyserial.readthedocs.io/en/latest/pyserial.html#installation
            We will add this to the docs. Thanks.
              minkley @daniel
              @daniel
              Thanks Daniel
              I installed pyserial it's getting past that now but failing with the following message
              Namespace(file=None, port='/dev/ttyUSB0', speed=115200, tar='/tmp/tmp.nBBvLQ6mbC/update.tar.gz')
              Connecting...
              Exception: Failed to connect to ESP32: Timed out waiting for packet header, on line 121
              root@pecan:/home/mink/pyupgrade#
              So I guess the ESP32 is not live , perhaps you clarify something for about the firmware upgrade process. As I don't have an expansion but am using a USB serial cable, where does wipy2 get it's power from?
              As an FYI, I'm using the same USB serial cable I connect to various other devices eg my CubieTruck3, so I know it works
              Any guidance would be appreciated.
              thanks
                @minkley have a look here: https://www.pycom.io/wp-content/uploads/2016/11/wipy_pinout.pdf
                You should connect 5V from the USB and GND. You also need to connect Rx and Tx on the program port. Don't forget to wire P2 to GND and reset to enter flashing mode as instructed by the updater tool.
                • F Offline
                  Feiko
                  Nano Gateway example doesn't work anymore https://forum.pycom.io/post/1210
                  It seems that calling lora_sock.recv(256) after lora_sock.send(pkg) is blocking the lora_sock.send function. The package is only send after the receive function is timed out. This kind of defeats the purpose of sending an ACK package. Does anyone have a solution?
                  Keep up the good work!
                    daniel @Feiko
                    @Feiko have you by chance made the socket blocking?
                    lora_sock.setblocking(True)
                    • F Offline
                      Feiko @daniel
                      @daniel Here's my code. It's the same as in the example I added a timeout.
                      import struct
                      from network import LoRa
                      # A basic package header, B: 1 byte for the deviceId, B: 1 bytes for the pkg size
                      _LORA_PKG_FORMAT = "BB%ds"
                      _LORA_PKG_ACK_FORMAT = "BBB"
                      DEVICE_ID = 0x01
                      # Open a Lora Socket, use tx_iq to avoid listening to our own messages
                      lora = LoRa(mode=LoRa.LORA, tx_iq=True)
                      lora_sock.setblocking(False)
                      while(True):
                          # Package send containing a simple string
                          msg = "Device 1 Here"
                          pkg = struct.pack(_LORA_PKG_FORMAT % len(msg), DEVICE_ID, len(msg), msg)
                          lora_sock.send(pkg)
                          # Wait for the response from the gateway. NOTE: For this demo the device does an infinite loop for while waiting the response. Introduce a max_time_waiting for you application
                          waiting_ack = True
                          timeout = time.time() +20
                          while(waiting_ack and timeout < time.time()):
                              recv_ack = lora_sock.recv(256)
                              if (len(recv_ack) > 0):
                                  device_id, pkg_len, ack = struct.unpack(_LORA_PKG_ACK_FORMAT, recv_ack)
                                  if (device_id == DEVICE_ID):
                                      if (ack == 200):
                                          waiting_ack = False
                                          # If the uart = machine.UART(0, 115200) and os.dupterm(uart) are set in the boot.py this print should appear in the serial port
                                          print("ACK")
                                          waiting_ack = False
                                          print("Message Failed")
                          time.sleep(5)
                      The socket is not blocking.
                      • F Offline
                        Feiko @Feiko
                        Of course I used
                            while(waiting_ack and timeout > time.time()):
                        On the NanoGateway side the package is received after timeout = time.time() + 20 is reached.
                        • F Offline
                          Feiko @daniel
                          In attempt to fix the NanoGateway code I tried locating the problem.
                          I used the next client code:
                          import struct
                          DEVICE_ID = 0x00
                          while(True):
                              DEVICE_ID += 1
                              msg = "Device %d Here" %DEVICE_ID
                              print("send message %s" % msg)
                              lora_sock.send(pkg)
                              waiting_ack = True
                                     # if (device_id == DEVICE_ID):
                                      if (ack == 200):
                                          waiting_ack = False
                                              print("ACK")
                                              print("Ack with wrong device_id: %d" %device_id)
                                          waiting_ack = False
                              if waiting_ack:
                                  print('no ACK received')
                              time.sleep(5)
                          This gives the next Console output:
                          Running node.py
                          Soft resetting the LoPy
                          send message Device 1 Here
                          no ACK received
                          send message Device 2 Here
                          no ACK received
                          send message Device 3 Here
                          no ACK received
                          send message Device 4 Here
                          Ack with wrong device_id: 1
                          send message Device 5 Here
                          Ack with wrong device_id: 2
                          send message Device 6 Here
                          no ACK received
                          send message Device 7 Here
                          no ACK received
                          Using the code nanogateway code from the tutorial found here gives the next console output:
                          Running nano_gateway.py
                          Device: 1 - Pkg:  b'Device 1 Here'
                          Device: 2 - Pkg:  b'Device 2 Here'
                          Device: 3 - Pkg:  b'Device 3 Here'
                            File "<stdin>", line 28, in <module>
                          OSError: [Errno 11] EAGAIN
                          The package is received on the gateway side after the timeout is reached on the client side. Also the Ack for device 1 is received after the Gateway crashed.
                          Also after stopping the client and soft resetting then restarting the Gateway. There are still messages received:
                          Device: 4 - Pkg:  b'Device 4 Here'
                          Device: 5 - Pkg:  b'Device 5 Here'
                          The receive buffer doesn't seemed to be reset with a soft reset. The sending of the ACK package from the server results in the OsError. After removing the
                          lora_sock.send(ack_pkg)
                          the gateway runs finds, however no Ack package is send.
                          Of course I used the latest firmware 1.2.2.b1. Can someone confirm my findings? I hope the problem can be fixed. I really need this code to run for a project.
                          • I Offline
                            iber
                            For me, the example code runs fine.
                            Although, I have noticed that your LoPy shouldn't be to close to eachother.
                            Maybe the long LORA wave has something to do with it?
                            • bmarkusB Offline
                              bmarkus @iber
                              @iber said in New release New firmware release 1.2.2.b1:
                              Personal experience is with LoRa devices and gateways that it is easy to override receiver if they are very closed to each other equipped with antenna. In this case you exeperince a high packet error rate, lost packets.
                              Place them in few meter distance and disconnect antenna. It will not damage your chip but if you afraid use a dummy load or an attenuator between LoPy and antenna,
                              • I Offline
                                iber
                                I have to stand corrected, now that I'm running 1.2.2.b1 I can't get it working either...
                                • F Offline
                                  Feiko @iber
                                  @iber Thanks Iber. I thought I was losing it. I Just went threw the trouble of putting the nodes 100 meters apart. Still no luck. Does your nanogateway also crash? putting in a little wait between receiving and sending the ACK message fixed this for me. Still the code shouldn't be crashing. @daniel Is this bug going to be fixed in the upcomming update?
                                    minkley @minkley
                                    @minkley
                                    Still struggling to get the firmware upgrade to work on linux.
                                    Note, I'm not using an expansion card but a Serial USB cable which powers the device up and allows me to connect to the wifi
                                    I'm also able to connect to the serial port with minicom and I get the following python version:
                                    >>> print(sys.version)
                                    3.4.0
                                    When I try and update the firmware I get the following error.
                                    Namespace(file=None, port='/dev/ttyUSB0', speed=115200, tar='/tmp/tmp.zR12S6HK0s/update.tar.gz')
                                    Connecting...
                                    Uploading stub...
                                    Running stub...
                                    Stub running...
                                    Changing baud rate to 115200
                                    Changed.
                                    Exception: empty file, on line 131
                                    This what I am doing exactly:
                                    As root Downloaded and extracted pycom_update_1.0.0.b3.tar.gz
                                    • cd into pyupgrade
                                    • run ./update
                                    • select WiPy 2.0
                                    • Disconnect device from USB
                                    • Put G23 into GND
                                    • Plug in USB cable
                                    • Press and hold the the reset button for about 3 seconds
                                    • Press enter on the update
                                    • Type in the serial path :-> /dev/ttyUSB0
                                    • Deselect high speed
                                    Then it fails with the "Exception: empty file on line 131.
                                    Just to be sure my EMS32 connectivity is good, whilst connected via minicom, if I plug in G23 to GND hit reset, I see the device is waiting for a download
                                    >>> ets Jun  8 2016 00:22:57
                                    rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
                                    waiting for download
                                    Perhaps someone can point me to the firmware file and a command line script I can use to test the install. I really would like to complete the upgrade and get on with using the device :)
                                    • 2 / 2
