urequests
  • urequests takes 20-30s to throw an OSError if it doesn't get a response. We can't figure out where this timeout comes from. There is no timeout in the original requests library
    def request(method, url, data=None, json=None, headers={}, stream=None):
        try:
            proto, dummy, host, path = url.split("/", 3)
        except ValueError:
            proto, dummy, host = url.split("/", 2)
            path = ""
        if proto == "http:":
            port = 80
        elif proto == "https:":
            import ussl
            port = 443
            raise ValueError("Unsupported protocol: " + proto)
        if ":" in host:
            host, port = host.split(":", 1)
            port = int(port)
        ai = usocket.getaddrinfo(host, port)
        ai = ai[0]
        s = usocket.socket(ai[0], ai[1], ai[2])
    We thought we'd try to add a shorter timeout following https://docs.python.org/3/library/socket.html#socket.getaddrinfo
    def request(method, url, data=None, json=None, headers={}, stream=None, timeout=5):
        try:
        except ValueError:
            path = ""
            port = 80
            import ussl
            port = 443
        if ":" in host:
            port = int(port)
            s = usocket.socket(2,1,0)
        if timeout is not None:
            assert hasattr(usocket.socket, 'settimeout'), 'Socket does not support timeout'
            s.settimeout(timeout)
        ai = ai[0]
    but it's not giving the 5s timeout we'd like. Can anyone see a way forward with this?
