    Pymesh updates
    loraenhancementpymesh
    73 Posts 13 Posters 12.8k Views 18 Watching
      thinginnovations
      For Lopy4 release, will this work on the L01 modules as this has the same flash and ram as the Lopy4 or will it be only limited to the L04 OEM modules?
      Andrew
        robert-hh @thinginnovations
        @thinginnovations You should expect that the LoPy4 firmware will only work on the L04 module (SX1276 chip) and the LoPy1 firmware will work on the L01 module, making however use of the larger RAM and flash. Similar to the WiPy firmware which works on both WiPy2 and WiPy3.
          thinginnovations @robert-hh
          @robert-hh That is providing Pycom build the firmware for the LoPy and include the LoRa Mesh functionality.
          Andrew
          • E Offline
            eranroll @catalin
            @catalin Thanks for the reply! I was able to load the tar files you had uploaded using the PyCom Firmware Updater.
            However, I am not sure I follow its purpose. LoRa Mesh communication will start working on boot? From that point forward messaging over the LoRa Mesh network is done only using the Mesh CLI?
            I am able to run a main.py file of lib/pymesh for example, but only after a few CTRL+C which stop the MESH THREAD.
            • catalinC Offline
              catalin @eranroll
              hi @eranroll
              Yes, indeed before I've frozen main.py, just for demo purpose.
              Now (just now, I've updated binaries), the Pymesh is a frozen library, and using a nice main.py you can play with Pymesh features.
              Catalin,
              E 1 Reply Last reply Reply Quote 1
                thinginnovations
                Just seen there is some new firmware for FiPy and Lopy4, are you going to create a version for use on L01 modules?
                Andrew
                catalinC 1 Reply Last reply Reply Quote 1
                • catalinC Offline
                  catalin @thinginnovations
                  Thanks @thinginnovations for pointing L01 modules.
                  For now there are some build errors, I'll check with the team.
                  When solved, I'll put them next to Lopy4 and Fipy: https://github.com/pycom/pymesh_apps
                  Catalin,
                  • DanneD Offline
                    Danne
                    With the new firmware:
                    On the line:
                    self.lora.Mesh()
                    in Loramesh I get:
                    Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
                    Any possibility of getting access to the FW source? Would be fun to debug this, and I got at least 5 Lopy4 boards that are unusable right now with this problem...
                    • catalinC Offline
                      catalin @Danne
                      Sorry, @Danne, can't release source-code, for now.
                      So, using https://github.com/pycom/pymesh_apps/blob/master/custom_fw_bin/LoPy4.tar.gz , then having just this small code (no other scripts running):
                      from network import LoRa
                      lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, frequency = 863000000, bandwidth=LoRa.BW_500KHZ, sf=7)
                      mesh = lora.Mesh()
                      Do you still have error?
                      Next, you could try only this main.py: https://github.com/pycom/pymesh_apps/blob/master/pymesh_micropy_scripts/main.py
                      Catalin,
                      DanneD 1 Reply Last reply Reply Quote 0
                      • E Offline
                        eranroll @catalin
                        @catalin Thanks for the quick response!
                        I have started to work with the binaries you had uploaded, and all of sudden I get this exception over and over again:
                        Core 0 register dump:
                        PC : 0x400930de PS : 0x00060033 A0 : 0x80092689 A1 : 0x3ffbb3a0
                        A2 : 0x3ffbb3f0 A3 : 0x3ffbb3c0 A4 : 0x00000020 A5 : 0x3ffc413c
                        A6 : 0x00000002 A7 : 0x3ffbb800 A8 : 0x00000000 A9 : 0x3ffb4d38
                        A10 : 0x3ffbb414 A11 : 0x3ffc4144 A12 : 0x3ffb4d38 A13 : 0x3ffb4d30
                        A14 : 0x00000001 A15 : 0x3ffbb6f0 SAR : 0x0000000a EXCCAUSE: 0x0000001c
                        EXCVADDR: 0x0000000c LBEG : 0x4009873c LEND : 0x40098747 LCOUNT : 0x00000000
                        Backtrace: 0x400930de:0x3ffbb3a0 0x40092686:0x3ffbb3c0 0x40093fb5:0x3ffbb3f0 0x40094302:0x3ffbb5c0 0x40093c1a:0x3ffbb600 0x40093e6e:0x3ffbb620 0x4008394a:0x3ffbb640 0x40090eb5:0x3ffbb700 0x40092c14:0x3ffbb720 0x40092bca:0x00000000
                        Any idea what might be the problem?
                        • catalinC Offline
                          catalin @eranroll
                          hi @eranroll
                          (Sorry, I have not saved the .elf, to debug the previous error)
                          Please try to re-load this v1.20.1.r1 release, also try also Erasing Flash file system and Force update LoRa region like:
                          Next, just try this simple code:
                          mesh = lora.Mesh()
                          Catalin,
                          DanneD 1 Reply Last reply Reply Quote 1
                          • DanneD Offline
                            Danne @catalin
                            @catalin said in Pymesh updates:
                            mesh = lora.Mesh()
                            Sorry been busy for some days. Today I did flash it with the https://github.com/pycom/pymesh_apps/blob/master/custom_fw_bin/LoPy4.tar.gz
                            Then used the code above and still the following :
                            Rebooting...
                            ets Jun  8 2016 00:22:57
                            configsip: 0, SPIWP:0xee
                            mode:DIO, clock div:1
                            load:0x3fff8020,len:8
                            load:0x3fff8028,len:2164
                            load:0x4009fa00,len:19944
                            entry 0x400a05e8
                            PC      : 0x40090fa8  PS      : 0x00060033  A0      : 0x40092c33  A1      : 0x3ffbb700
                            A2      : 0x3ffc42bc  A3      : 0x7fffffff  A4      : 0x00050023  A5      : 0xc8bc0000
                            A6      : 0x3ffdd8c8  A7      : 0x00000000  A8      : 0x3ffc412c  A9      : 0x00003ffd
                            A10     : 0x00000001  A11     : 0x3ffb4d38  A12     : 0x00000000  A13     : 0x00000005
                            A14     : 0x3ffc4030  A15     : 0x3ffc4134  SAR     : 0x00000014  EXCCAUSE: 0x0000001c
                            EXCVADDR: 0x00004009  LBEG    : 0x00000000  LEND    : 0x00000000  LCOUNT  : 0x00000000
                            Backtrace: 0x40090fa8:0x3ffbb700 0x40092c30:0x3ffbb720 0x40092be6:0x00000000
                            rolling fast... :)
                            Going to try the other main now...
                            • DanneD Offline
                              Danne @catalin
                              @catalin I followed the instructions given to @eranroll and me... and erased the flash file system and did update LoRa-region when flashing the new firmware that you linked
                              This is what I got when I tried this one:
                              Final error reading /flash/pymesh_config.json file!
                               Exception: [Errno 2] ENOENT
                              Can't find /flash/pymesh_config.json , or can't be parsed as json; Set default settings and reset
                              Default settings: {'debug': 5, 'Pymesh': {'key': '112233'}, 'autostart': True, 'LoRa': {'sf': 7, 'region': 5, 'freq': 863000000, 'bandwidth': 2}, 'ble_api': True, 'ble_name_prefix': 'PyGo '}
                              Set MAC in config file as  8121069065130701253
                              MAC ok 8121069065130701253
                              Default settings: {'ble_api': True, 'autostart': True, 'ble_name_prefix': 'PyGo ', 'debug': 5, 'LoRa': {'sf': 7, 'region': 5, 'freq': 863000000, 'bandwidth': 2}, 'MAC': 8121069065130701253, 'Pymesh': {'key': '112233'}}
                              write_config force restart
                              rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                              entry 0x400a05e8
                              Settings: {'ble_api': True, 'MAC': 8121069065130701253, 'autostart': True, 'debug': 5, 'LoRa': {'sf': 7, 'region': 5, 'freq': 863000000, 'bandwidth': 2}, 'ble_name_prefix': 'PyGo ', 'Pymesh': {'key': '112233'}}
                              PC      : 0x40090fa8  PS      : 0x00060033  A0      : 0x40092c33  A1      : 0x3ffd6730
                              A14     : 0x3ffc4030  A15     : 0x3ffc4134  SAR     : 0x00000012  EXCCAUSE: 0x0000001c
                              EXCVADDR: 0x00004009  LBEG    : 0x40098758  LEND    : 0x40098763  LCOUNT  : 0xffffffff
                              Backtrace: 0x40090fa8:0x3ffd6730 0x40092c30:0x3ffd6750 0x40092be6:0x000000fe
                              PC      : 0x400930fa  PS      : 0x00060033  A0      : 0x800926a5  A1      : 0x3ffd63d0
                              A2      : 0x3ffd6420  A3      : 0x3ffd63f0  A4      : 0x00000020  A5      : 0x3ffc412c
                              A6      : 0x00000002  A7      : 0x3ffd68d0  A8      : 0x00003ffd  A9      : 0x3ffdf7f4
                              A10     : 0x3ffd6438  A11     : 0x3ffc4134  A12     : 0x3ffdf7f4  A13     : 0x3ffe3130
                              A14     : 0x00000001  A15     : 0x3ffd6720  SAR     : 0x0000000a  EXCCAUSE: 0x0000001c
                              EXCVADDR: 0x00004009  LBEG    : 0x40098758  LEND    : 0x40098763  LCOUNT  : 0x00000000
                              Backtrace: 0x400930fa:0x3ffd63d0 0x400926a2:0x3ffd63f0 0x40093fd1:0x3ffd6420 0x4009431e:0x3ffd65f0 0x40093c36:0x3ffd6630 0x40093e8a:0x3ffd6650 0x4008395e:0x3ffd6670 0x40090fa5:0x3ffd6730 0x40092c30:0x3ffd6750 0x40092be6:0x000000fe
                              Re-entered core dump! Exception happened during core dump!
                              Rebooting...
                              • catalinC Offline
                                catalin @Danne
                                Thanks to @Danne I was able to debug the problem.
                                Apparently, there's a more general problem, so before using this Pymesh firmware, you should first erase all your board (Fipy or Lopy4) using the cli version of the Firmware Update Tool, so please navigate where this app was installed (search for pycom-fwtool-cli executable) and execute:
                                pycom-fwtool-cli -p <PORT> erase_all
                                Next, flash the Pymesh binary can be flashed using the normal Firmware Update Tool.
                                Also, fixed a small bug in main.py.
                                Catalin,
                                kodarnK DanneD CAPKEC 3 Replies Last reply Reply Quote 0
                                • kodarnK Offline
                                  kodarn @catalin
                                  @catalin That erase_all thing resolved my problems. Flash'ing your custom LoPy4-firmware now works, and your updated pymesh_micropy_scripts/main.py example starts out of the box :-)
                                  • DanneD Offline
                                    Danne @catalin
                                    @catalin Thanks a lot!
                                    This allows my project to continue, and I look forward to check out the app!
                                    • CAPKEC Offline
                                      CAPKE @catalin
                                      @catalin: I'm using the https://github.com/pycom/pymesh_apps/blob/master/custom_fw_bin/LoPy4.tar.gz on two devices (LoPy4 and FiPy) , but these both devices can not find a neighbor!
                                      Another 4 LoPy modules with firmware LoPy-1.20.0.rc7.tar.gz work perfectly in parallel.
                                        ricardolima @CAPKE
                                        @CAPKE
                                        Hi, it discover indirectly neighbor too? Thank you
                                        • catalinC Offline
                                          catalin
                                          Hi all,
                                          The Pymesh docs were updated: https://docs.pycom.io/pymesh/ explaining the frozen library API, BLE RPC, the CLI and the Border Router example.
                                          It should work with the firmware from https://github.com/pycom/pymesh_apps/tree/master/custom_fw_bin
                                          @CAPKE So, you're having the corresponding firmware Fipy and Lopy from here, so the 2 devices should create a Mesh network. Probably they're not compatible with the older Mesh created by LoPy-1.20.0.rc7.tar.gz because the masterkey is different. Initially I've used some default masterkey, now it can be set here and the default one is specified here in docs.
                                          Anyway, you could find the masterkey with command:
                                          # as test, the masterkey can be printed
                                          >>> print("masterkey:", pymesh.cli("masterkey"))
                                          masterkey: 11223300000000000000000000000000
                                          Catalin,
                                          kodarnK CAPKEC 2 Replies Last reply Reply Quote 1
                                          • kodarnK Offline
                                            kodarn @catalin
                                            @catalin Thanks for updating the documentation!
                                            One question: Do you consider lib/pymesh.py to be an api or an application? To my understanding, it spawn's an interactive CLI shell, right? so should it really be a part of /lib ?
                                            • 3 / 4
