How to set the Pin mode for machine.deepsleep?
@rcolistete
LoPy4 + Expansion Board v3.1, Yes
With battery (otherwise it wouldn't go to deepsleep)
No USB plugged in. -
if you want some code, this is the main.py (boot.py is empty)
from machine import I2C import time import machine #check for dual sensor i2cCH1 = I2C(0, I2C.MASTER, baudrate=100000, pins=('P9','P10')) i2cCH2 = I2C(1, I2C.MASTER, baudrate=100000, pins=('P22','P21')) from machine import Pin RelayPin=Pin('P20', mode=Pin.OUT, pull=None) RelayPin.value(1) # RelayPin.hold(True) # machine.pin_sleep_wakeup(['P20'], mode=machine.WAKEUP_ALL_LOW, enable_pull=False) time.sleep_ms(2000) print('\nSeconds Power ON: ' + str(time.ticks_ms()/1000)) if time.ticks_ms()/1000 < 120: # stop loop after 2 min. print('start sleep' ) time.sleep_ms(5000) # current drop print('start machine sleep') machine.sleep(10000) # current drop lower print('start machine deepsleep') machine.deepsleep(12000) # current drop lowestP20 -- 180 ohm -- led -- 3.3V (but P20 is pulled low also if not connected to anything)
@KenM My best experience with going to sleep is by setting pins, which drive external loads, to input mode before going to deep_sleep. Then it is guaranteed to be in high impedance state. Unless of course you need it to drive something, which of course then consumes power.
Changed the code tofrom machine import Pin RelayPin=Pin('P20', mode=Pin.IN)Didn't change it, well, P20 is always draining current now, not only in machine.sleep and machine.deepsleep.
@KenM In that case you most probably have an problem in the circuitry. Do you have the choice to connect the LED to GND instead of 3.3v. I'm suspecting a current through the ESD protection diodes, when during deepsleep the I/O circuitry is switched off. Whether that works for you final set-up, is another story.
I can change the board to source it instead of drain it but I was hoping this could be fixed in software, my I2C pins with external pull-ups don't draw current.
As test I tried to init P20 as part of the I2C but that didn't change the behavior of P20. (same for P19) -
@KenM Cyn you tell which direction is the current flow of P20 is?
It's sinking to ground through the external led/diode from 3.3V so there is only one direction possible. -
@KenM I made a test myself, using a 1k resistor between 3.3V and P20:
- after boot: 78µA
- When set to OUT, value=1: 5.2 µA
- when set to OUT, value = 0: 3.2 mA
- When set to IN: 0 µA
In any IN/OUT/value setting: Current during deepsleep: 0 µA.
I tested also P10. Same behavior.
So there may be some other reason. -
That good news and bad news
You used this code above with the same firmware version like mine on a lopy4 on an extension board? -
@KenM I use 1.20.1r1, but a homebrew extension board, with absolute no connection to P20 or P10, unless I wire some.
I did cut the connection of P20 to the expansion board but kept the connection of P20 to my board, and it work perfect now :)I will need to check if I lost some functionality of the expansion board.
All wasted time, because pycom refuses to give the schematic of the expansion board...
Thanks for doing some compare tests.
@KenM Welcome to the pin cutters club (https://forum.pycom.io/topic/1673/pysense-pinout-wake-on-pin/19) :-/
