Handling WLAN and MQTT disconnects
Hello. Before I start coding it up I was wondering if anyone has a good base model for detecting WiFi and mqtt failures and reconnecting?
Chris
@cmisztur To check if you are connected to wifi you can use the isconnected() as show below
from network import WLAN import time class WifiMonitor: def __init__(self): self.conn_timeout = 20 self.wlan = WLAN(mode=WLAN.STA) def _connect(self, ssid, pswd): if not self.wlan.isconnected(): print("Connecting to Wifi SSID: {} PASS: {}".format(ssid, pswd)) self.wlan.connect(ssid, auth=(WLAN.WPA2, pswd)) count_10ms = 0 while count_10ms <= self.conn_timeout * 100 and not self.wlan.isconnected(): count_10ms += 1 time.sleep(0.01) if self.wlan.isconnected(): print("WiFi connected: {}".format(self.wlan.ifconfig())) def connect_loop(self, ssid, pswd): while True: try: self._connect(ssid, pswd) except Exception as e: print("WIFI connection error: {}".format(e)) pass time.sleep(10) WIFI_SSID = 'my ssid' WIFI_PASS = 'my pass' wifi = WifiMonitor() wifi.connect_loop(WIFI_SSID, WIFI_PASS)For MQTT you can send a ping to the MQTT server
