I2C pin
Hi all,
I have to do two I2C lines and I have a disposition 4 pin: P8 P20 P15 P16.
For the first I2C I have P9 and P10
My question is Can i use two lines I2C together?
Francesco -
@ciccio
In case you need to connect more than one I2C device: you can have multiple I2C devices on one I2C bus
In case you really need two distinct I2C interfaces: Yes, you can define that. When defining the I2C, you can specify the GPIO ports used for that. You can however not use P15 or P16, because these are input only pins. P8 and P20 are fine, unless you want to use the SD card, which also uses P8. -
