    Pymesh updates
    loraenhancementpymesh
    73 Posts 13 Posters 14.1k Views 18 Watching
    • catalinC Offline
      catalin @Danne
      Thanks to @Danne I was able to debug the problem.
      Apparently, there's a more general problem, so before using this Pymesh firmware, you should first erase all your board (Fipy or Lopy4) using the cli version of the Firmware Update Tool, so please navigate where this app was installed (search for pycom-fwtool-cli executable) and execute:
      pycom-fwtool-cli -p <PORT> erase_all
      Next, flash the Pymesh binary can be flashed using the normal Firmware Update Tool.
      Also, fixed a small bug in main.py.
      Catalin,
      kodarnK DanneD CAPKEC 3 Replies Last reply Reply Quote 0
      • kodarnK Offline
        kodarn @catalin
        @catalin That erase_all thing resolved my problems. Flash'ing your custom LoPy4-firmware now works, and your updated pymesh_micropy_scripts/main.py example starts out of the box :-)
        • DanneD Offline
          Danne @catalin
          @catalin Thanks a lot!
          This allows my project to continue, and I look forward to check out the app!
          • CAPKEC Offline
            CAPKE @catalin
            @catalin: I'm using the https://github.com/pycom/pymesh_apps/blob/master/custom_fw_bin/LoPy4.tar.gz on two devices (LoPy4 and FiPy) , but these both devices can not find a neighbor!
            Another 4 LoPy modules with firmware LoPy-1.20.0.rc7.tar.gz work perfectly in parallel.
              ricardolima @CAPKE
              @CAPKE
              Hi, it discover indirectly neighbor too? Thank you
              • catalinC Offline
                catalin
                Hi all,
                The Pymesh docs were updated: https://docs.pycom.io/pymesh/ explaining the frozen library API, BLE RPC, the CLI and the Border Router example.
                It should work with the firmware from https://github.com/pycom/pymesh_apps/tree/master/custom_fw_bin
                @CAPKE So, you're having the corresponding firmware Fipy and Lopy from here, so the 2 devices should create a Mesh network. Probably they're not compatible with the older Mesh created by LoPy-1.20.0.rc7.tar.gz because the masterkey is different. Initially I've used some default masterkey, now it can be set here and the default one is specified here in docs.
                Anyway, you could find the masterkey with command:
                # as test, the masterkey can be printed
                >>> print("masterkey:", pymesh.cli("masterkey"))
                masterkey: 11223300000000000000000000000000
                Catalin,
                kodarnK CAPKEC 2 Replies Last reply Reply Quote 1
                • kodarnK Offline
                  kodarn @catalin
                  @catalin Thanks for updating the documentation!
                  One question: Do you consider lib/pymesh.py to be an api or an application? To my understanding, it spawn's an interactive CLI shell, right? so should it really be a part of /lib ?
                  catalinC 1 Reply Last reply Reply Quote 1
                  • catalinC Offline
                    catalin @kodarn
                    @kodarn good question, so it seems to be both, which is not clear design, right? Just to mention, there are also threads started for BLE-RPC part.
                    One idea would be, in the configuration file to have a parameter to enable/disable CLI (also for the other application features).
                    Or how would you like to use pymesh library? What would you modify?
                    Catalin,
                    kodarnK 1 Reply Last reply Reply Quote 1
                    • kodarnK Offline
                      kodarn @catalin
                      @catalin Perhaps I am misunderstanding things since I was thinking of PyMesh being the Mesh Network. But PyMesh is not that. Instead, PyMesh seems to be more of a wrapper to the Mesh Network enabling BLE/Configuration/CLI stuff?
                      So if I'm interested in building applications with the Pycom Mesh Network API, and not interested in the Bluetooth & CLI stuff, I should use the mesh_interface.py api?
                      • catalinC Offline
                        catalin @kodarn
                        @kodarn Yes, you can use directly mesh_interface.py, but make sure you initialise it as in pymesh.py.
                        The idea was that the pymesh.py is the API level, but you can just use it as it fits your needs.
                        Catalin,
                        • catalinC Offline
                          catalin @catalin
                          As mentioned earlier, the official release process is in this topic.
                          Catalin,
                          • CAPKEC Offline
                            CAPKE @catalin
                            @catalin I updated my LoPy4 and FiPy with the firmware LoPy4.tar.gz and FiPy.tar.gz.
                            On both devices, I successfully tested the example https://docs.pycom.io/pymesh/simple-example/.
                            But if I try out the following code:
                            import ubinascii
                            from network import LoRa
                            lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.EU868)
                            masterkey = ubinascii.unhexlify("112233")
                            pymesh = lora.Pymesh(key=masterkey)
                            See https://docs.pycom.io/firmwareapi/pycom/network/lora/pymesh/#class-network-lora-pymesh-key-masterkey
                            I get the error message:
                              File "main.py", line 19, in <module>
                            AttributeError: 'LoRa' object has no attribute 'Pymesh'
                            Pycom MicroPython 1.20.1.r1 [v1.11-7c63158e0] on 2019-10-22; FiPy with ESP32
                            I'm currently not sure when to use which PyMesh-lib?
                            • catalinC Offline
                              catalin @CAPKE
                              Thanks @CAPKE for spotting that documentation problem. The subclass name is Mesh(), not Pymesh() 😕.
                              I've made a wrong replace-all in docs.
                              Catalin,
                              • catalinC Offline
                                catalin @catalin
                                hi all,
                                Few updates:
                                1. the LoRa.Mesh() class documentation issue, was fixed here, so there's no class name Pymesh
                                2. the repository pymesh_apps was deleted as the information was redundant:
                                • releases are released thru licensing process
                                • scripts and mobile app are https://github.com/pycom/pycom-libraries/tree/master/pymesh
                                Catalin,
                                CAPKEC 1 Reply Last reply Reply Quote 1
                                • CAPKEC Offline
                                  CAPKE @catalin
                                  @catalin Hi Catalin,
                                  I found a other issue at the https://docs.pycom.io/firmwareapi/pycom/network/lora/pymesh/#class-network-lora-pymesh-key-masterkey example:
                                  The constructor class network.LoRa(id=0, …) without the params bandwidth and sf will not work correctly (no neighbors will be found).
                                  Please change to:
                                  lora = LoRa(mode=LoRa.LORA, region=LoRa.EU868, frequency = 863000000, bandwidth=LoRa.BW_125KHZ, sf=7)
                                  • catalinC Offline
                                    catalin @CAPKE
                                    ok @CAPKE, thanks a lot! mode=LoRa.LORAWAN is a mistake, it should have been mode=LoRa.LORA.
                                    A pre-requisite of the Pymesh is that all the nodes (that want to be part of the same mesh network) should be initialised on the same LoRa settings (band, frequency, spreading factor, bandwidth) and master key.
                                    Catalin,
                                      craigzych
                                      Curious if anyone has seen this behaviour.
                                      I have 4 fipy devices.
                                      Using the simple example modified for USA, I had all 4 nodes join last night. I left them plugged in overnight to test if they would all still be connected in the morning. Last night I had one Magenta and 3 green as I'd expect. This morning all 4 were blue meaning they had segmented into 4 separate networks.
                                      Now this morning I can occasionally get 2 to join after resets but they just want to stay separated.
                                      pymesh_config = {'ble_api': True, 'autostart': True, 'debug': 5, 'LoRa': {'sf': 7, 'region': 8, 'freq': 915000000, 'bandwidth': 2}, 'ble_name_prefix': 'PyGo ', 'Pymesh': {'key': '112233'}}
                                      Have you seen this?
                                        chrisso @craigzych
                                        @craigzych
                                        I get this in the office as well with a mixture of 2 x Fipy and 3 x Lopy4.
                                        Also found when driving around doing some range testing, it didnt always rejoin the mesh when in range as I would have expected it to do.
                                          jclo13 @robert-hh
                                          Hello, @catalin, I have the same error, whit the FW 1.20.2.rc11, for pymesh, have you solved it?.
                                          Thank you in advance.
                                          • 4 / 4
