    OneWire.py problem
    onewireds18b20
    26 Posts 5 Posters 2.7k Views 5 Watching
    • K Offline
      kjm @andreas
      @andreas I note Rob has an unused function in there def scan(self), does anybody have an example of that being used?
      K robert-hhR 2 Replies Last reply Reply Quote 0
      • K Offline
        kjm @kjm
        @kjm I tried an ow.scan() after the ow.reset() in start_conversion & read_temp_async, those occasions when I get a None response instead of a temperature are when the scan returns [] instead of [bytearray(b'(\xff\xd3\xe1E\x16\x03>')] I'm really having trouble understanding the logic of 'if self.is busy' in read_temp_async now, because a null response from the scan means it couldn't find the DS18B20 not that the DS18B20 was busy doing a conversion surely?
          robert-hh @kjm
            andreas @robert-hh
            Dear Robert,
            @robert-hh said in OneWire.py problem:
            I do not understand you problem. The onewire driver is built-in into the machines code.
            Unfortunately, this does not happen to be for us. Are you really sure about that detail?
            The only files we can find inside the repository are
            offgrid:pycom-micropython-sigfox amo$ find . -iname 'onewire.py'
            ./drivers/onewire/onewire.py
            ./tests/esp32/onewire.py
            ./ports/esp8266/modules/onewire.py
            ./ports/stm32/modules/onewire.py
            and the first guy comes from [1] - which is actually the 1-Wire driver for vanilla MicroPython which also has a different module layout.
            The driver you are most probably referring to is coming from [2] and is not included by default, unless we are looking in a totally wrong direction.
            However, after including that driver manually into our datalogger program, we received many glitches/misreadings from the sensors. After looking at the code in more detail, we found that the crc8 method is not invoked at all, so it's not surprising that things will go south.
            After some hair pulling, we finally found the contribution [3] coming from your pen and are reasonably happy with it. Results from @kjm also show that this works better than the vanilla pure-Python driver shipped through pycom-libraries.
            Saying this, we feel a bit sad that Pycom hasn't been able to include the native driver from Vanilla MicroPython yet. We humbly started working on [4] yesterday night but will have to back away from that now.
            Please correct me if I am wrong on any of these details. Actually, I would be happy to learn where I missed some important detail.
            With kind regards,
            Andreas.
            [1] https://github.com/pycom/pycom-micropython-sigfox/tree/Dev/drivers/onewire
            [2] https://github.com/pycom/pycom-libraries/tree/master/lib/onewire
            [3] https://github.com/pycom/pycom-libraries/pull/62
            [4] https://github.com/pycom/pycom-micropython-sigfox/pull/356
              robert-hh @andreas
              @andreas Sorry no. It was my mistake. I did not notice that I had onewire.py on that device. Notably the one which had modified. But that one seems stable. And I remember having that running in a test of several sensors for about a week.
              Edit: Pycom does not really react to Pull Requests. Especially PR's for the library are completely ignored. And also for the firmware there seems no on to be in charge of that.
                andreas @robert-hh
                Thank you very much for this. We are also running that and are quite happy with it. However, we see occasional bumps where the CRC check probably hits the fan. Seeing this happen, it is way better than getting any misreadings out of it.
                It's a bit sad yes. We understand the core team must be pretty busy and are more than happy to see MicroPython 1.11 finally came to Pycom MicroPython with the most recent release. Kudos to all who made that happen!
                Saying this, we would be more than happy if someone would pick up the work from [1]. Maybe someone capable and lucky enough to tackle that problem will be the one we could salute here?
                [1] https://github.com/pycom/pycom-micropython-sigfox/pull/356
                • K Offline
                  kjm @kjm
                  @kjm I made a little mod to def scan
                  def scan(self):
                          Return a list of ROMs for all attached devices.
                          Each ROM is returned as a bytes object of 8 bytes.
                          devices = []
                          diff = 65
                          rom = False
                          for i in range(2):
                              for i in range(0xff):
                                  rom, diff = self._search_rom(rom, diff)
                                  if rom:
                                      devices += [rom]
                                  if diff == 0:
                                      break
                              if devices!=[]: return devices
                              self.reset()
                  and got 100% on an overnight run, looks like the DS18B20 sometimes needs a reset after a deepsleep.
                    andreas @kjm
                    @kjm said in OneWire.py problem:
                    self.reset()
                    Thanks! It looks like we already did that to be better safe than sorry. Good to know we have not been dreaming here.
                    # The 1-Wire bus sometimes needs a fix when coming back from deep sleep.
                    self.adapter.reset()
                    -- https://github.com/hiveeyes/hiveeyes-micropython-firmware/blob/0.6.0/terkin/sensor/core.py#L212-L216
                    • K Offline
                      kjm @andreas
                      @andreas All of us reinventing the wheel Anrdeas.
                        crumble @kjm
                        @kjm
                        as long as the hard-/software on which the pycom devices base has timing problems, you have to make your software fault tolerant. Playing around with timings is playing tic tac toe. You cannot win as long as you do not control the exact state of hardware and OS.
                        You have to deal that the device is only 99% reliable and how it can get back into a good state after failure. The high rate of failure makes the ESP 32 a good learning system for this kind of software ;)
                        • K Offline
                          kjm @crumble
                          @crumble It's a real shame. The idea of a python capable micro with integrated 4G looked so good in the advert.
                            crumble @kjm
                            @kjm
                            Pycom ran into this damn ESP 32 trap.
                            Don't expect that Itell you, that the actual firmware solved my problems. I did that too many times and a few hours later everything crashed. But it seems that I2C is now as reliable as the old one core version of the firmware.
                              andreas @andreas
                              Dear @kjm, @crumble and @robert-hh,
                              @andreas said in OneWire.py problem:
                              I was too quick on that detail. After getting into the MicroPython code, I see that porting/enabling the modonewire.c from Genuine MicroPython on Pycom MicroPython will require more efforts than I will be able to dedicate to this topic for now.
                              Finally, we have been able to add support for the native 1-Wire/DS18X20 driver on Pycom MicroPython and published respective firmware images called 1.20.1.r1-0.7.0-vanilla-dragonfly-onewire. See also Inofficial firmware bakery for Pycom/ESP32 devices.
                              Please be aware that you will have to use a set of different Python drivers to access the lowlevel API available through https://github.com/micropython/micropython/tree/master/drivers/onewire.
                              • FiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
                              • GPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
                              • LoPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
                              • LoPy4-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
                              • SiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
                              • WiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
                              If you are willing to test this, we will be happy to hear about the outcome for you.
                              With kind regards,
                              Andreas.
                              • John BairdJ Offline
                                John Baird
                                Jumping in a bit late, but FWIIW - I've been running DS18B20 sensors in many devices that regularly go to deepsleep for months now. They work very well, with few (if any) missed reads. I think the difference here is that our application is very power sensitive, so the DS180B20 is powered from a supply that turns off every time the module goes into deepsleep. Perhaps you could try parasitic power? That would also turn off the sensor during deepsleep.
                                  robert-hh @John Baird
                                  @John-Baird Parasitic power is not easy, because it has to be supported by the driver. For using it, the data line has to switched to a string pull-up aka Vcc when the temp conversion takes place. This strong pullup has to be set within 10µs after sending the start conversion command. That is not possible at app level, but must be done at the bit level driver. I know it because I just have implemented it yesterday.
                                  And it does not solve the problem that sometimes the sensors do not respond. A full powercycle helps, including pulling the data line to 0. If the data line stays high, then the devices stay powered, and that could be the problem here.
                                  b.t.w.: The driver is here: https://github.com/robert-hh/Onewire_DS18X20. It follows the API of the micropython.org version.
                                    andreas @robert-hh
                                    The [refurbished] driver is here: https://github.com/robert-hh/Onewire_DS18X20. It follows the API of the native MicroPython driver.
                                    Taking this chance, we want to thank @robert-hh so much for taking care of all the details regarding this driver. It was a real pleasure to work together with you getting this a real home and - to top it all off - big thanks that you also made its API match the one of the native driver, so people can swap them in and out. We have been doing this through [1] already and are very happy about it.
                                    [1] https://github.com/hiveeyes/hiveeyes-micropython-firmware/commit/2a23af47
