    Pybytes Token and data visualization
    Scheduled Pinned Locked Moved Pybytes IoT platform
    16 Posts 3 Posters 950 Views 3 Watching
      andreas @securigy
      @securigy said in Pybytes Token and data visualization:
      I used the alternative builds you provided instead (the ones built by Robert).
      These builds don't have the pybytes modules compiled in anyway.
      The most recent official FiPy firmware release 1.20.1.1r is flawed, as we all know, (and makes FiPy unusable)
      I wouldn't say so. Pycom will probably not ship flawed things for building the Pybytes platform altogether. It might just be that we don't know how to exactly invoke them.
      then I am out of luck, and cannot use Pybytes
      I believe you will be able to just pass the token into the respective API methods when using the pybytes modules in a manual way?
        andreas @andreas
        @andreas said in Pybytes Token and data visualization:
        Maybe looking at [1] specifically and [2] in general might help you along.
        [1] https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/frozen/Pybytes
        [2] https://github.com/pycom/pycom-micropython-sigfox/tree/Dev/esp32/frozen/Pybytes
        • securigyS Offline
          securigy @andreas
          @andreas About Kotori... I tried to read/browse through it documentation. So correct me if I am wrong: it is a framework that consists of a few tools (some of them, like MQTT, I am very familiar with) that I need to install on a Linux machine somewhere in the cloud... I did not see that it is a specific web site that I need to register my device/s with... Correct? If yes, then it can be a problem for me - the web site I have (gravitystorms.com) on GoDaddy doe not provide access to the OS guts in order to build applications but just for building the visual UI... Grafana looks good though...
            andreas @securigy
            @securigy Yes, this software stack has to be installed somewhere, it is a complete lightweight but slick DAQ backend. Don't you have any iron floating around? However, we are operating a few of these services, two of them are publicly available at [1,2]. Let me know if I can be of help in any way on that aspect.
            And yes, MQTT is a first citizen here, however data ingestion can also be made through HTTP.
            [1] https://swarm.hiveeyes.org/
            [2] https://weather.hiveeyes.org/
            securigyS 2 Replies Last reply Reply Quote 0
            • securigyS Offline
              securigy @andreas
              @andreas I am also wondering if Pybytes are enabled/included in your build that Robert built on Nov 2, 2019?
              I am referring the the issue raised here:
              https://forum.pycom.io/topic/5331/building-compiling-micropython-with-pybytes
              A robert-hhR 2 Replies Last reply Reply Quote 0
              • securigyS Offline
                securigy @andreas
                @andreas I looked at both.... ...few problems:
                1. I don't understand German ;-)
                2. If I ignore #1
                  A. How do I deliver data? (what are MQTT Broker settings: URL/Port, other settings? Dow it support SSL/TLS? If yes, is it Basic Auth by credentials or through security certificates?)
                  B. How do I add/create my account, register the device and then see the data (json? base64encoded?) then how to I do visualization? I have zero knowledge in Grafana...
                • securigyS Offline
                  securigy @andreas
                  @andreas If I in the future plan to deliver relatively big chunks of data, that is, the sensor with 500 Hz gives me 10 seconds of data where each point is tuple...that could be about 100 KB (floats delivered as strings for more compact payload)...
                  Then do you think MQTT will be efficient for these kind of payloads (I always delivered just dozens of bytes in the past) ? Is your broker Mosquitto? Or sockets would be a better way? (delivering 1 tuple at a time will be quite an overhead, I think).
                  If this size is a problem for MQTT Broker, I supposed I could break it to smaller chunks, just not sure what freedom/control I have to stitch them together...
                    andreas @securigy
                    I am also wondering if Pybytes are enabled/included in your build(s)
                    To quote myself here:
                      robert-hh @securigy
                      @securigy No. The builds I provided are deliberately WITHOUT pybytes, in contrast to those from the Pycom download pages.
                        andreas
                        Dear @securigy,
                        thanks for your interest in Kotori. While I will definitively be happy to answer your questions thoroughly, I would like to divert them to reduce the noise about it on the Pycom user forum.
                        You might find some information already on [1] and maybe also [2]. Saying this, I want to humbly refer to [3,4] here, where I tried to explain some basics of Kotori to other people asking about the details. Otherwise, feel free to open yet another issue on GitHub for additional questions.
                        I believe most of your questions can be answered positively like "Kotori's DAQ stack will be able to do it". However, I put down some words on the high-frequency data ingest which is questionable and will require more thoughts and engineering.
                        Yes, we use Mosquitto as a MQTT broker and every feature regarding authentication and beyond will be available as accustomed. Data can be shipped en bloc using JSON or in a discrete way. We designed Kotori to be flexible with respect to these details.
                        We designed Kotori deliberately to omit any device registration steps on purpose. Through the MQTT topic design, it is multi-tenant / multi-channel out of the box. So, it is really just about submitting measurement data and see it coming within Grafana in a "wash & go" style.
                        This style resonates very much with our use-cases of having a hackable DAQ platform without any obstacles with respect to device onboarding and all that jazz. While this is definitively the opposite direction of "enterprise-grade" here, respective features might be added on top.
                        If I in the future plan to deliver relatively big chunks of data, that is, the sensor with 500 Hz.
                        While building the DAQ stack around Kotori, we also thought about these kinds of use-cases with high-frequency measurements and their respective ingesting mechanisms. Right now, I don't believe any solution around what we are doing here will be able to deliver that kind of performance.
                        However, respective requirements are fulfilled through industry-grade systems and we will be happy to look at these kinds of requirements in general by eventually providing respective "fast-path" mechanisms.
                        Do you think MQTT will be efficient for these kind of payloads?
                        While we haven't been able to investigate into that, we will be happy to look more into this. I believe with high-frequency ingest, everything will also depend on efficient payload serialization and database performance. These are advanced topics.
                        I hope this helps for now. Going into more details will probably spiral this thread out of control. However, I will be happy to stay in touch as it looks like we share a common interest here.
                        With kind regards,
                        Andreas.
                        [1] https://getkotori.org/
                        [2] https://github.com/daq-tools/kotori/issues
                        [3] https://github.com/daq-tools/kotori/issues/12
                        [4] https://github.com/daq-tools/kotori/issues/13
                          andreas @andreas
                          See also [1] and [2].
                          [1] https://getkotori.org/docs/handbook/acquisition/protocol/mqtt.html#single-readings
                          [2] https://getkotori.org/docs/handbook/acquisition/protocol/mqtt.html#multiple-readings
