Reading from a Polar H7 Bluetooth Heartrate sensor
I have tried to connect to and read the pulse data from a Polar H7 sensor but is not managing to get it to work. Any ideas?
The error I get is:
Got services...
Reading from service 180d
Print chars found
char 2a37
Reading pulse data every second...
Exception caught...
the requested operation failedHere is the code:
from network import Bluetooth import time bt = Bluetooth() bt.start_scan(-1) # Code to connect to Polar H7 Bluetooth heartrate sensor # The detected Heartrate is "published" over the LoRaWAN network while True: adv = bt.get_adv() if adv: name = bt.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) if name is not None: if name.startswith("Polar H7"): print ("Found: " + name) bt.stop_scan() try: conn = bt.connect(adv.mac) print("Connected...") services = conn.services() print("Got services...") for service in services: time.sleep(0.05) # According to specification from Polar, service.uuid = 0x180D is Heart Rate and char.uuid = 2a37 is value in beats per minutes if service.uuid() == 0x180D: print('Reading from service %x' % service.uuid()) chars = service.characteristics() print("Print chars found") for char in chars: print('char %x' % char.uuid()) # Charactersistic 2a37 is a notification char and we need to enable notification to receive the ValueError if char.uuid() == 0x2a37: # Notify sensor that we want to receive pulse data. byte = bytes([1]) char.write(byte) while True: print("Reading pulse data every second...") print('char {} value = {}'.format(char.uuid(), char.read())) except Exception as ex: print("Exception caught...") print(ex) -
@arneme
The Heart Rate Measurement profile requires BLE notifications, it doesn't work with simple reads.However there isn't yet a system to receive BLE notifications on the LoPy so unfortunately you'll have to wait a bit more.
EDIT: Was catching up on the other threads and apparently this functionality could come next week. I also have a Polar H7 and can look into it at some point.
I was afraid that the notification part was missing in the firmware but great if it appears soon :-). Thanks for the speedy reply.
