    Pymesh wishlist
    pymesh
    18 Posts 4 Posters 1.1k Views 4 Watching
      thinginnovations
      Sleepy edge nodes.
      Andrew
      • catalinC Offline
        catalin
        @thinginnovations Thanks Andrew, for suggestion.
        Could you be a bit more exact of what do you expect?
        I am thinking, that a certain node (connected within a Pymesh network), can be forced to a Child role, so it can go to (deep)sleep as much as it wants. When it wakes up, he will take its old role back (look for the same parent, if not found connect as Child to a different Parent), important thing is that he won't affect the Pymesh. Being a Child he won't relay/route packages.
        Then probably for some nodes, an opposite feature (always Router role) needs to be created, right? So these nodes, would always (most of the time) be active, and they will be designated Leader/Router role with a higher priority.
        Let me know what you think!
        T 1 Reply Last reply Reply Quote 2
          thinginnovations @catalin
          @catalin This is my understanding, the edge nodes don't route traffic, they are like the leaves on a tree - at the very edge.
          I was originally looking at the definitions at https://openthread.io/guides/thread-primer/node-roles-and-types
          Cheers
          Andrew
          catalinC 1 Reply Last reply Reply Quote 1
          • catalinC Offline
            catalin @thinginnovations
            @thinginnovations fyi, as explained here the sleepy end devices was implemented using a simple pymesh.end_device(True).
            For the ref, this is in v1.20.1.r2.
              @catalin Thanks, I'll give it a try.
              What is the timescale for getting the updated firmware after jumping through the licensing hoops?
              Andrew
              • catalinC Offline
                @thinginnovations hi Andrew,
                I'm not sure what you mean. After signing the licence, you'll receive the firmware binary (for Lopy4 and Fipy) immediately.
                On the long run, more features and bugfixes will be added to the Pymesh release, probably you'll receive updates automatically (the process is under implementation now).
                At some point, Pymesh firmware flashing (and licence signing) will be done within the Firmware Update Tool.
                  @catalin
                  ok, form sent back.
                  Andrew
                    thinginnovations @thinginnovations
                    no reply yet.
                      thinginnovations
                      Got it all now, thanks @catalin
                        thinginnovations
                        Using latest pycom updater (1.16.1) and I cant seem to select tar.gz files from the file list when using the Flash from local file option. All the files are greyed out and unselectable.
                        This is on Mac OS Catalina.
                        Any ideas?
                        The file received did not contain the L01 firmwar images, only for FPy and Lopy4.
                        Andrew
                        catalinC A 3 Replies Last reply Reply Quote 1
                        • catalinC Offline
                          @thinginnovations This is due to newest application rights, in Catalina. (Try System Preferences/Security&Privacy/Full Disk access).
                          Could you make a new topic in https://forum.pycom.io/category/17/software-tools and maybe the community has the solutions.
                            andreas @thinginnovations
                            @thinginnovations said in Pymesh wishlist:
                            Using latest pycom updater I can't seem to select .tar.gz files from the file list when using the Flash from local file option. All the files are greyed out and unselectable.
                            I believe someone from our community also reported this recently. I couldn't believe it.
                            @catalin said in Pymesh wishlist:
                            This is due to newest application rights in macOS Catalina.
                            Thanks for letting us know about this detail, @catalin! Bummer.
                            @thinginnovations: Maybe invoking the programm from the command line still works for you like
                            Prepare
                            alias pycom-fwtool-cli='/Applications/Pycom\ Firmware\ Update.app/Contents/Resources/pycom-fwtool-cli'
                            export MCU_PORT=/dev/cu.usbmodemPye090a1
                            Invoke
                            pycom-fwtool-cli --verbose --port $MCU_PORT flash --tar FiPy-1.20.1.r1-0.7.0-vanilla-dragonfly-onewire.tar.gz
                              thinginnovations
                              Finally got around to reflashing the firmware on a few LoPy4 devices. Seems 1 repeatedly guru mediates. I used a windows laptop to reflash, gave up on the Mac.
                              Next question for @catalin , when will the L01 firmware be available or can the Lopy4 firmware be used on the L01 ?
                              thanks
                              Andrew
                              • catalinC Offline
                                @thinginnovations
                                If you still have this problem, it can be easily sorted by renaming firmware package .tar, instead of tar.gz. We're looking into it.
                                  @catalin That works. Now I can reflash firmware on a mac.
                                  Andrew
                                  • catalinC Offline
                                    • DanneD Offline
                                      Danne
                                      @catalin
                                      Is Pymesh still under development?
                                      I wish to have the issue with running out of buffers resolved :)
                                      Problem:
                                      After a while nodes are unable to send data to each other.
                                      To reproduce, start up two nodes, send message until you run out of "free buffer", to check available buffer, run buffer info...
