    LoRaWAN network
    21 Posts 4 Posters 9.1k Views 5 Watching
      gouao @gouao
      @gouao Is that possible to create a LoRaWAN network using LoraMAC instead of OTAA join tho ?
      I understand better how does it work, thanks !
      The solution you proposed on TTN webbsite seems nice, i'll dig on it.
      So, how my LoRaWAN network will work once the gateway will be able to listen the LoPys ? Would I need to pass through a server then, only to make my LoPys devices communicate ?
        jmarcelino @gouao
        @gouao
        Yes, LoRaWAN requires a network server even for just 2 devices. Also it's not meant for devices communicating between themselves, it's more for having many devices uploading small amounts of data to some server.
        For device to device there's LoRa mode (without the WAN), which is essentially just a radio channel, like a walkie-talkie. But remember you need to do your own encryption then and probably establish some sort of protocol.
          gouao @jmarcelino
          @jmarcelino Sure, the devices communicating between themselves case was for some tests.
          How this server scenario actually works ? The planning will consist to send data to this server.
          So the LoRa mode is certainly working on low frequency ? Do you know the range of this mode please ?
          Furthermore, what could be the etablishment of my own encryption ? Some code to add in the boot.py ?
          Do you have any code samples wich could help me on this, and for the LoRaWAN network ?
            jmarcelino @gouao
            @gouao
            I suggest reading a few things on LoRaWAN such as https://www.thethingsnetwork.org/wiki/LoRaWAN/Home and also this crash-course video https://www.youtube.com/watch?v=T3dGLqZrjIQ
            It's difficult to say a range with anything radio, it depends on your environment, but my best with LoRa was 5 Kilometres using SF12, no line of sight and the receiver located at an altitude of 8 meters
            For encryption of LoRa data you could use for example AES, see https://docs.pycom.io/pycom_esp32/library/ucrypto.AES.html
            then just make sure both LoPys have the same key.
            I don't have any LoRa samples sorry, but the nano gateway example I linked below and the LoRa-MAC (Raw LoRa) in the Pycom tutorial should explain it.
            G bmarkusB 2 Replies Last reply Reply Quote 0
              gouao @jmarcelino
              @jmarcelino It's very kind of you, I will dig on this side !
              May I return to you if I still have questions ?
              Thanks for all.
              • bmarkusB Offline
                bmarkus @jmarcelino
                @jmarcelino said in LoRaWAN network:
                With line of sight we have stable link in 50-60 km where S/N is around 0dB which means there is plenty of spare link budget down to -18dB. Conditions:
                • 868 MHz
                • Kerlink professional gateways
                • SF12
                • Simple omni-directional antenna
                Record is cca. 150 km distance. In a city like Budapest from car with antenna on the roof 20-25km usually works with Kerlink gateways.
                On 434 MHz with P2P using SX127x chips, not SX130x we have seen 60km link, on a bicycle tracking it gives 10-12km reliable tracking with stable station just in a house, no hilltop, towers, etc.
                  gouao @bmarkus
                  @bmarkus said in LoRaWAN network:
                  • 868 MHz
                  • SF12
                  Wow, thanks ! Can you estimate the price of such a project ?
                    jmarcelino @gouao
                    @gouao
                    It's not really a question of price, but 99% about antenna positioning - especially what's around the antennas - on both nodes and gateways.
                    You can easily spend $1000+ on a gateway and not get much more than 1Km.
                    Line of sight and antenna height are particularly important. The video I linked explains a lot about that.
                    bmarkusB G 2 Replies Last reply Reply Quote 0
                    • bmarkusB Offline
                      bmarkus @jmarcelino
                      @gouao
                      People tend to forget LoRa is RADIO technology which need ANTENNA and proper POSITIONING, not only software. A proper antenna can make miracles. However we see better performance using a Kerlink GW over RPi even they have the same chipset. Frontend filters can improve performance on receiving side. By experience the latest Kerlink station outperforms current generation according to our tests. So for higher price you get better performance. But true, you can reach poor performance for high price also with improper installation, noisy environment, etc.
                        gouao @jmarcelino
                        @gouao
                        True, the vid explains a lot about it, and underlines points like antenna height, reflection & diffraction phenomenon.
                        Any ideas how could I configure a server for a LoRaWAN network, wich will probably work with a TTN gateway please ?
                          jmarcelino @gouao
                          @gouao
                          If you mean running a server for your own private LoRaWAN network (outside of Things Network) you can try https://github.com/brocaar/loraserver
                          The other alternative - and the way I'm using - is to run you own copy of Things Network, it's fully open source and they even provide a setup guide at https://www.thethingsnetwork.org/article/setting-up-a-private-routing-environment - but you should really understand how their system works first.
                          • bmarkusB Offline
                            bmarkus @jmarcelino
                            @gouao
                            You can use a Loriot server also, which is free for 1 GW and up to 10 devices, see https://loriot.io/
                              gouao
                              Thanks both of you !
                                Stroggo @jmarcelino
                                @jmarcelino It's possible to send peer-to-peer with two LoPy's. Pycom have supplied a tutorial on that in the documentation. The range I get between two LoPy's is about 400-500 meters in urban area, which is not particullary good though
