    OTA firmware update
    17 Posts 9 Posters 4.6k Views 9 Watching
      livius @jcrfonera
      @jcrfonera
      you can only upgrade by UART
      ftp is curently not supported
        jcrfonera
        @livius
        Thank you for your answer, but it is the same as Xykon Nov 9, 2016
          livius @jcrfonera
          @jcrfonera
          still bootloader is modified from version to version
          until that ftp update will be not possible
            jcrfonera
            @livius
            thanks for your reply.
              jasonriedy
              The security aspects are... interesting to say the least. For my use, firmware updates in the LoRa window signed by some key under our control could be useful. And we have physical possession for a while before deployment but would like to extend the ability for updates to other bee keepers. This is an open area of practice/research in general. (Also not my area, so perhaps others know of the right mechanisms.)
              • N Offline
                noobiemcfoob Pybytes Beta
                The updater doesn't work for me. I can connect via ftp but using the updater I get "Connecting... failure!" I have tried several computers and cables.
                  acheesehead @livius
                  @livius said in OTA firmware update:
                  @jcrfonera
                  Does that imply that once the bootloader is stable, then OTA firmware update via FTP will be supported? This feature would be very important to us, unless the firmware becomes so stable that it is not changed appreciably.
                  Are there any plans to replace FTP and Telnet with scp and ssh? This is somewhat important to us.
                    arthurlutz @jmarcelino
                    @jmarcelino said in OTA firmware update:
                    @admiral99
                    I don't have a breakout board either, just use a cheap (£1) USB-serial TTL adapter.
                    Just make sure it supports and it's set to 3.3v
                    I'm having trouble updating the firmware with my FTDI232, the REPL on pymakr works fine (in 5V), trying the update setup I'm switching to 3.3v, it should still be connected to VIN ou should it be connected to the 3.3 V pin ?
                      jmarcelino @arthurlutz
                      @arthurlutz
                      You really have to check your adapter, many 3.3V level TTL FTDI232 adapters - in fact the official FTDI-branded cable does that - deliver 5V on V+ so you should connect that one to Vin. Some have a pin marked 5V.
                      That's probably what you want because most adapters can't deliver enough power on their 3.3V output to power the Py boards, the regulator is too weak.
                      However any adapter should be set to 3.3V voltage level signals. That means TX and RX must use 3.3V.
                      If you do have a FTDI-style adapter that can deliver enough current on 3.3V (suggest 500mA) you can connect it to the 3.3V pin directly on the Py board.
                      Read closely before you buy and then if possible test it before using it.
                        acheesehead @jmarcelino
                        FTDI 232-3V3 cable works.
                        http://www.ftdichip.com/Support/Documents/DataSheets/Cables/DS_TTL-232R_CABLES.pdf
                        @arthurlutz
                          acheesehead @acheesehead
                          Specific part number is TTL-232R-3V3.
                          @acheesehead said in OTA firmware update:
                          @arthurlutz
