mqtt with ssl
Hi
I'm trying to connect to a mqtt server using port 8883, and have the following:
client = MQTTClient("userX", "XXX", port=8883, user='XXX',password='XXX', ssl=True, ssl_params={'cert_reqs':ssl.CERT_REQUIRED, 'certfile':'cert/ca.pem'})
Doing a
client.connect()
gives me:Traceback (most recent call last): File "<stdin>", line 1, in <module> File "umqtt/simple.py", line 58, in connect OSError: -1
I'm able to connect to the server from my desktop with a python script. I'm using the same
ca.pem
file in both cases, do I need a seperate files, is the setup correct (ssl_params
@Asb I put the full path to the certfile in my config ('certfile':'/flash/cert/ca/pem'}, maybe this helps.
André
@aen No, but I think the problem is with my certificate, unless someone says the initialization is wrong.
@Asb No answer to your question.. Did you move past your problem?
