    New firmware release 1.3.0.b1
    32 Posts 16 Posters 14.0k Views 17 Watching
    • I Offline
      iotoz
      Where do we find this elusive firmware update? Can't wait to use it.
      If it is not available yet, when?
        daniel @iotoz
        @iotoz it's here: https://www.pycom.io/support/supportdownloads/
        (Under Firmware Updates)
        • I Offline
          iotoz @daniel
          @daniel Thanks for that, I had checked there. I can still only find pycom_update_1.0.0.b3.tar.gz for linux, or any other platform.
          Any chance that you can post a direct link to the linux firmware 1.3.0.b1 ?
          Would be ideal to see a Git rep with the firmware versions to choose.
          D rcolisteteR 2 Replies Last reply Reply Quote 0
            daniel @iotoz
            @iotoz that's the version of the updater only. Please use it and it will tell you that it's going to apply firmware version 1.3.0.b1 to your modules.
            • F Offline
              Feiko
              Hi thanks for the update. I have a project connecting to websockets over ssl. Since last release my project broke, a ssl fix was promised this release however the project still doesn't run. Can I expect a fix in the next days? Is there a way to revert my firmware to a previous version? I like to revert to version 1.1.
              Keep up the good work.
                @iotoz yes we are aware that it was promised for this release but we haven't been able to fix it yet, sorry for the delay. Long story short, the TLS/SSL library runs out of memory while wrapping the socket. This problem was introduced when we enabled Bluetooth support. We have raised this issue with Espressif and they are working on optimizations to solve this once and for all. We were really hoping to sort it out for this release but unfortunately it wan't possible.
                Trust me, this is a major issue for us as well, and it's on the top of out list. We'll let you know once we have more news.
                  @iotoz we have made previous releases available, but 1.1.0 is not there. We'll make that one available on Monday. I'll let you know once that's done.
                  • F Offline
                    Feiko
                    Thanks I'm looking forward to the fix. Until then 1.1.0 will probably do the job.
                    • rcolisteteR Offline
                      rcolistete @iotoz
                      @iotoz said in New firmware release 1.3.0.b1:
                      See this post :
                      "The "file" attribute shows the direct link to the firmware binary files. You can then download the file with wget "https://software.pycom.io/downloads/1.0.0.b2-LoPy_868.tar.gz" and use bin/updater.py -t 1.0.0.b2-LoPy_868.tar.gz -p /dev/ttyUSB0"
                      So for 1.3.0.b1 with 915MHz, download the file :
                      https://software.pycom.io/downloads/1.3.0.b1-LoPy_915.tar.gz
                        crankshaft @daniel
                        @daniel - Thanks for the update, but I am struggling with the 100 - 120ma power consumption of the wipy2 and need to reduce power by using the machine.sleep modes and RTC.wakeup()
                        Any idea when this will be added ?
                        rcolisteteR 1 Reply Last reply Reply Quote 0
                          rcolistete @crankshaft
                          @crankshaft said in New firmware release 1.3.0.b1:
                          Loot at this topic.
                            leelive
                            Thanks for this update! I have a question about RTC. Our application requires very low power. The RTC doc says, "The RTC counter ticks at 5 MHz.", but the LoPy (OEM) spec sheet says RTC uses 32KHz, Will a future release give us the option of specifying the 32KHz clock?
                              toribios_people @daniel
                              @daniel Version 1.1.0 is still not available in the downloads section, when will it be available? Thanks.
                              • Z Offline
                                zmrzli
                                Program below switches led colors every minute or so if Bluetooth() is called.
                                Without it runs as expected.
                                Is that a bug?
                                from network import Bluetooth
                                bluetooth = Bluetooth()
                                pycom.heartbeat(False) # disable the heartbeat LED
                                pycom.rgbled(0xff0000) # make the LED light up in RED color
                                pycom.rgbled(0x00ff00) # make the LED light up in GREEN color
                                pycom.rgbled(0x0000ff) # make the LED light up in BLUE color
                                C M J 3 Replies Last reply Reply Quote 0
                                  crankshaft @zmrzli
                                  @zmrzli - I think you need a short sleep in your loop otherwise it will consume 100% processor time and there won't be time to do anything else ?!
                                    mohpor @zmrzli
                                    @zmrzli you are clogging the main thread in that sample code and the CPU never gets to do anything else because of that while True, if you want to change the LED color this fast, try putting it in a thread. And please add some delay between those LED color sets.
                                    import _thread
                                    def led_totary(id):
                                            time.sleep_ms(50)
                                            time.sleep_ms(50)
                                            time.sleep_ms(50)
                                    _thread.start_new_thread(led_totary, (0))
                                      jmarcelino @zmrzli
                                      @zmrzli
                                      It's not such a bad question because the ESP32 is dual core. I remember reading the original plan was one core would handle all networking while the other would be totally free for the user to use, not sure if that's still the case. Now I'm curious to find out :)
                                      That said for sure there's all sorts of locks involved even with two cores so could be the reason
                                        Hi everyone,
                                        At the moment we are only using one of the 2 cores, but we plan to enable multi-core support soon. MicroPython will run on core #1 and the network stacks (BT, WiFi, LoRa, Sigfox) will run on core #0. We have chosen to stay on 1 core for a while to wait for the ESP IDF to become stable enough around dual core support.'
                                        • Z Offline
                                          zmrzli
                                          If bluetooth was not working, than that could be blamed on tight loop without opportunity to release processor (sleep), but that is not the case. Following code takes few minutes to get to green light:
                                          It seems that same resource (line?) driving BLE is used for bit banging LED in 1.3...
                                          There is change about it in 1.4.0, so maybe this will be fixed.
                                          • 2 / 2
