    pymakr will not sync project
    5 Posts 4 Posters 1.7k Views 4 Watching
    • F Offline
      feabhas
      I am loosing the will to live here.
      I am having a reoccurring problem with pymakr just hanging when trying to sync a project after a previous successful sync.
      I have the latest firmware installed.
      I can telnet/ftp/screen (I'm on OSX) to the picot LoPy unit
      I can see the REPL cli in pymakr
      But whenever I try to sync a simple project (setup.py and main.py) it just hangs
      My project is setting the IP address using DHCP to my local network (successfully)
      The only way I can seem to recover is to always have to do a factory reset of the filesystem
      this seems pretty extreme and unacceptable operation.
      Any ideas? Any way of getting a log file for the comms between pymakr and the LoPy board?
      MicroPython v1.8.6-379-gc44ebac on 2017-01-13; LoPy with ESP32
        Shaun
        See:
        https://forum.pycom.io/topic/496/pymkr-syncing-failed/2
          livius @feabhas
          @feabhas
          Do this in different way:
          1. create file e.g. wifi_sta.py
          2. write to it any config (IP settings) and other methods
          3. in e.g. main.py write
            if button()==1: #you can use ==0 if you need different action to be default
            execfile('wifi_sta.py')
          in this way if your sync will fail
          you have still your board with default AP settings when you press button or not
          and in my opinion - do not use Pymakr.
          I do not use it - only i work by ftp - edit and put file back
          It is faster for me.
          F H 2 Replies Last reply Reply Quote 0
          • F Offline
            feabhas @livius
            @livius thanks for the advice will give it a go.
            • H Offline
              hemalchevli @livius
              @livius thank you so much, I too was banging my head with the same issue, FTP is much better and reliable, I'm using tera term to see the console.
              thanks
              Cheers
