expansionV3 + lopy4, P2 during RST
I have a expansion board V3.1 (with expansion31_0.0.11.dfu), with a Lopy4 plugged.
We use visual code with PlatformIO, in C++ to develop and upload the firmware.I haave 2 questions:
Actually, I have to connect P2 to GND to be able to upload.
1 => Is there a way to update the LOPY4 firmware without any P2_to_GND manipulation ?
2 => Is there a way to update the LOPY4 firmware without pushing RST physical button ? -
@frecfrec I'm not sure that works with the expansion board (I believe it does with the 3.x versions which have a similar PIC to the PySense/PyTrack), but AFAIR the CLI update tool (
pycom-fwtool-cli) should be able to instruct the PIC on the board to take the required steps to switch to firmware update mode. If it doesn't by default, you can add the--picoption. -
Thank you for you answer, using windows10, I tried to flash using pycom-fwtool-cli,
.\pycom-fwtool-cli.exe -p COM9 -s 115200 --pic flash -f .\firmware.bin output => You must either specifiy the tar[.gz] file or both the file and partition to flashbut requested input is a .tar.gz and not a .bin file.
PlatformIO generate .bin files for firmware.bin and partitions.binI'm afraid to break my lopy4, putting those 2 files into a tar.gz file and testing it.
Is it the right way to do it ?
@frecfrec You can probably use another mode that doesn't need a file (maybe reading the config block with
cb?) and the--noexitto stay in firmware update mode, then use your usual flashing tool.Alternatively, you can use the
copycommand of the tool to write a.binfile (though I'm not quite sure what the partition parameter should be, it probably depends on what you .bin file actually contains -- you may want to backup existing partitions and compare with the firmware that you are supposed to already have on the device to find the right value). -
@frecfrec said in expansionV3 + lopy4, P2 during RST:
finally done creating a tar.gz file containing:
- firmware.bin (our firmware compiled with platformIO)
- bootloader.bin (copied from a tar.gz sample)
- partition.bin (copied from a tar.gz sample)
sample used for bootload.bin and partition.bin:
https://packages.hiveeyes.org/hiveeyes/foss/pycom/official/pybytes/LoPy4-1.20.2.rc3.tar.gz
