New Firmware Release 1.20.2.rc6
  • A new firmware release 1.20.2.rc6 is now available. Even though this is marked as a release candidate, we think it's more stable than the previous release which is why it's available in the standard pybytes category.
    Changes:
    • IDF recompiled with v98 compiler
    • Ctrl-D works if pybytes is disabled (pycom.pybytes_on_boot(False))
    • updater.py supports additional pybytes options
    • Sigfox: finalizing certification RCZ1, 2, 4
    The firmware packages (.tar.gz) can be downloaded from the docs.
    The elf files can be found on github.
  • Any change log of firmware 1.20.2.rc7 ?
    It is not cited in the GitHub releases page :
    https://github.com/pycom/pycom-micropython-sigfox/releases
  • @robert-hh I only ever connect to GPy in the traditional headless manner (I initially only had a GPy board , no expansion board, no USB). I created a boot.py to set it up as a STAtion, established a wifi connection on MacBook Pro to the SSID gpy-wlan-7b7c and ftp'ed boot.py. After reset I use ftp to update boot.py and main.py. I telnet to it test code snippets in REPL.
    If you provide me code to retrieve the values you are interested in I can use REPL to display them or I can put them in a main.py and write the values to a file and retrieve it with ftp.
  • @dgerman If you connect your GPy to a terminal emulator and push the reset button, then you'll get some messages. These are the ones I'm asking for. Sample witth a LoPy4 below:
    ets Jun  8 2016 00:22:57
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8020,len:8
    load:0x3fff8028,len:2140
    ho 0 tail 12 room 4
    load:0x4009fa00,len:19760
    entry 0x400a05bc
    Pycom MicroPython 1.20.2.rc6 [v1.20.1.r2-115-g5e92391-dirty] on 2020-04-08; LoPy4 with ESP32
  • @robert-hh Sorry I don't understand what you are asking for.
    Summary:
    GPy 1.18.1.r2 (as received)
    boot.py set LED green, pink, connects to wlan as STAtion and finally green.
    main.py updates time from ntp sets LED blue then sends syslog message.
    After update to 1.20.2.rc6 LED blinks but no syslog message is received. GPy does not respond to ping, telnet or ftp.
    After erase_all and update, LED shows heartbeat (since boot.py and main.py were initialized as empty). GPy transmits SSID as AccessPoint one time only and macBookPro can no longer connect.
  • @dgerman Can you show the full log you see in a console window after pushing reset?
  • @peterp Should I create an issue at GitHub?
  • @peterp Thanks. On Mac OS with Pycom Firmware Update.app include develop versions I choose
    GPy-1.20.2.rc2 ++SUCCESS++
    GPy-1.20.2.rc3 --FAILS only transmits SSID once---
    GPy-1.20.2.rc2 --FAILS !-!
    GPy-1.20.2.rc2 with erase file system ++SUCCESS++
    Did not see rc4 or rc5.
  • @dgerman said in New Firmware Release 1.20.2.rc6:
    @peterp After erase_all and flash my boot.py and main.py are no longer there
    Ugh, yeah, of course. Sorry, wasn't thinking along properly here. Mhm ... it's weird ... I'm thinking ...
    I cannot connect to Access Point to put them there.
    just for completeness, you know you can work with pymakr?
    If I download and flash a previous version of the firmware for GPy where should I get it? I am using a Mac so how do I get Pycom Firmware Update.app to flash a specific version?
    you should be able to select previous version also in the application ... if you want to download them manually, see here https://software.pycom.io/downloads/GPy.html
  • @peterp After erase_all and flash my boot.py and main.py are no longer there as I can tell by the heartbeat.
    Using
    sudo iwlist wlan0 scan
    on a Raspberry PI Zero W reports
              Cell 06 - Address: 80:7D:3A:94:7B:7D
                        Channel:6
                        Frequency:2.437 GHz (Channel 6)
                        Quality=70/70  Signal level=-40 dBm
                        Encryption key:on
                        ESSID:"gpy-wlan-7b7c"
                        Bit Rates:5.5 Mb/s; 11 Mb/s; 1 Mb/s; 2 Mb/s; 6 Mb/s
                                  12 Mb/s; 24 Mb/s; 48 Mb/s
                        Bit Rates:54 Mb/s; 9 Mb/s; 18 Mb/s; 36 Mb/s
                        Mode:Master
                        Extra:tsf=0000000000000000
                        Extra: Last beacon: 30ms ago
                        IE: Unknown: 000D6770792D776C616E2D37623763
                        IE: Unknown: 01088B9682840C183060
                        IE: Unknown: 32046C122448
                        IE: Unknown: 030106
                        IE: Unknown: 0706434E00010D14
                        IE: IEEE 802.11i/WPA2 Version 1
                            Group Cipher : TKIP
                            Pairwise Ciphers (2) : CCMP TKIP
                            Authentication Suites (1) : PSK
                        IE: Unknown: 2D1A6E1100FF00000000000000000000000100000000000000000000
                        IE: Unknown: 3D1606050000000000000000000000000000000000000000
                        IE: Unknown: DD180050F2020101040003A4000027A4000042435E0062322F00
    I notice the only difference between multiple reports is
    • Extra: Last beacon: 30ms ago
    • Extra: Last beacon: 2070ms ago
    • Extra: Last beacon: 4260ms ago
    Which seems to confirm my suspicion that GPy is only broadcasting SSID once.
    I don't know how to interpret anything else in the report.
  • @dgerman Understood. And are you able to test that AP behaviour after temporarily removing your boot.py and main.py?
  • @peterp Thank you for your response.
    After erase_all and flash I expect GPy to be blinking heartbeat and to be in Acces Point mode broadcasting SSID of gpy-wlan-xxxx (where xxxx are low order digits from MAC) with a password of www.pycom.io with a telnet server and ftp server running at 192.168.4.1 .
    This is what I expect now but it seems to broadcast SSID only once (or a few times) ( I am using Mac Boot Pro , Catalina 10.15.4 which prior to flash 1.20.2.rc6 offered to connect and the airport utility continuously reported it's RSSI.)
    wlan = WLAN(mode=WLAN.STA)
    For my understanding, do you want to put the GPy into STA mode or in AP mode? If you want AP mode, can you then try without your boot.py and main.py?
  • @rcolistete from my notes (as I cannot access system) Is this what you are looking for?
    os.uname():
    1/07/20 (sysname='GPy', nodename='GPy', release='1.18.1.r2', version='v1.8.6-849-f652205 on 2018-10-18', machine='GPy with ESP32')
    I did NOT know I was supposed to erase flash first.
    Thanks for including the command.
    I extracted pycom-fwtool-cli from the Pycom Firmware Update.app and ran
    pycom-fwtool-cli list
    pycom-fwtool-cli -p /dev/cu.usbmodemPy0d3d0c1 erase_all
     Running in PIC mode
     Erasing the board can take up to 40 seconds.
      Board erased successfully in 12.51 seconds
    Then ran Pycom Firmware Update.app which ran as previously.
    The GPy now blinks heartbeat and broadcasts SSID gpy-wlan-7b7c as expected at least a few times. But the Mac book pro that previously connected to it as an access point does not offer to connect to it. After 60 seconds it no longer appears in the list of networks shown by apple's airport utility (I expect that the first(few?) broadcast, retained in cache expired)
    Just to be redundant(?) I did the erase_all again and ran the update again but still no joy.
    I await addition assistance, Thank you
  • What was the previous MicroPython version ?
    Have you erased the flash memory before installing the firmware 1.20.2.rc6 ?:
    $ pycom-fwtool-cli -p /dev/ttyACM0 erase_all
  • @peterp After updating GPy WLAN no longer connects.
    I used max os Pycom Firmware Update.app 1.16.2 to update a GPy to 1.20.2.rc6. Ran nicely:
    writing gpy.bin
    Changed baud rate to 230400
    Wrote 4 KiB to config in 0.07 seconds
    Device ID: 807D3A947B7C
    EXISTING (previous working) boot.py includes:
    pycom.heartbeat(False)
    pycom.rgbled(0x005000)      # green
    from network import WLAN
    pycom.rgbled(0x201010)
    wlan.ifconfig(config=('192.168.1.3', '255.255.255.0', '192.168.1.1', '192.168.1.1'))
    wlan.scan()
    wlan.connect(ssid='Mynet', auth=(WLAN.WPA2, '5Cav')
    pycom.rgbled(0x003000)
    (previous working) main.py includes:
    pycom.rgbled(0x000060)      # blue in main
    from machine import RTC
    rtc=RTC()
    for i in range (1,8):
        pycom.rgbled(0x302020)      #   pink going to network
        rtc.ntp_sync("pool.ntp.org")
        pycom.rgbled(0x301010)      #   pink back from  network but did it work?
        if time.localtime()[0] > 2019:
            break
        time.sleep(1)
    pycom.rgbled(0x000060)      #   blue back to main
    import usyslog
    s = usyslog.UDPClient(ip='dalom', facility=usyslog.F_LOCAL5)
    s.alert('++ main.py: reset:' + str(machine.reset_cause()))
    LED indicates that boot is progressing and main gets time from NTP (since it does not loop for 8 seconds) although if it is not connected to the WLAN that does not make any sense. No syslog entries are recorded at the syslog server.
    I can no longer connect via ftp or telnet or ping (since it is not connected to the WLAN).
    I am able to run the update which installs the firmware. (edited since I had some difficulty creating the post)
    But although GPy seems to broadcast its SSID briefly, the Mac book pro which connected to it as an access point previously no longer offers to connect to it. After 60 seconds it no longer appears in the list of networks shown by apple's airport utility (I expect that the first broadcast, retained in cache expired)
    How do I proceed?
  • This post is deleted!
    writing gpy.bin
    See additional info (separate since combined identified as spam!)
  • @Xykon Many thanks.
19 out of 23
