queue, double put blocks code
I tested this code inside pycom and using the command line generated by pymakr in vs code.
import queue
a = queue.Queue()
a.put("teste")
print("all good")
print(a.full())
a.put("teste")
print("not gonna show ")result:
all good
Trueconclusion:
Is the real limit of the queue one input?
Or am I doing something wrong?
@Doroana, not sure if you have figured this out yet but when you create your instance of the queue, you can give it a parameter of the size of the queue.
a = queue.Queue(10), this will create a queue with max size 10. The default value is 1.
