    New firmware release 1.4.0.b1
    65 Posts 15 Posters 42.3k Views 14 Watching
      PeterBaugh @jmarcelino
      @jmarcelino Out of interest how are you measuring the power consumption of your device?
        constantinos
        Can you give us more explanation for machine.idle and sleep modes?
          jmarcelino
          So there's the small caveat that disabled doesn't mean 'turn off' the interface :-) Thanks for the clarification! The STA power savings are very good news though, can save a lot of battery with almost no effort.
          By the way I found that if I do:
          from network import WLAN
          wlan = WLAN(mode=WLAN.STA)
          power saving is enabled, but if I use this instead it doesn't:
          wlan = WLAN()
          wl.mode(WLAN.STA)
          @PeterBaugh: Just looking at my power supply reading at the moment. I also use a coulomb counter (LTC4150) for consumption over time (without needing to do integration) I'm hoping to do a blog post on this soon.
          D 1 Reply Last reply Reply Quote 2
            daniel @jmarcelino
            @jmarcelino
            wlan = WLAN()
            wl.mode(WLAN.STA)
            If that's the case that's an issue. We'll check. Thanks!
              crankshaft
              @daniel Been waiting for this, thanks very much, I am looking now at my power supply which definitely shows the current is down, but fluctuating a lot.
              But I have a feature request, is it possible to have a machine.sleep(msec) where msec is the number of milliseconds that you want to sleep.
              This would be really cool, to be able to put it to REAL sleep without interrupts.
              And on the same subject, are the RTC interrupts on the horizon so that we can achieve the above, only with more code ?
                livius @daniel
                @daniel
                something is wrong
                pycom.rgbled(0xff0000)
                OSError: the requested operation is not possible
                >>> os.uname()
                (sysname='WiPy', nodename='WiPy', release='1.4.0.b1', version='v1.8.6-398-g4a4a81e on 2017-01-20', machine='WiPy with ESP32')
                  @livius that's being done on purpose, you need to disable the heartbeat first. You can either have the heartbeat enabled or control the LED manually. What are you trying to do?
                    jmarcelino @livius
                    @livius
                    I noticed that, but wasn't sure if it's new. You have to disable the heartbeat before using rgbled
                    pycom.heartbeat(False)
                    Maybe a little jarring for first time users just trying to blink the led
                      livius @daniel
                      @daniel
                      i have this file from start(3 month ago)
                      file "wifi_ap.py"
                      print('wifi_ap')
                      pycom.heartbeat(0)
                      pycom.heartbeat(1)
                      this worked in all previous version of firmware
                      now it does not work.
                      If it should not work previously in that way i can fix this
                        jmarcelino @livius
                        @livius
                        Why is the code turning the heartbeat signal off just to turn it on right after?
                        If you remove the pycom.heartbeat(1) line it should work.
                          livius @jmarcelino
                          @jmarcelino
                          file 3 month ago and i suppose copy paste from doc or forum
                          but why i can not change color of led when it is on?
                          and i disable default blink of led which is after normal boot(firmware blink)
                            livius
                            but something is wrong try this:
                            1.
                            pycom.heartbeat(0) #disable
                            pycom.rgbled(0xff0000) #change color - but this also turn it on
                            pycom.heartbeat(1) # strange this also disable led
                              jmarcelino @livius
                              @livius
                              This is how I understand it:
                              1. heartbeat is a special function associated to the led and needs exclusive access. If it's active (set to 1 or True) you can't override it and the led will just blink periodically in blue.
                              2. rgbled doesn't just change the colour, it sets the led immediately to the colour you give it. If the colour is anything other than 0 (black) it turns the led on. To turn it off do pycom.rgbled(0)
                                livius
                                and also problem with i2c
                                previous code run without any problem but now i got:
                                I (8388) wifi: connected with livius, channel 9
                                WLAN connection to the router succeeded!
                                  File "boot.py", line 16, in <module>
                                  File "wifi_sta_router.py", line 65, in <module>
                                  File "bmp180.py", line 48, in __init__
                                OSError: I2C bus error
                                was something changed also in i2c?
                                @jmarcelino
                                i can also understand this in that way but what is then purpose about parameter
                                pycom.heartbeat(1)
                                pycom.heartbeat(0)
                                i can disable it and enable back with the same color as previous?
                                but pycom.heartbeat(1) also disable it when it was enabled
                                i suppose that this work as toggle instead on/off
                                @daniel
                                also i see that when i send file - size 3201 bytes throught wifi
                                it is somehow broken inside - it is transmitted as 3201 but some lines are wrong when i download it back throught wifi
                                e.g.
                                oryginal file
                                		ileTemp180=0
                                	if (prevCisnienie180!=cisnienie180):
                                		prevCisnienie180=cisnienie180
                                		s.send('{"U":"' + UID + 'C180' + '", "V":[[' + str(cisnienie180)+','+str(ileCisnienie180) +']]}\n')
                                		ileCisnienie180=0
                                	time.sleep(1)
                                and after download back:
                                		ileTemp180=0
                                	if (pr180) +']]}\n')
                                		ileCisnienie180=0
                                	time.sleep(1)
                                UPDATE
                                i see that problem with i2c was only because this crash(trash) in file not i2c itself (i suppose)
                                when i send this file e.g. 20 times (always successfully)
                                then it was eventually as should be and code work ok also in newest firmware
                                12 sensors read data throught i2c, one wire, digital and ADC and send it back throught wifi to service on computer and back to database :)
                                And now i have question - how many times we can write to flash?
                                What is the write cycle life of that flash?
                                UPDATE 2
                                I supposed that it all was fixed
                                but after fresh start on early morning it bring me back same error about i2c
                                  crankshaft
                                  OK, just discovered something....
                                  If I power the WIPY2 via expansion board / USB then it boots, but if I power it by VIN and GND it does not.
                                  I have proved that it appears to be firmware related by performing the same test on another board that has factory firmware.
                                  Can someone else verify this ?
                                  Update 1
                                  Is there a circuit diagram for the expansion board, I can't seem to find one ??
                                  If I remove the expansion board jupmers for TX and RX and power it via USB, it does not boot, same as powering with VIN, I now suspect that the new firmware may not be pulling the TX/RX lines high during boot, or something is waiting for these lines to be pulled up.
                                  Update 2
                                  OK, If I hold P0 high, then the board will boot when:
                                  1. powered via VIN
                                  2. powered via USB but the TX jumper is removed.
                                  So my guess is that the firmware is not doing a soft-pullup on this pin during bootup ??
                                  Update 3
                                  After more study, I believe that this issue is caused when calling the serial console in the boot.py file, the system tries to initialise the serial console and if the line is not high then it just waits forever until it is.
                                  So not really a bug !
                                    mohpor
                                    @daniel
                                    Thanks for the updates.
                                    The Bluetooth.CLIENT_CONNECTED and Bluetooth.CLIENT_DISCONNECTED are working as expected. but I just can't work the Bluetooth.CHAR_NOTIFY_EVENT! It simply won't call the callback function.
                                    I'm developing my own test app for iOS and when I try to subscribe to the characteristic I have defined, I get an update from my peripheral manager that indicates the characteristic is not subscribed for notification! Meaning the BLE characteristic has rejected the subscription. Could you provide us with a working example of the event callback to work on? Am I missing something here?
                                    Here is how I'm defining the callback:
                                    def char_subscribed(chr):
                                        print("Char Subscribed: %r" % chr)
                                    chr1_cb = chr1.callback(trigger = Bluetooth.CHAR_NOTIFY_EVENT,  handler = char_subscribed)
                                    P.S.: If I substitute CAHR_NOTIFY_EVENT with CHAR_READ_EVENT the callback is called when I try to read.
                                    UPDATE:
                                    As I was browsing through the newly available source code of the MicroPython for pycom boards (Thanks a lot), I have noticed that the Notify event is for the BLE Client mode only (?!) am I right? it says MOD_BT_GATTC_NOTIFY_EVT which from GATTC part I'm guessing it is for GATT Client only! Could someone confirm my findings?
                                    UPDATE 2:
                                    Using other utilities leads to same results: If you try to subscribe, it simply fails to subscribe.
                                    Tools I tried: LightBlue (iOS and macOS)
                                      jmarcelino @mohpor
                                      @mohpor
                                      Yes thats is correct, the notification events are for the Py boards working as a GATT client only.
                                      What are you trying to achieve by having a notification callback as GATT server? Servers usually just send a notification if a characteristic was updated (this isn't implemented yet)
                                      • W Offline
                                        Wembly
                                        I have seen in later releases that I get a lot of these:
                                        W (196498) wifi: post pm rx bcn failed
                                        I have no idea why, I cannot recall that I got them before.
                                        They seem to be harmful since my sockets are being dropped after a while. Also, when they arrive the hw seem to stall for many seconds.
                                          mohpor
                                          @jmarcelino
                                          I'm not sure what your question is about, but, there is a valid pattern involving here.
                                          Acting as a server (GATT), you can start updating a characteristic's value IF the client subscribes to its notification which is extremely essential to GATT Servers, otherwise, you are updating a characteristic when no one's even interested in it!
                                            jmarcelino @mohpor
                                            @mohpor
                                            Yes that would be useful but this is a CHAR_NOTIFY_EVENT notification, where the Py board, acting as a GATT client, subscribes to a characteristic and for some reason (usually when the value was updated) the GATT server wishes to notify the Py board.
                                            As far as I know the Py acting as a GATT server cannot send notifications yet, so at the moment - to me at least - there seems to be no useful purpose for a "subscribed" callback.
                                            • 1 / 4
