    PySense library on Extension Board 3.1
    2 Posts 2 Posters 74 Views 2 Watching
      aparcar
      I'm trying to read the battery voltage with the PySense/pycoproc library function read_battery_voltage(), however the board detection fails with the error message below. Is there no support for the Extension Board 3.1?
      rst:0x7 (TG0WDT_SYS_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8020,len:8
      load:0x3fff8028,len:2140
      ho 0 tail 12 room 4
      load:0x4009fa00,len:19760
      entry 0x400a05bc
      Smart Provisioning started in the background
      See https://docs.pycom.io/smart for details
        File "main.py", line 15, in <module>
        File "/flash/lib/pysense.py", line 20, in __init__
        File "/flash/lib/pycoproc.py", line 115, in __init__
      Exception: Board not detected: I2C bus error
      Pycom MicroPython 1.20.2.rc6 [v1.11-01f49f7] on 2020-02-28; LoPy4 with ESP32
      Pybytes Version: 1.3.1
        robert-hh @aparcar
        @aparcar On expansion Boards you can determine the battery voltage with the internal ADC on Pin P16. There is a voltage divider between the battery an P16, which divides the battery voltage by 2 or by 3.05, depending on the board. So you can use the ADC class (see https://docs.pycom.io/tutorials/all/adc/) with 11dB attenuation to read the input voltage and scale that by the divider. E.g. if the ADC tells 1.9V, and the divider is 2, the the battery voltage is 3.8V. Since the ADC is noisy, you may have to calculate an average over say 100 values taken. If you have an voltage meter, you should take that to obtain the proper scaling value.
